The printer squeaks loudly when I prints. - Office Equipment & Supplies
  • ervins89 Apr 07, 2011
    This printer prints perfectly, but it makes high-pitched squeaking noises, as though some gears need oil. It is not a rumbling noise. I replaced the toner cartridge, since it doesn't start squeaking until the paper starts running through.That didn't help.
    The squeak has a rhythm like the rotation of a wheel. It starts slowly as it prepares to print and then speeds up as it pulls the paper through. It stops after the paper comes out of the machine.
    Hope this helps.
  • ervins89 Apr 12, 2011
    I am not a technician and I have no repair manual so I don't how to identify or get at the gears you are talking about. Where can I get access to a diagram or parts list that show me how to repair what you're talking about?
    Ervin
    Genius:
  • 1,570 Answers
Hi
It is the gears of either the imaging drum rollers or the fuser drum rollers of the toner cartridge itself that squeaks. You need to grease these gears and if not try to replace the cartridge and to check if the squeaks sound will disappear.
Also, check the cartridge compartment for spilled ink and clean the compartment by removing all the cartridges and clean it using a soft cloth with rubbing alcohol.
Please post comments if you need more help. Welcome to Fixya.
Regards.
Posted on Apr 08, 2011
  • 6,993 Answers
Let me share this piece of information with you that might be of help.
I just fixed a LaserJet 2100TN that had the same exact symptoms - rumbling noises from deep inside when the paper path components were moving, but the printouts came out perfect. The printer worked fine, but the noise was very annoying to the owner. The sound reminded me of a drive gear problem or a paper path problem. I first tried a new toner cartridge, but the noise was still there. So, I removed all of the covers and checked the drive gears, but they were in pristine condition. The paper path was dirty, so I removed the fuser to get a full view of the paper path. I used a soft lint-free cloth and compressed air to thoroughly clean the inside of the printer (including the insides of the covers). I used compressed air to clean out the fuser assembly, but it wasn't very dirty. I found a large buildup of toner on the transfer roller (foam roller under the toner cartridge) and cleaned off the excess with the cloth and then compressed air. I reinstalled the original toner cartridge and tried another printout - the rumbling noise was gone and the printout was still great. I noticed that the LaserJet 2100TN has three rubber paper feed rollers that resemble tank tracks. They are in the area where I felt the noise was coming from. It might be possible that the dirt or toner residue could been hampering their rotation, which would have probably made a rumbling noise as the rollers (inside the tracks) moved, but the rubber tracks didn't. Although I did remove the fuser (maybe it had a bad connection) it appears to me that dirt and toner residue were the culprits.
I hope this helps.....
Good luck
Posted on Apr 07, 2011
My XEROX 6180N printer has vertical white lines running on left side of page and also has starting making loud squeaking noise while printing? Any ideas?
Try a different cartridge. While line typically means that no toner is being applied to the drum in that location. Would also explain the squeaks.
Sep 02, 2015 | Xerox Phaser Office Equipment & Supplies
My Dell 5210n printer has a very loud squeak in the back. How do open the printer to lubricate the bearings?
Usually you don't lubricate. It is probably the fuser assembly wearing. How is the print quality? Have you ran a test page, ran a supply status page? Checked the error log?
Jan 17, 2013 | Dell 5210n Laser Printer
My HP Officejet 6500 wireless E709N makes a loud squeaking noise every time something is printed and is printing additional lines on the sheets of paper being printed?? Help!
Horizontal streaks across the page usually mean your cartridge is about to run out, or is at least dirty. Try cleaning the nozzles, though avoid doing this manually -- your printer should have a cleaning cycle.
The squeaking noise could be dust in your rollers. That can't really be fixed without major intervention that could throw something out of balance and result in many a paper jam. You can use a lint-free, static-free cloth to gently clean inside an unplugged printer, but it's generally not a great idea to mess around in there too much.
May 06, 2011 | HP Officejet 6500 Wireless All-in-One...
Brother HL5250DN makes loud squeaking noise while printing. Sounds like crickets chirping.
This is not a problem but it can be early signs of the drum and rollers wearing out. When it does die, I suggest buying another printer.
Dec 07, 2010 | Brother HL 5250DN Laser Printer
Copies are coming out with a dark horizontal lines and printer is making a rather loud sound when paper is in printing process.
Two things that can cause print quality issues and noise.
1. The toner cartridge can cause lines and sometimes can make a squeaking noise.
2. The fuser can cause streaking and smudges on the prints and can cause a grinding noise if the drive gear is worn or the bushings are worn.
Oct 15, 2010 | HP LaserJet P3005 Printer
My printer is squeaking very loudly whenever it
Take it apart, and clean and lube the components.
Oct 14, 2009 | Lexmark C532dn Laser Printer
HP laserjet 3055 beeps loudly when printing. Would like it to stop!!! Otherwise printer is just fine.
If it's a grinding or squeaking problem, it's a pickup roller assembly problem. Would need to be serviced, or returned if still under warranty.
Jun 26, 2009 | HP LaserJet 3055 All-In-One Printer
HP LJ P2015DN making noise/squeaking
As you mentioned that the printer makes loud grinding noise or squeaking when page comes out than i feel this is the noise coming out due to faulty fuser.
I want to be sure so please open the rear bin and try to print if still noise comes than i m sure it is fuser.
If there are smudges on the printed page or if some film coating is coming out with printed page than fuser roller are physically damage.
However in this case i assume fuser is faulty.
If there opening the rear bin noise goes off than top output rollers are faulty.
Thanks and Regards
Neeraj Sharma
Feb 18, 2009 | HP LaserJet P2015dn Printer
Squeak
PHOTPSMART PRINTER 4180 MAKES SQUEAK SOUND WHEN SCANNIN
Aug 14, 2008 | HP Photosmart D5160 InkJet Printer
Squeaking noise when printing
This is a duplicate posting; here is the link to the active posting: http://www.fixya.com/support/t132706-squeaking_noise_when_printing
Feb 02, 2007 | HP Color LaserJet 5500hdn Printer
75 people viewed this question
jasbo
jasbo
