Question about Sony CDX-R3300 CD Player
I turned the volume up the other day and it got stuck, it kept getting louder and louder. I turned it off, but now I can only use the CD player. I can't change the volume on the CD player. I also can't use anything on the radio like change the clock or use the radio.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Sony Master
  • 2,226 Answers
You need to free the stuck switch. As long as it is jammed, it is going to send a signal to the microprocessor. The microprocessor can only handle one command at a time, so while the volume up switch is sending a signal to it, it will do nothing else.
Posted on Apr 07, 2011
SOURCE:
A year ago, while playing a CD with a corrupted track, the JVC KF-HDR44 stopped responding entirely. The CD kept playing at a loud volume, and there was no way to turn it off or turn it down. After I...
You may have a problem with the front panel. There is no harm in removing the front and sending it to a service location to check. If you want to go ahead and order, then call 18005825825. They will help you order it.
Sep 26, 2013 | JVC KDHDR44 In Dash Receivers
Try to adjust the volume(on dock only) and just keeps getting louder havt to pull ipod
Volume button stuck in. Try and free the button as it may be jammed. It may need to be taken apart to loosen the up volume button. First try prying it up externally but be careful not to break anything in the process.
Sep 21, 2012 | Bose SoundDock digital music system...
I recently had my car broken into and someone tried to steal my system. Thankfully my fiance heard and went out in time and they drove away. They had disconnected some of my wires and we tried to put them...
wire from battery(normally red) to 12v+, really skinny wire(normally blue) to remote, black or silver wire from ground to grnd. No you dont need the converter as long as you have your rca from asftermarket cd player to your amp(preferred way). You might have also bridged your amp with your speaker wires which would cause your system to run on a different ohm which would cause the bass to get louder then overheat you amp which would turn it off.
Aug 16, 2009 | Rockford Fosgate Car Audio & Video
Cuts out in the middle of a song
this happens because of old discs or cassette which have complete there age after some time and this is not important while its new or old..
May 31, 2009 | JVC KARAOKE, 3-CD CHANGER, 3 MIC INPUT,...
Alpine ida-x001 volume is low even if stereo is turned all the way up only when ipod is plugged in on ipod setting.Radio (AM/FM) is normal volume (louder)..How can I fix this?
Most newer car receivers have a feature named something like "level balancing" in which you can adjust the relative loudness of each input (Tuner, CD, AUX, IPOD). Check you owner's manual for a similar function.
Also, are you or can you turn the level of the ipod itself up a bit?
Mar 07, 2009 | Alpine iDA-X001 CD Player
When i turn on my vm9311ts it comes on at a louder volume
page 12 of your manuel left corner volume adjust program check there
Jan 07, 2009 | Jensen VM9511TS AM/FM/CD/DVD/SD Player/7"...
Creative Zen
Most audio software these days offer either built-in or plugin functionality that will attempt to level the volume of your MP3 files so that you aren't turning the volume up to hear soft songs, then getting blasted by louder ones. So why is it that even after turning that option on, you sometimes notice a significant volume difference between some songs? What's worse is when you're listening to songs from the same album, and the volumes jump around abnormally after applying volume normalization.
The problem is that the vast majority of audio player programs use peak amplitude analysis to determine how "loud" a song is and normalize based on that, rather than doing a more comprehensive analysis of the frequencies that impact how loud the music actually sounds. But even those that do a more comprehensive analysis fail to consider songs within the context of the album they belong to.
Luckily, there's a great little utility called MP3 Gain that does lossless volume analysis and adjustment based on David Robinson's Replay Gain algorithm, as well as allowing for the volume of entire albums to be processed. MP3 Gain has been around for a number of years, and it doesn't appear that it is being actively developed anymore, but since MP3 technology hasn't changed much either that doesn't matter for our purposes.
So, how do you fix an entire library of music? Pretty easy, actually. MP3 Gain offers batch processing options that allow you to process an entire folder at once. But if you collect music albums, you'll want to do those separately. The reason is that MP3Gain offers two modes: Radio and Album. Radio analysis and gain adjustment will adjust all songs to the same maximum decibel level. Album mode analyzes all of the songs in an album, essentially considering them to be one entire song, then adjusts them all to a maximum decibel level, but maintains their relative volume.
Jun 21, 2008 | Creative Labs Zen Digital Media Player
M&S Systems MC602 Master Unit and M&S MCD6 6-disc CD Player
mc 602 system---volume stuck on 32 and not playing main speaker
Mar 05, 2008 | Audio Players & Recorders
Volume Adjusts
Hi There Briank36,
Most electronic devices now days rely on a small "battery" device inside to retain the memory settings that you set the system to.
This memory device can be a small battery or a capacitor, which is kept charged by the power supply during its on time.
When you turn the System off the memory device keeps the settings you like for the next time you turn the system on.
During this Off time the memory device is slowly discharged.
So as you say the system is now 5-6 years old so I suggest that the memory device needs to be replaced for a new one...
as it now cant kep the memory settings for as long as it used to...
I dont know the actual electronic configuration of your particular system but this would be the first item to replace..
Its only a few dollars in cost to have done.
cheers from YUBEUT.
Dec 04, 2007 | Fisher SLIM-1500 CD Shelf System
Sony CDX-R3300 CD Player Logo
240 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Mike Duncan
Mike Duncan
Dalynn Turner
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
