Question about Kitchen Appliances - Others
Older Neon sign flickers. Do I look for a bad connection? Is the neon low? Thanks
  • 4 Answers
Most likely the cathodes (the part that excites the gas molecules) in ether end of the tube are at the end of there life. A local sign shop may be able to repair the problem for a minimal cost. If you are not an electrician you should not attempt to repair this on your own. Neon is powered from a transformer / ballast with high voltage and could cause a fire hazard if not repaired properly.
Best of luck
John K Electrician / Electrical Contractor 30 years
Posted on Apr 09, 2011
How do I open the3 fuse box under the hood of my 02 dodge neon,it keeps humming
PDF]Owners Manual - Dodge
https://www.dodge.com/download/pdf/.../2004_JR41_Stratus.pdf DodgeThe interior lights will come on when you open any door, ... There is a door lock switch on each front door trim panel ...... the hood release lever located under the left side of the ...... and neon signs. ...... NOTE: Using the "3" range while operating the vehicleunder ...... The fuse access panel is behind the end cover at the left.
were is the fuel pump reset button for a 2001 dodge neon?
www.cargurus.com > Questions > Dodge > Neon
CarGurusJul 26, 2011 - were would i find the reset button on my dodge neon i need help badly is there ... I would check the fuse under the hood and relay. ... Fluid, spray into your intake with engine off and throttle open .... 2002 Dodge Neon For Sale.
[PDF]WIRING DIAGRAMS - Ertyu.org
www.ertyu.org/steven_nikkel/neonfsm/2000/EPL_8W.pdf
what causes the humming noise thats coming from my fuse box in our ...
https://answers.yahoo.com/question/index?qid...
Feb 4, 2011 - I am in a Alpha Ideal 34 ft rv. The fuse box on wall started humming a noice lastnight. Coming right from in the area of the switches. What could ... Buzzing noise coming from fuse box/lights flickering?
Aug 25, 2013
Breaker/Fuse box noise please help?
Sep 11, 2011
Why is my home's fuse box making a loud constant buzzing noise ...
Jan 3, 2011
My house fusebox has a buzz sound?
Jul 14, 2009
More results from answers.yahoo.com
Feb 05, 2016 | Jeep 02 - 05 Chrysler Sebring, Dodge Neon,...
Which is advanced or better : Neon or LED illumination?
LED lighting is more advanced. Neon has a long history, having been used for nearly a century.Though Neon has the brightest lighting capacity, it requires maintenance. Neon emits more energy than LED lights. LED works in any climate. This makes LED a very reliable optionfor illuminated channel letters. They require much less maintenance and are more energy efficient than neon. Neon signs are easily broken. Being made of glass, they leak. LED does not have this problem . Once you get a neon sign, there's no changing it. Custom LED signs can be updated as often as you like, with whatever messages you like. Custom LED Signs Toronto Single Double Sided New Style Signs
Jul 31, 2015 | Neon Sign Inc Old Style New Orleans...
I have a tapping noise in my 2005 neon it just startaed
check the oil make sure its full. change the oil with recommended grade oil and the filter. if this doesn't fix the issue have the oil pressure checked. neon are known to have bearing issues that cause low oil pressure and a tapping noise because the lifters are not getting enough oil. some will have the oil light flicker when engine is idle in gear. another cause for a tapping would be the belt tentioner
Feb 09, 2014 | 2005 Dodge Neon
Neon sign shuts down
there is a weak connection in the wiring. there may be a back panel that you can remove with a screwdriver to view the wiring
Feb 16, 2013 | Neon Sign Inc Budweiser Neon Jacksonville...
Engine runs rough after a few miles
Easy way to check plugs wires while driving, get 4 or 6 small neon lamps depending on how many cylinders,the neon lamps used in appliances to show they are on are good NOT LEDs.
Remove resistors from neon and connect one side of neon lamps together and earth to body, take other side of each lamp and solder long single telephonr wire and wind about 10 turns around each plug wire insulation a little way from plug leave end of this wire disconnected. make sure the end of wire does not earth anywhere on body leave unconnected. the high voltage going through plug wire will induce enough voltage to fire neon and show plug works if one neon does not flicker as plug fires it the bad one.
This will only show electrical misfire not injector problem.
The best time to do this test is at night neons will flicker bright at night. As a mechanic how to check injector and injector voltage.
Jun 28, 2017 | 1994 Isuzu Rodeo
Chrysler neon 2002 shows a exclamation sign on
It's either your brake pads are low or you are not putting the handbrake down to the lowest seting (it could be that your handbrake lever is not disconnecting the switch properly) To see if it the pads, jack the front of the car up, lever the pads away from the discs, and if the light goes out, the pads are worn, if it doesn't, then you lever is at fault. your pads should have 5mm of meat on them, any lower and your pads will connect a circuit.
Sep 13, 2009 | Chrysler Neon Cars & Trucks
New Leviton 'lighted, decorative' switch flickers when off
You cannot use standard electronic dimmer switches with CFL bulbs, only incandesant bulbs! That is why you are getting the flickering.
With CFL's bulbs installed in a light fixture that has a non-flouresant rated dimmer switch on that circuit, you will cause the standard dimmer to fail.
You have to look at the dimmer package (sometimes printed on the back of the dimmer itself too) to see if it can be used with CFL bulbs,as many are not rated for use with anything other than standard incandesant bulbs.
Hope you found this very helpful and best regards!
May 31, 2009 | Leviton Decora Light Dimmer Switch
1998 Dodge Neon 2.0L SOHC
Do you have eng light on and what mileage do you have and have you ever replaced the timing belt on it?
Jan 04, 2009 | 1998 Dodge Neon
Neon sign lights up inconsistently
If you are a trained person that knows how to measure electricity and switches, I would use a multimeter with the power off, and check the switch. Other than that it actually sounds like your ballast(transformer) is going out. They can be picked up pretty cheap at Lowes or Home depot. Good luck.
May 21, 2017 | Neon GREEN PC POWER SUPPLY KIT Power...
Fuse sign light on when start my car
Hi my name is Allen!
Normally this means you have a fuse blown!
This year model neon had a lot of problems with the instrument cluster circuit boards, its hard for me to say thats what it is without being there to check it.
If this is not causing problems I would just drive it until it comes on all the time then check the fuses again, it could be a fuse thats trying to go bad, you know like a light bulb that will flicker for awhile and then burn out.
For further assistance contact me at FixYa!
Dec 23, 2008 | 2001 Dodge Neon
Kitchen Appliances - Others Logo
396 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
