Question about Craftsman Convertible 25cc. Gas Line Trimmer
CRAFTSMAN WEEDWACKER 316-791860, WILL NOT START. HAS SPARK, FUEL LINES FILL UP, WAS RUNNING FINE, DIED, STARTED NEXT AM, RAN 5 MINS THEN DIED AND WOULDN'T RESTART
    Problem Solver:
  • 19 Answers
Two things which may be the problem: 1) carb need to be rebuilt or replaced, and 2) you need a new spark plug. The carb with shipping is around $50.00 from sears ( http://www.searspartsdirect.com/partsdirect/part-model/Craftsman-Parts/Grass-trimmer-weed-wacker-Parts/Model-3167918602008/0247/1503820/P0805032/00001?blt=06&prst=&shdMod= ) A sparkplug can be had at any small engine repair shop and most auto parts stores for less than $5.00 Start with the cheap solution... Also make certain you have fresh gas and that the oil mix is correct.
Posted on Oct 31, 2011
Mower will not start
Hi, check that you are getting a spark at the spark plug 1st. Also check that you my have an air lock in your fuel pipe.
Apr 21, 2014 | Craftsman Garden
Backfiring and missing
change the spark plugs.
Jan 06, 2014 | Cars & Trucks
Managemylife com
1.You have to remove the air filter *** cover.
2.Remove air filter.
3.Remove 2 screws, to remove the rest of air filter ***.
4.Remove the 2 fuel lines with a long nose plier.(Take a photo of
the position of fuel lines or mark fuel lines for reassembly)
5.Unhook the throttle cable.
Now to fix the Carburettor
1.Remove the 4 screws on primer bulp side of the carburettor.
2.Open the carburettor and clean with paint brush and clean fuel.
3.Replace diaframe kit(available from your nearest dealer) and reassemble the trimmer.
Dec 30, 2013 | Craftsman WeedWacker Gas Trimmer 29cc...
My Craftsman Weedwacker, (Model # 358.791010 ) does not start. originally it took about 5 - 10 minutes to start and once it was running, I'd hit the switch from "START" to "RUN" and...
Sounds like a carb problem. You may need to rebuild it. Check to see if your fuel lines inside the tank have rotted. Common problem on Craftsman.
Nov 01, 2010 | Craftsman 25cc Gas Line Trimmer
Weedwacker won't start
Is there an air lock in the line. Remove the lines and insert only one at a time and see if one will take fuel and the other none? Also, check carb float to make sure its not stuck open intaking fuel constantly flooding bowl
May 31, 2010 | Craftsman 25cc Gas Line Trimmer
I have a 2003 craftsman 6hp lawn mower. It would start and not stay running so I cleaned the spark plug, cleaned the carb and drained the fuel. It ran decent for a mow, the next time I used it I started it...
Fuel Problem, Pull off the Carb bowl you will see the problem (Green Gunk and Varnish. When you drop the Carb Bowl you will see a hole in the carb assy. below the float, use a paperclip or other small object to clean it out........its probably plugged.
Jul 12, 2009 | Craftsman Garden
Primer bulb won't re-fill.
Not sure about your particular set-up, but there is usually two fuel lines running from the fuel tank. One goes to the carb and the other goes on a fitting on back of the primer bulb. The primer bulb will have a second fitting with a line going to carb. Sounds like either a clogged or leaking fuel line to me. Hope this helps and good luck.
Jul 11, 2009 | Garden
1998 mitsubishi mirage 1.5 liter 5 speed wont start
If you have spark, try changing the fuel filter. If you don't have spark, get back to me.
May 21, 2009 | 1998 Mitsubishi Mirage
88 Toyota Corolla backfires through carburetor.
If that is carbureted, and has a mechanical fuel pump, try running a length of fuel line from inlet side of pump to a gas can that has fresh, clean fuel, and if it runs good that way, you know problem is most likely in the tank. Removing the tank & cleaning it out is best solution from there. I'd even be tempted to add a small bottle or 2 of Lucas Fuel Sytem Cleaner to first fill in clean tank, just to help clean lines as well as carb.
May 20, 2009 | 1994 Toyota Corolla
Engine intermitantly stalls
if this a fuel injected car just check to fuel pressure first.
Oct 24, 2008 | 1994 Pontiac Bonneville
Craftsman Convertible 25cc. Gas Line Trimmer Logo
729 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
