Question about Whirlpool Washing Machines
Our washer will not re-start after canceling a running job. It simply powers off whenever we push the start button.
  • jjhamblin Apr 08, 2011
    Its a whirlpool duet
    model number WfW8300SW04
    Is there a reset option that could reset the control?
    Neither option worked. I still powers off when I hit the start button..
  • Whirlpool Master
  • 1,902 Answers
Hello & Welcome to FixYa
The problem seems to be with the control board or the motor assembly that's bad and needs replacement. If you want more help tell me the make and model of the washer. Please get back to me if you have any other questions.
Kevin
Posted on Apr 08, 2011
  • Kevin White
    Kevin White Apr 08, 2011
    Press and hold the end of cycle/cycle signal button for 15 seconds to reset the control. If the problem returns then open the bottom front access panel and clean the drain filter assembly completely to solve this problem
  • Kevin White
    You can test the door switch with a voltmeter before replacing the control board.
Washer states sensing with a buzz sound?
Hello keisha, thank you for your post!
I understand that your Frigidaire washer is making a buzzing sound until the cancel or start button has been pushed. It sounds like it could be a possible issue within the door either not being fully closed or it could be a defective switch. I would recommend resetting your appliance which can be done by disconnecting power to the appliance for roughly ten minutes. Please comment back if that did not help correct the issue. -Matt
Sep 05, 2014 | Frigidaire Affinity ATF7000E Front Load...
Washer start to run water the it just stop
If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Feb 20, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
My frigidaire dishwasher model #fghd2433kf1
It is in a delay wash mode.
Disconnect power for 60 seconds.
Re-connect power.
Press the Cancel button.
Press the regular wash cycle and start the dw.
Jul 17, 2010 | Frigidaire Dishwashers
Hi I have a whirlpool front load washer model number ghw9100lw my problem is that i am getting a f05 code i have changed the temp sensor and i am getting the same code i have unplugged the washer now when...
Check and replace
- Flowmeter.
- Water inlet valve
Make sure to unplug power cord before you replace the part and also make to clean drain tube and filter every year.
Jun 29, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Cancelled a job and it stays in queue
Cancel all the documents in the print queue, (just do it whether they are actually deleted or not), press "cancel" on button the printer and restart your system and also the printer. If possible, please leave the printer switched off for few minutes and don't forget to use the "Power" button to turn if off or on. This will help your printer to restart new print job, all the jobs on the print queue will be deleted/cleared. Good luck, Thanks for using FixYa.
Jun 08, 2010 | HP DeskJet 5550 InkJet Printer
Can't get washer to start again after pushing pause/cancel button
sounds like central control unit problem, you can check for diagnostic mode operation by setting (door closed) drain/spin, no spin, pressing prewash 4 times in 5 secs pressing prewash again will advance through diagnostic cycle. replacing user interface may also be necessary
Apr 25, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Power out when running. showed code F 71 now not working.
After power outage that will happen do this to fix.
Select PAUSE/CANCEL twice to cancel the cycle. Select
DRAIN & SPIN if there is excessive water in the washer.
Re-select cycle and press START. If the problem remains, call
for service.
Dec 17, 2008 | Kenmore Elite 45986 Front Load Washer
Washer power
Sounds like you have a stuck or shorted keypad. I've seen this a lot on this model. Solution is to replace the keypad. Catriver.
Aug 04, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Kenmore Front Loader stuck in "LOC" and every button produces "ERR"
Look for the 2 buttons on your that have a lock symbol.  Pushing & hold both for 3 seconds.  This toggles the child proof mode.
Nov 20, 2006 | Fisher and Paykel Fisher Paykel Intuitive...
Washing Machines Logo
Dan Webster
Dan Webster
Sal De
