Question about Craftsman 12" Drill Press (21914)
How do i replace a stop collar on a craftsman drill press?
2 Suggested Answers
SOURCE: Bought a craftsman drill press mod. 11321370 and
try managemylife.com
Posted on Dec 27, 2010
Replacement of cord for a 3.5 amp 1/2 in. Crafstman drill
that's surprising, as sears usually can solve those issues....anyways....you can just get num14 grounded wire, to length you need and that will cover the amps you're using for that drill and a bit more.you'll have to re-use the rubber grommets, or improvise one from something else....like perhaps a roll of soft rubber wrap made into a grommet!!!
Apr 22, 2012 | Craftsman Drills
I need to replace a cord on an old Craftsman 1/2" drill
A lot of times B&D makes molded cords that work with Craftsman stuff. Look up a service center near you and take the cord in to see if they can match it up with something they have. (Take the drill in too.)
http://dewalt.com/Find-Service-Center.aspx
I need to replace the Rack on a Delta 16 1/2 inch Drill press, model 17925. Do I need to pull the drill head or is there an easier way ?
I looked at a schematic and owners manual for a 17-950, COULDN'T find the one you listed and if I am not mistaken I believe there is a collar holding the rack in position and if you snug the table or somehow keep from falling you can loosen the collar and using the height adjustment move the rack so you can remove it. BUT I also found a dedicated help line that I would suggest calling first about this and the number is 1-800-223-7278.
Feb 25, 2011 | Drills
Pro-Tech 10" drill press model 10162. Quill travel adjustable?
There is probably a depth stop collar with a thumbscrew on the shaft which has the three handles attached to it. This collar would be about two inches in diameter. All you have to do is loosen the thumbscrew.
Apr 26, 2010 | Makita 6825 Factory Reconditioned Drywall...
The chuck on my craftsman 8" drill press wobbles. How can I stop it from wobbling?? Can I get a manual for my drill. thanks. billybee3@yahoo.com
There are a couple of different ways that drill chucks are attached on smaller tools. You didn't specify the model, so I can't help much. But here is a link to where you can usually find manuals for Craftsman. If the press is not too old, you will probably be able to find the manual here.
http://www.searspartsdirect.com/partsdirect/index.action
Feb 25, 2010 | Craftsman Drills
How to switch to hammer on dc935
Turn the black clutch adjusting collar all the way to the hammer symbol. It will be just past the Drill symbol on the collar. Then when you press the bit against the material you will feel the vibrations.
Oct 14, 2009 | Dewalt 18 Volt Compact Drill Kit
Craftsman 10" bench drill press chuck wobbles
If this is a new tool I would take it back and get it replaced. The only other way to eliminate this problem is to determine if it is the spindle or the chuck and replace the defective unit. Warranty works better.
Oct 07, 2009 | Craftsman Drills
Chuck is locked in open position
What you can try is some WD 40 spray into the chuck and then find a GOOD pair of gloves or a rag and hold the collar of the chuck either by hand or use the rag and a pair of channel locks to protect it and then use the tool motor slowly and see if that doesn't release it
May 25, 2009 | Craftsman 14.4 volt Cordless Drill/Driver...
Replace drill chuck on 23 year old Craftsman 8" drill press
Yes it does have a Morse taper and you can remove it by gently hitting it with a rubber or nylon mallet.
Feb 08, 2009 | Craftsman 4" Drill Press Vise, Side -...
Craftsman 12" Drill Press (21914) Logo
131 people viewed this question
Top Craftsman Drills Experts
Gareth Cockram
Gareth Cockram
John Trevino
Are you a Craftsman Drill Expert? Answer questions, earn points and help others
