Question about Motorola Mobility TracFone w175 PayAsYouGo Cell Phone
Motorola tracfone says invalid battery, battery says full charge, yet the phone will do nothing
What does invalid battery mean in my motorola flip phone
My tracfone would do that also. Then I would turn it off and turn it back on and it would disappear. Try to do that and see if it helps.
May 18, 2017 | Motorola Cell Phones
Tracfone beeping while charging
Probably a pending message or low battery.
Mark
Motorola Support
Apr 15, 2014 | Motorola Mobility TracFone C139-4 Cellular...
Invalid battery message comes up when I turn the phone on.
I am not familiar with the TracFone V170 but most phones now communicate with the battery. They do this because the battery contains a small computer chip which monitors the charge state, temperature etc.. If this chip is faulty or missing because it is a cheap copy battery, some phones will not work properly. They usually power up okay but will not charge or will charge really slowly. There are various messages they may give including "alien battery", "Invalid Battery" to name a few. If it is unable to communicate with the battery, it will not usually charge as fast as it could because it cannot tell if the battery is overheating so it will always trickle charge an unknown battery.
You will notice a battery like this because it has at least three battery connections. Older ones only had two.
Feb 06, 2011 | Motorola Mobility TracFone® V170 Cellular...
I'm having some troubles with my Motorola Razr battery.
whenever the phone says the battery is invalid it means that the battery which is  being used by phone is not its original battery. every phone has a specific battery no. for  ex. -in nokia 6233 battery no is BP-6m. check it whether it is correct battery or due to over charging it has been blocked to avoid risk of blast. pls rate me thank you
Feb 13, 2009 | Motorola Mobility RAZR V3i Cellular Phone
My tracfone will not come on,only the lights
You'll wanna ensure your phone is totally charged. Also, let it completely drain before putting back on the charger. This will help with the charging memory.
As for the phone. Do a master reset: to do a "Master Reset". I went to "Settings," "Other Settings," "Initial Setup," "Master Reset" and put in the security code. "1234" is the security code if you have not reset yours.
It'll get the phone back to as you got out of the box, day one! Your numbers will be fine. You'll notice the ringtone and the wall paper will be the orignals.
I know this will work!
Cheers!
Feb 04, 2009 | Motorola Mobility TracFone C139-4 Cellular...
Display screen says "invalid battery" All works fine, what does that mean?
your battery may be putting off an incorrect amount of voltage to the phone, and powering it on (yes) but frying it internally (no!)
Meaning, the battery may make it work, but it is not good for the phone.
NGK
Nov 03, 2008 | Motorola Mobility TracFone® V170 Cellular...
Motorola razr2 v9
it sounds like a one in a million defective battery goto service phone tech show them your receipt and have them replace this battery
May 28, 2008 | Motorola Mobility MOTORAZR2 V9 Cellular...
"invalid battery" and wont switch on
my motorola fon L6 is invelid battery plise find my recuest
May 27, 2008 | Motorola Mobility L6 Cellular Phone
Motorola Mobility TracFone w175 PayAsYouGo Cell Phone Logo
296 people viewed this question
Top Motorola Mobility Cell Phones Experts
Rami Obeid
Level 1 Expert
D. E. Hev
Lawrence Oravetz
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
