No audio after reconnect after disconnect to move. All other functions of computer are normal. Need connection image? possible DIN plug misalignment or damage?
  • Computers & ... Master
  • 27,725 Answers
i will start with with your screen you will need a screen to fix the sound
make sure you have connected it properly and the socket is dust free
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they are probably old and faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error
if you are having problems with your sound
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps
Posted on Apr 07, 2011
Are the speaker plugs brlow rca and din plug in or out, and if its the white plug where can I get the plug for that ?
The speaker out connections are for stripped wire.
The DIN and RCA connectors are for audio IN.
The white connector is probably a power connector.
May 20, 2015 | RCA Audio Players & Recorders
The blue light keeps flashing on and off on my Seagate 4Tb XHD. It won't show up on the finder as connected. What causes that?
follow these steps:
  1. Make sure the computer and external hard drive are powered on.
  2. Safely remove the drive from the computer (if possible).
  3. Disconnect the external drive's USB or FireWire cable.
  4. Disconnect the power supply plug from the external drive.
  5. Power off the computer.
  6. Disconnect the computer's power supply cord for 60 seconds.
  7. Reconnect the computer.
  8. Power on the computer.
  9. Connect the power supply to the external drive.
  10. Connect the drive's USB or FireWire cable and check for detection.
If that does not correct the behavior, and if the drive is also not detected by your computer, the blinking light is probably a symptom of a larger problem. If those steps do not return the drive to correct function, it is very possible, even probable, that the drive has failed and needs to be replaced
Dec 22, 2014 | Seagate Computers & Internet
Lexmark X4550 Scanner not working
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer (if USB connected)> reboot your pc > unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer (if USB connected). Then try to print again once the computer fully recognizes the USB connection or when the WiFi light on the printer turns solid green (if WiFi connected.).
If that doesn't help, try the steps below:
  1. Disconnect the USB cable connecting the printer from your computer.
  2. On your computer, go to Control Panel > Printers and Faxes.
  3. Delete the Lexmark print object.
  4. Reboot computer.
  5. Re-brick your printer by pulling out the power supply - black box where the power cord is plugged into on the back of the printer, and re-plug after 30 seconds.
  6. When the printer turns on, reconnect it to the computer.
  7. Wait until your computer fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, try to print a document to verify that the problem is fixed.
Jan 05, 2012 | Lexmark X4550 Multifunction Wireless Color...
Since moving house can't get sound from PC speakers, packed, unpacked, disconnected and reconnected myself, I must have missed out a connection or connected something wrongly. Regards Stan
I suppose that you have plugged the green plug of the speakers in the green socket from the mainboard, in the back. And , of course, the speakers are still functional - try them with any other device that has a 3.5 mm plug.
Probably the audio setup was disturbed: unplug the speakers from the pc, reboot, plug in the speakers - the Audio Manager (the one that controls what and where is plugged) should open to ask you what has been plugged. If it doesn't do that unplug the speakers again and open it manually. If when you plug the speakers it doesn't sense that then the audio driver is busted - reinstall it.
Nov 09, 2009 | Acer Aspire™ T180 PC Desktop
No connection There is no computer connection.
Hello !
Give this a try;
Go to Printers and Faxes and delete your printer icon.
Disconnect the USB cable.
Restart your computer.
Reconnect the USB to your computer.
Your computer should see your printer. If it does not, move the USB cable to another port on your computer. It's also possible that your USB cable is faulty - replace the cable.
Install the printer driver.
Hope that helps.
Oct 15, 2009 | HP Office Equipment & Supplies
Wont connect to my computer
Follow the instructions below and it will work.
Disconnect the Camera from the USB port and reinstall the CD or Downloaded software program.
When the program asks you to connect the camera to the USB port, do so and it should work.
Then to use it on the Web, do this.
Web Camera’s have to be setup on the program they are to be used with. Just installing the
camera on your computer does not set it up to broadcast on messengers or Skype.
Each program has Options that have to be setup in order for the Audio and Video to function
properly.
A. Skype Setup:
After downloading and installing Skype (http://www.skype.com/intl/en-gb/download/skype/windows/beta/downloading/) set it up as follows:
1. Go to Tools, then Options, and click on Audio Settings and set the Microphone and
Speakers to the computer Audio Card.
2. Then click on the Video Settings.
3. The camera if Installed Properly will come up and show a video picture.
4. Then, on the bottom of the page click on Save.
The camera and audio should function properly. Your friends and Family will now be able to
see and her to you.
B. Yahoo Setup:
After downloading and installing Yahoo Messenger
(http://www.soft32.com/download_30.html )
1. Go to Messenger at the top left and click on it.
2. Next go down to Preferences and click on it.
3. Next Calling and Devices on the right and set the Microphone and Speakers to the
4. Next go to the Test Audio section and (in blue writing) click on “Open the call
setup assistant” and follow the instructions on the left window.
C. Windows Live Messenger:
1. After you start Windows Live Messenger, expand the view by clicking on the square on
top left next to the red X.
2. Then on the Windows Live messenger window on the right side, click on “ “Show Menus.”
And then click on “Show the Menu Bar”.
3. Next go to the Menu Bar on right side, click on “ “Action.”
4. Go to “TOOLS” and click “Audio and Video Setting” and follow the instructions.
NOTE: Your audio and video should work. Enjoy.
When done both the Audio and Video will function properly so you can chat and see family or
friends you are connected to.
D. AIM (AOL) Messenger
1. On the VIM sign-in window click on Edit.
2. Then click on Settings Enhanced IM.
3. Next click on Enhanced IM.
4. Then click on Audio Video.
5. The Audio and Video portion has drop downs so you can select the proper audio card and
video camera installed in you computer.
The Audi Video drop downs are
Microphone
Speaker
Camera
Adjust Your Audio and Video Settings:
In order to adjust your audio and video settings, please follow the steps given below:
1. Click the Audio and Video Settings button directly below the My Buddy or My Camera window.
If you are currently participating in an AOL Live Video IM session, a message will display:
You must disconnect the current AOL Live Video IM conversation before running setup. Would you
like to disconnect now? Click the Yes button.
2. The Audio and Video Tuning Wizard will appear to help you verify that your camera, speakers
and microphone are working properly. Follow the on-screen prompts.
Notes:
· The first time you use AOL Live Video IM, a message will display: Would you like to
first check your audio and video settings? Click the Yes button. The Audio and Video Tuning
Wizard will appear to help you verify that your camera, speakers and microphone are working
· images in AOL Live Video IM may appear reversed, or as a mirror image (text may
appear backwards) when you look at your own camera feed or at the picture-in-picture (PIP) display.
After making the settings your ready for a chat and video talk with your Family and Friends.
After you get your camera installed properly, DO NOT unplug it from the USB port as it will
cause the drivers to be corrupt and render the camera unusable till reinstalled it properly.
Hope this helps. Bud
Oct 13, 2009 | Logitech QuickCam Connect Webcam
Newly bought webcam is giving dark image .product spec.is E-8MPIR
Normal 0 Disconnect the Camera from the USB port and reinstall the CD or Downloaded software program. When the program asks you to connect the camera to the USB port, do so and it should work. Then to use it on the Web, do this.
Web Camera’s have to be setup on the program they are to be used with. Just installing the camera on your computer does not set it up to broadcast on messengers or Skype.
Each program has Options that have to be setup in order for the Audio and Video to function properly.
A. Skype Setup:
After downloading and installing Skype (http://www.skype.com/intl/en-gb/download/skype/windows/beta/downloading/ ) set it up as follows:
  1. Go to Tools, then Options, and click on Audio Settings and set the Microphone and Speakers to the computer Audio Card.
The camera and audio should function properly. Your friends and Family will now be able to see and her to you.
B. Yahoo Setup:
After downloading and installing Yahoo Messenger (http://www.soft32.com/download_30.html ) set it up as follows:
  3. Next Calling and Devices on the right and set the Microphone and Speakers to the computer Audio Card.
  4. Next go to the Test Audio section and (in blue writing) click on “Open the call setup assistant” and follow the instructions on the left window.
Mar 28, 2009 | Logitech QuickCam Communicate STX Personal...
Plug-ins with aim
Normal 0 . AIM (AOL) Messenger
  5. The Audio and Video portion has drop downs so you can select the proper audio card and video camera installed in you computer.
Microphone Speaker
Camera The audio and camera should function now.
Additional info to use with VIM settings.
Adjust Your Audio and Video Settings: In order to adjust your audio and video settings, please follow the steps given below:
1. Click the Audio and Video Settings button directly below the My Buddy or My Camera window. If you are currently participating in an AOL Live Video IM session, a message will display: You must disconnect the current AOL Live Video IM conversation before running setup. Would you like to disconnect now? Click the Yes button.
2. The Audio and Video Tuning Wizard will appear to help you verify that your camera, speakers and microphone are working properly. Follow the on-screen prompts.
Notes:
  • The first time you use AOL Live Video IM, a message will display: Would you like to first check your audio and video settings? Click the Yes button. The Audio and Video Tuning Wizard will appear to help you verify that your camera, speakers and microphone are working properly. Follow the on-screen prompts.
  • images in AOL Live Video IM may appear reversed, or as a mirror image (text may appear backwards) when you look at your own camera feed or at the picture-in-picture (PIP) display.
After making the settings your ready for a chat and video talk with your Family and Friends. Hope this helps. Bud
Dec 28, 2008 | Logitech QuickCam Communicate STX Personal...
Cant hear anything
Try different headphones, see if they work. Also, go into the audio settings menu, and make sure all of the audio settings are kosher.
As for the Invion...it is normal for an mp3 player to do "something" when you unplug it from computer - turn on, update, turn off when you disconnect it from computer, etc. It is not normal for you to get power ONLY when you are connected to computer. After disconnecting from computer, try turning the mp3 player back on - does it turn on? Make sure it is fully charged, of course.
If it won't turn on outside of plugging it into computer, then hold in the volume + button before you reconnect it to computer and continue holding it for 10-30 seconds after reconnecting - Windows will try to reload any missing drivers/software. If the problem persists, I would find out if your mp3 player is still in warranty, b/c it will need to be replaced.
May 14, 2008 | SanDisk Sansa c250 (2 GB) MP3 Player...
Connection using Firewire
Use a DV cable to connect the camcorder to the computer. Determine whether your computer has a 4-pin or a 6-pin DV terminal. Use an appropriate, commercially available DV cable for your computer's DV terminal. When making this connection, the use of the compact power adapter is recommended. How to connect ? 1. Turn the camcorder's POWER switch to . ? 2. Move the TAPE/CARD switch to . ? 3. Connect the computer's DV terminal and the camcorder's DV terminal with the DV cable as shown in the image below. The location of DV terminals differs between computers. For more information, please refer to the documentation that came with your computer. Important: 1. Operation may not work correctly depending on the software and the specifications/settings of your computer. 2. If the computer freezes while the camcorder is connected, disconnect and reconnect the DV cable. If the problem persists, do as follows. (1) Disconnect the DV cable, and then turn off the camcorder and the computer. (2) Turn the camcorder and the computer back on and reconnect them with the DV cable. 3. The image files saved on the hard disk drive of your computer are original data files. If you wish to edit these image files on your computer, make copies of them first, and use the copied file, retaining the original.
Sep 04, 2005 | Canon Optura 500 Mini DV Digital Camcorder
Computers & Internet Logo
26 people viewed this question
David Payne
David Payne
