Question about YouTube Computers & Internet
When I click on the video is begins for a second or two then stops then starts again and stops...all the way through.
Dryer starts then stops continuously throughout cycle
That's usually a sign that the motor is beginning to go bad.
Mar 21, 2014 | Maytag Dryers
My youtube keeps cutting off and starting form the beginning on my samsung S3!
If a video doesn't play continuously (it stops and starts while you're watching), or stops early, try these troubleshooting steps:
Check your internet connection. You'll need a broadband connection with at least 500 Kbps for the best viewing experience.
Change the video quality to a lower setting to see if the video begins to load.
Pause the video, then change the quality. Allow the gray bar at the bottom of the player to load. Try playing the video again.
If the video still doesn't load, clear your browser's cache and cookies and try viewing the video again.
Nov 19, 2013 | YouTube Videos
Need to set clock on oxo timer
I also own this model, and the manual isn't availble on OXO's site. But this is what I've learned over the years:
To set clock:
  1. Press and hold clock/timer button for 3 seconds (clock icon will appear on left side of screen).
  2. Input time using keypad then quickly press clock/timer button to save.
To set timer:
  1. Press and release clock/timer button.
  2. If necessary, press clear/memory so timer reads all zeroes.
  3. Enter desired time using keypad (to a maximum of 99hrs:99mins:99secs).
  4. Press stop/start to begin countdown.
  5. Pause countdown by pressing stop/start; resume by pressing button again.
  6. When countdown is complete, timer will beep continuously for 30 seconds and display will flash. Timer will then beep every 10 seconds for 10 minutes until the stop/start button is pressed.
  7. Press clock/timer button to return to clock function.
To time activities:
  3. Press stop/start and plus (+) sign will appear on right side of screen as timer begins counting up.
  4. Pause count-up by pressing stop/start; resume by pressing button again.
  5. When you're finished timing, press stop/start to end timing function.
  6. Press clock/timer to return to clock function.
Sep 30, 2013 | Oxo Good Grips Digital Stainless Steel...
How do you set the clock for a 1061978 oxo timer
This is the only timer model OXO doesn't provide for download on their site. But I also own this timer, and this is what I've learned:
To set clock:
To set timer:
To time activities:
Sep 15, 2013 | Oxo Hardware & Accessories
Oxo digital single timer set clock
I'm assuming that you're referring to OXO's model #1061978 and it's the only timer manual not available on their website. But I also own one, and this is what I've learned:
To set clock:
To set timer:
To time activities:
Mar 26, 2013 | Oxo Hardware & Accessories
Need manual for oxo #1061978 timer
I own this model also and OXO doesn't offer the manual online. So here's what I've learned to do:
To set clock:
To set timer:
To time activities:
Mar 07, 2013 | Oxo Hardware & Accessories
Instructions for oxo model 1061978
To set clock:
To set timer:
To time activities:
Feb 17, 2013 | Oxo Hardware & Accessories
Hello... Since this morning i have the same problem :((. My benQ FP73G won't start. The function led just starts for a second(turns green) and then nothing happens...
If your VGA connector is connected to a video card put it in your onboard VGA connector if the problem is still there. Remove the video card from your motherboard then boot on safe mode then adjust your video resolution. Here are some steps on how to boot in safe mode on your computer.
  • Turn on your computer.
  • Start tapping the F8 key. The Windows Advanced Options Menu appears. If you begin tapping the F8 key too soon, some computers display a "keyboard error" message. To resolve this, restart the computer and try again.
  • Ensure that the Safe mode option is selected.
  • Press Enter. The computer then begins to start in Safe mode.
  • Right click on the desktop then click setting then adjust the resolution on lower resolution. The normal resolution for VGA is 640X480. Then click apply and restart the computer and in normal.
Hope this solve your problem.
Jul 29, 2011 | BenQ FP73G 17 inch LCD Monitor
No picture on my philips 42PF7321D/37
Bad caps in the power supply must be replaced .
Jul 21, 2009 | Philips 42PF7320A 42 in. Plasma HDTV
Brand new Dryer starts then stops after 15 seconds
Stop what you are doing. It is under warranty. This will be more costs and it is not necessary. It is a mfr problem.
Feb 08, 2009 | Frigidaire Affinity 5.8 Cu. Ft. Electric...
Computers & Internet Logo
Top YouTube Computers & Internet Experts
Rizwan Hanif
Level 1 Expert
Michael Terence...
Michael Terence...
Are you a YouTube Computer and Internet Expert? Answer questions, earn points and help others
