Question about Linksys Wireless-G WRT54GS Router (e125894)
How to setup security on linksy router go to 192.168.1.1 ask for username and password nothing works
First, be sure that 192.168.1.1 is in fact the address of your router. Follow the following steps to confirm this information in windows.
1) Press the Windows key and "R" key simultaneously
2) Type "cmd" and press enter
3) Type "ipconfig" into the command prompt
4) The ip address following the label "Default Gateway" is the ip you should be entering into your web browser in order to access the router.
The default password for this model router is "admin" while the username is "admin". If these credentials do not allow you access to the router, someone has changed these settings without your knowledge.
Posted on Apr 07, 2011
How do i set a password for it or secure it
My friend,
You have to lo-gin into the router setup page .
1.Put this address (192.168.1.1) in the address bar and then you will see the router setup page.
2.Then this will ask you for the username and password.
3.Username is nothing so leave this blank and password is admin.
4.Then you will see the router setup page .
5.Click on the wireless Tab near the basic wireless settings you will see wireless security .
6.Click on the wireless security and you will see there your router wireless security mode.
7.Always select Security Mode as WPA2 PERSONAL.
8.Enter the key which you want to setup.
9.After changing the settings Click on the save settings.
Regards:-
Amit Awasthi
Dec 09, 2010 | Linksys Wireless-G Broadband Router
HOW TO SET WIRLESS PASSWORD ??
>first, access your linksys' default gateway by typing 192.168.1.1 on you browser's address bar
>Graphical User Interface (GUI) will be accessed
>Now it will ask you to login by default the Linksys routers uses either "admin" as username and "password" as the password or leave the username blank and type "admin" as password. Not unless you have setup a logon security for your router's configuration. After logging into the router's configuration, go to SECURITY tab, if your wireless connection does ask for a username and password for you to connect then you need to ask your Internet Service Provider (ISP) what type of security is compatible with your service will it be WEP,WEP Shared, WPA2 etc...
Now, if you select WEP the password is plainly a 10-digit code, if it's other than WEP then the wireless password has to be a 16-digit Alpha-Numeric code...
Sep 14, 2010 | Linksys Wireless-G WRT54G Router
I can connect to the internet with my lap top trough my Linksys Router WRT54G because every time i try to connect is asking fo a security code number
Hi
On your wired computer, opened internet explorer and type 192.168.1.1 or 192.168.0.1 then press enter.
It will ask you for a Username and password, type admin on the username and type your Administrator password on the password field (default password is admin).
Then you will be directed to a setup page, go to the wireless teb then click on the wireless security tab. You will see your password there .
Hope I was able to help.
Sep 12, 2010 | Linksys Wireless-G WRT54G Router
I have a Linksys wireless 2.4 Ghz Broadband router. I have a secure wireless network set up, but it has a red x through it, and defaults to an unsecured wireless network. How do I fix this?
Access the router setup page from the working computer you can do this by typing 192.168.1.1 on the address bar of your internet explorer and that will ask you for a username and password leave the username blank and password is admin if admin did not work type your commonly use password, Once you're on the setup page you can go to Wireless tab and then Wireless security and there enable the security that you want to use......
Nov 11, 2009 | Linksys Wireless-G Broadband Router
How do i set up a secure network
Hi! you can setup a secure wireless network by accessing the linksys setup page and go to wireless setting, it will ask u what kind of security settings, like, wep, wpa, wpa, use the wpa2 and tkip then set the password, change also the router username and password so that no one can access ur wireless router setup page, only u..
Aug 08, 2009 | Linksys Wireless-G WRT54G Router
Forgot security key/passprease
the security passkey or passphrase will be found on the router user interface. if you are also using a linksys wireless router...you can try this out..
1. open internet explorer...type 192.168.1.1 on the address bar and hit enter.
2. it will ask you for a password, default username and password for a linksys router is username - nothing, password - admin.
3. go to the wireless settings tab and wireless security tab then look for the password.
Oct 08, 2008 | Linksys (WMP54GS) 802.11g/b Wireless...
Wireless router hookup...
You need to use a working computer with the router then access the router setup page that way you can get the wireless security key, then follow this step:
Open a web browser like internet explorer or Netscape. Enter the ip address of your router in the address bar of your browser. In the picture above the address bar has http://www.google.com in it. Just replace all of that with the ip address of your router. By default the ip address should be set to 192.168.1.1
You should see a box prompting you for your username and password. Enter your username and password now. By default the username is blank, and the password is admin. Click the Ok button to log in to your router.
When you're already on the Linksys router setup page, click on Wireless tab and look for a sub tab that says Wireless security and there you can find the security key that you're looking for..
Hope that helps..Don't forget to rate the solution FIXYA thank you...
Oct 04, 2008 | Linksys Wireless-G WRT54G Router
Passphrase
Since you forgot the security ket for the wireless network you need to access the router setup page using the a computer that is working fine with the router,
On the internet exploreer address bar of the working computer type in 192.168.1.1 , then that should be asking you for a username and password, just leave the username blank and password is admin. If tha admin password didn't work try typing your commonly use password.
If you're already on the setup page of the router, Just go to wireless tab then there's a wireless security sub tab there where you can find the security key that you need...
Hope that helps...........
Sep 07, 2008 | Linksys Wireless-G Broadband Router
Security
Hi!
You may follow this article to secure your wireless network.
Before following the article, open your browser first and type in 192.168.1.1 on your address bar and hit Enter. You will then be asked for a username and password. Default login (no username) for your router is admin. If it doesn't work, use the password you've used when you've ran the router setup CD.
Just reply if you have any questions.
Jul 06, 2008 | Linksys Wireless-N WRT150N Router
Linksys Wireless-G WRT54GS Router (e125894) Logo
49 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
