Question about Onkyo TX-8511 Receiver
I have an Onkyo TX-8511 and 1 speaker is louder than the other I replaced the stero wires / new ones, switched from "A" speaker bank to "B" speaker bank,and made sure of my settings. What could be the cause? I also hooked it to my TV and the sound seems like it monotoned! HELP!
  • 760 Answers
Check your right and left balance. Make sure they are equal
Posted on Apr 07, 2011
My speaker "B" channel has gone out. Is this an
Maybe I'm misunderstanding the problem...
One speaker? Why would you have one speaker attached to A or B? A and B represent speaker pairs and are driven by the same two amps.
It's also not clear if you're saying the speaker is failing or the channel. You CAN swap them to find out.
Either way, the amps are common to both speaker pair connections so if only the B pair isn't working at worst you have a switch problem.
Jul 01, 2011 | Onkyo TX-8511 Receiver
My receiver is in protect mode..what does that mean
See reasons for protect mode on onkyo site.
Most likely the speaker wires are shorting or are reverse polarity. see connection diagram.
Jan 19, 2011 | Onkyo TX-8511 Receiver
Hi, I have a TX-8511 Onkyo. The left channel is silent. It's not the speakers or the wiring - checked and swapped. Using 8 ohm speakers and switch is set to 8 ohms. Does the same thing on both A & B -...
hello 1 of the transistor could be dry jointed if joint ok then you may a leak on the transistor also check the capacitor around the transistor for bulging all the best
regards
shaun
Sep 13, 2010 | Onkyo TX-SV373 Receiver
How do I connect my Samsung Model un46b8000xf led to onkyo receiv
Use the TOSLINK - the optical/digital connector on both devices.
Jul 07, 2010 | Onkyo TX-8511 Receiver
I must have hit some buttons on the remote unintentionally - all of a sudden I lost the sound out of the left speakers on my Onkyo TX-8511
Reverse left and right speakers at back of unit
to verify if a speaker/wire problem. Also check
all functions for same problem!
Jan 30, 2010 | Onkyo TX-8511 Receiver
My TX-SV 424 showes a protect sign what shoud i do.
PROTECT SIGN MOSTLY HAPPENS WHEN THE INTERNAL OUTPUT IC IS SHORTING, OR THE OTHER REASON COULD BE, THE SPEAKER WIRES ARE CROSSED TOUCHING EACH OTHER, THIRD AND LAST OPTION IS SPEAKERS, TRY TO TAKE ALL SPEAKERS OUT THEN PLUG IT ONE BY ONE....RESULTS WILL BE OUT, IF NONE OF SPEAKERS ARE DEFECTIVE THEN ITS YOUR OUTPUT IC SHOULD BE CHANGED AACCORDING TO THE SAME TYPE AND NUMBER
Oct 14, 2009 | Onkyo TX-8511 Receiver
I just hooked up my old Onkyo TX-8511 receiver to my bose speakers, which is also hooked up to a subwolfer. When I turn the volume up the system goes into protect mode. Any solutions.
Just check your speaker cabling again. Make sure that all of them are seated properly, none is touching each other or the body of receiver. Rewire if necessary..
Are you using banana plugs for connecting speaker or just directly. Some times even a little tiny wire touching the receiver could trigger the protect mode. Be careful, since protect mode is sometimes not fast enough and it could blown a few trasistors in the power circuit.
Otherwise, do your bose speakers play out load on other systems?
Mar 08, 2009 | Onkyo TX-8511 Receiver
Powered Or Unpowered Subwoofers For Onkyo TX-8511
Greg- Powered subs are better than non-powered subs (also known as passive subs), anyway I see the TX-8511 has no sub pre-out on the back panel, so you need to decide what sub you will use and run from the receivers left and right speakers output into a subwoofers speaker in from speakers then back out to speakers, look at the back of a subwoofer and you will see like 4 sets of speaker hookups 2 in and 2 out, what this does is takes the low end or bass and drops the signal to the subwoofer then takes the mids and highs out to your left and right speakers, unless your regular left and right stereo speakers have large woofers a sub is the way to go.
Jan 28, 2009 | Onkyo TX-8511 Receiver
Connecting a subwoofer
There are numerous systems that would be compatible with your system. Consult your dealer where you bought your RCVR..accordianman
Jan 14, 2008 | Onkyo TX-8511 Receiver
Onkyo TX-8511 Receiver Logo
205 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
