Question about Kitchen Ranges
I have to turn my tub back and forth to get it to go, spin or agitate, if I don't it makes a loud buzzing, then shuts down completely for an unknown amount of time.
  • Kitchen Ranges Master
  • 2,180 Answers
There's an overload on the motor that will pop if the machine is trying to run and can't,then when the motor resets it will try to run again,it sounds like you have a bad motor,when you do get it to work does it spin and agitate normally,if so i'd say the motor is bad,if it still spins slowly you could have something locking up in the tranny. but usually a buzzing sound is the motor.how old is the machine?i mean you didn't send any info and this is under kitchen ranges so the best advice i can give to you is if the machine is old or beat up looking i would just change it out instead of putting any money into it,if it's fairly new it's your decision if you want to sink any money into it or not for a new motor
Posted on Apr 07, 2011
Agitator quit working during wash cycle. If I move timer to rinse and fill with water then move timer to spin the agitator works fine and drains water from the tub
depends on what u mean by agitator works fine on spin? it doesnt do anything on spin cycle cause its not suppose to? if ur saying ur not getting any wash agitation? then I suspect ur cam dogs inside agitator are bad? remove the 7/16 bolt nut and remove top of agitator and u will see the cam dogs underneath it. there fairly cheap like 5-10 bucks for a set, if u can push the agitator back and forth when its all together in tub, and its catching the teeth and not easy to move back in forth, their not bad, but if u have no resistance then they are bad
Feb 19, 2015 | Washing Machines
Kenmore 80 series washer won't spin just makes a loud buzzing noise.
Possible that the motor is not moving , could be a faulty capacitor to the motor. Also check for the free movement of the agitator, if the shaft is tight then it can cause a drag on the motor.
check this link:
http://www.espares.co.uk/advice/washing-machines/a/7/1401/how-to-replace-the-bearings-on-a-washing-mach.html
Jun 28, 2012 | Kenmore Washing Machines
GE Profile WPRE6100G tub spins while washing
My parent's Hotpoint did the same thing!! The brake on the bottom of the tub is not engaging! It needs replaced!!
May 15, 2012 | GE Profile WPRE6100G Top Load Washer
My 110 20862990 kenmore washer doesn't spin, the motor runs, it drains, and the coupling is in good shape. On another DIY page it asked to turn the drive side of the coupling one way to see if the...
My washer was doing the same thing. I had a magic marker on the bottom of the plastic tub below the inner tub. The agitation cam could not release for spin. I remove the magic marker and she took off.
This video shows how to get the inner tub out:
More here
More here
Sep 09, 2011 | Kenmore 24032\24036 Top Load Washer
Kenmore 80 series, model 110-2781690, won't spin or agitate. loud clicking from lower portion of machine. fills & drains ok. transmission failure?
hi,
Unfortunately, it sounds like a transmission/gearcase problem, mainly because you stated the motor would run, but would not agitate or spin.
With the motor removed from the gearcase, try to turn the coupler on the gearcase side one way for many turns, and see if your agitator moves back and forth, then turn the coupler on the gearcase the other way many turns to see if the tub starts to move
thank you,
vijay
Sep 29, 2009 | Kenmore Washing Machines
Grinding niose from agitator.
If the fill and drain functions correctly, AND the spin cycle works correctly, AND the cycle itself starts and completes correctly, the problem being that the back and forth motion of the agitator starts the loud grinding noise, it will likley be broken gears in the transmission. The single most expensive part in the washing machine.
Feb 04, 2007 | Maytag Atlantis MAV6451 Top Load Washer
Kitchen Ranges Logo
41 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
