Question about Garden
How do i replace a stop collar? - Garden
  • stran2008 Apr 13, 2011
    The stop collar is for a drill press machine. I have the parts but do not
    know how to install it.
    *Make:* Craftsman 15" Drill press w/ Laser-Trac
    *Model#:* 152.229000
  • 710 Answers
What is the stop collar for? Make and model please.
If it is for a drill or router, please reply back. I'll look up where you can get them from.
Thanks,
Handie Andie
Posted on Apr 09, 2011
  • Handie Andie
    Handie Andie Apr 13, 2011
    I haven't seen a Craftsmen drill press, but if it were like mine, you'ld have to take the quill out either from the base or take the head off and slide it off. I'd find it easier to take the base off on mine.
    Hope that helps.
    Please place a vote. Thanks,
    Handie Andie
Is there any organic made collars?
An organic collar is much more comfortable for your cat thena regular one.I myself have replaced my cat's old collar to an organic oneand I can tell you that my cat seems happier than ever.You can find organic collars, custom made organic collars,and cotton made collars in the links below.http://www.etsy.com/shop/collarswithcolorhttp://www.properpet.com/ruffinit-organic-cat.html
Jul 18, 2012 | Cats
Is there any disadvantage to a leather collar for my cat?
Cat collars must have a quick release mechanism in case they get stuck on something. Sometimes the collars have an elastic band that can easily snap if caught or you can get collars with an easy open clasp. You should not put a collar on a cat that cannot easily open for risk of strangulation.
Jul 18, 2012 | Cats
How often should I replace my cat collar?
The only times you should replaceyour cat collar is when one of these thing occur:1) Thecollar become too small and gets too tight around your cat's neck.2) Thecollar look rusty and in bad shape(visually)3) Yourkitty get really irritated by the collar
Jul 18, 2012 | Cats
Innotek shock collar
I had same problem with an Innotek Bark collar. However after my dog s barking caused shocks the first times he wore it and quickly he changed that behavior. It finally and quickly got to the point that I still used it on him but I never had batteries in it as just wearing the collar was enough to stop his annoying the neighbors. These collars do not have a long lifespan like most electronic goods.
Jul 01, 2012 | Innotek Pets - Others
Esky remote control dog collar
My Esky dog collar does not work in any mode. The first problem was when the collar would not stop beeping. Now it will turn on, but it will not beep, vibrate or shock. What do I do?
May 26, 2012 | Dogs
My dog's SmartPets 4in1 Dog Training Shock and Vibration Collar has stopped working
It seems like your batteries have run out - you can buy new batteries from here http://www.amazon.com/PetSafe-6-Volt-Lithium-Battery-Batteries/dp/B0009811TW/ref=pd_sim_petsupplies_8 The battery is very easy to change, the handset also runs on batteries but they are AA and can be purchased from your local store.
May 13, 2012 | Pets - Others
I need to replace the drivers side low beam on my 2008 subaru tribeca
The High and low beams are all in the same bulb. You have to reach in behind the light in the engine compartment and undo the retaining collar and pull it out and then pull the bulb assembly out if it separates from the collar. Unplug the bulb and replace it. I usually stop at Walmart and use the little box they have there to find the proper bulb for the vehicle, in most cases they are the less costly of the places you can get the bulbs.
Jun 24, 2011 | 2008 Subaru Tribeca
Can't find reverse on my 91 Volvo 240. 5 spd manual transmission. Something is up with the detent collar or cable ...i think?
There are screws around the rubber boot. You can remove them and pull the boot up from beneath the carpet and see what is up. The detent collar is a pretty simple mechanism. There is a plastic stop that the shifter hits, and goes past when you pull up the collar. That plastic stop may need to be loosened and re-adjusted, or perhaps there is some foreign object in there that is keeping the shifter from moving to the end of its throw when you pull the collar.
Feb 27, 2011 | 1991 Volvo 240
Garden Logo
18 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
