Question about KitchenAid 24 in. KUDI02IR Built-in Dishwasher
How to remove water input assembly
There is an assembly on the side on my whisper quiet dishwasher, it has a buildup of water deposit in it and I am trying to remove it. I removed the hose off it and I thought I should be able to remove it by turning the piece on the inside of the diswasher a quarter turn or something. I can't get it to turn at all... Is there a trick to removing that?
  • garnd Aug 06, 2008
    Thanks for the info jsrock516, that is what I was talking about, so I guess if there is a little leaking water through it also, you should just use some silicone on the outside to stop the leak as it can't be taken apart to replace the gasket?
  • 5,911 Answers
If you are talking about the plastic molded piece on the outside of the dishwasher tub where the water inlet hose runs to, this piece does not come off. Its a permanent molded piece of the tub. If you break it, you have to replace the entire tub. The build up of water scale and deposits is a common problem in this area. If you remove the rubber hose and use a small screwdriver or small brush (the kind you would use for cleaning gun barrels) this is sufficient to get most of the deposits free. Flush with distilled vinegar and hot water. If I'm wrong in assuming this is what you're talking about, please post back and let me know. I hope this helps you.
Posted on Aug 06, 2008
  • Jeff Rockwell
    Jeff Rockwell Aug 06, 2008
    That might work. What happens sometimes is that it can give the appearance of a leak as sediment builds up inside the assembly and creates a blockage. As water tries to enter through the hose and into the tub, it is partially (or fully) blocked and sprays out the sides. Thats why I suggest that you take the hose off and try pushing a small screwdriver or stiff small brush through to see if there are any deposits, first. I had a customer with this problem and it ended up leaking and ruining their kitchen floor.
My dishwasher drawer is not draining the water well after the dishes are washed and then is smells. How can unclog the drain so that it will drain? the filter is clean.
The pump may be worn so it doesn't pull all the water out.
Or a bad check valve so it allows water back into the washer after it was sucked out
Jun 18, 2015 | KitchenAid Double-Drawer Dishwasher System...
My Maytag Qriet Series 100 Dishwasher won't drain
Check the drain hose connection at the sink drain for local blockage. If ok, you may have to tear down the lower spray arm assembly down to the deck (noting orientation and position as you remove parts). Look for clogged screens and clogged openings in the deck. You can use a vacuum hooked to 'blow' to make sure these openings are clear. Wash the screens in hot water, detergent, and white vinegar to remove water and food deposits. Make sure upper and lower spray arms have open spray holes and no split seams. Hope this gets you running again!
Feb 10, 2010 | Dishwashers
Child lock blinking on a Kitchenaid ultima diswasher.
Try holding the E.S. button down for 30 seconds. Does not work, you need an Electronic control assembly which can be ordered online from Repair clinic .com for $146 for your model plus shipping. This is apparently a common problem with Kitchenaid dishwashers. Just repaired one the other day. Tried everything, but as soon as the new Electronic control assembly was installed, everything was Okay. This is an easy repair for anyone who is handy at all. Please shut off power to the dishwasher by switching the breaker off or removing the fuse.
Feb 04, 2010 | KitchenAid KUDR25 Dishwasher
My dishwasher runs fine but has become very noisy. is that a problem? it used to be "whisper quiet" & now it sounds like a drone
usuallly a pump motor asssembly is required.. most had a five year parts warranty and if out of warranty most assembly are 100-300 dollars for the part.
Feb 03, 2010 | KitchenAid 24 in. KUDS01FLBL Built-in...
Kitchenaid Whisper Quiet + dishwasher making loud humming noise
Very likely pump motor shaft seal leaks water into bearing casing buildup of rust and consequently noise. I just replaced $112 worth of pump assy and it's back to normal. I would also buy repair manual for $10 on-line to be sure how to disassemble the sump to get to the pump.
Jul 14, 2009 | KitchenAid Dishwashers
Water leaking from botom of Door
see if float cup is free on bottom of machine so it is not overfilling. take old toothbrush and clear any accumulated soap buildup from bottom of door and gaskets.
Feb 16, 2009 | KitchenAid Dishwashers
Kitchen aide won't drain
look in your air gap first make sure there is no debrie in there this will make you dishwasher drain really slow.
Jan 16, 2009 | KitchenAid 24 in. KUDI02IR Built-in...
Hard water deposit build up
Do not disassemble the arms. Just go get the product Lemi Shine. The product is awesome. It removed years of buildup of my machine that I thought I would have to throw away. You can find it at your local grocery store.
Dec 14, 2008 | Maytag MDB9100A Dishwasher
KitchenAid 24 in. KUDI02IR Built-in Dishwasher Logo
150 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
