Question about Kenmore 63942 Dryer
Need download manuel for kenmore dryer model 86860100,no heat
SOURCE: Kenmore dryer (electric )
NOT ELITE HE4..... Model 96595400. Replaced thermistor and Hi-Limit Stat. Probably the thermistor.
Posted on Jun 29, 2008
SOURCE: where is heaing element located on kenmore dryer
http://www.davesrepair.com/DIYhelp/DIYreplacingWPLdryels.htm
Posted on Mar 30, 2009
  • 68 Answers
SOURCE: Kenmore gas dryer model #76812690 will not heat.
does the dryer heat initially when you first turn on the dryer Or no heat at all?
the first thing i would check is tthe thermal fuse thats located on the back of the unit. test it with a multimeter and see if it has continuity, if it doesnt then replace that and your operating thermostat. the check to be sure you venting to the outside of your house is not clogged
Posted on Apr 29, 2009
vickygomar
  • 460 Answers
SOURCE: kenmore dryer will not dry completelt in even heat cycle
This video will help you to determined what you need,
copy n paste
http://www.youtube.com/watch?v=HRKIU4LiS20&feature=related
for parts n prices
http://www.partselect.com/AppliancePartList.aspx?Brand=Kenmore&Appliance=Dryer&ModelNum=&Type=Electrical%20Parts,%20%20No%20Heating%20Elements&MinSize=U&MaxSize=U&Electrical=Y&Metal=U&Plastic=U&OneColor=U&PageSize=15&FirstPart=1
Was this helpful?
Posted on May 13, 2009
  • 4088 Answers
SOURCE: kenmore dryer model number 110.66912691 not heating.
Check the house electrical panel for tripped dryer-circuit breaker-pair. Push off, then on. If immediately re-trips, the dryer has a dead short circuit in it. If they hold, then retry the dryer. If it now works, ok! If not, recheck the breakers as above. If tripped again, there is a likely short in the dryer's heater assembly. The drum must be removed to access the heater.
Posted on Aug 24, 2009
I have a old kenmore dryer and it won't dry my clothes, if the rubber gasket around the door is gone will this prevent drying? Thank you Gloria
That could be the problem or if it doesn't heat up at all it's probably the heating element in it. Any local appliance supplier should have either part part in stock or look up the model online and you can order one. Replacing them is pretty easy.
Apr 08, 2017 | Kenmore Dryers
Kenmore electric dryer model number 86860100
door latch kit 279570. repairclinic.com has picture of it
Oct 13, 2013 | Dryers
How to hook up kenmore gas dryer model# 76512
You may download a copy of the owner's manual and installation instructions at http://c.searspartsdirect.com/mmh/lis_pdf/OWNM/L0705194.pdf
Dec 08, 2011 | Kenmore Dryers
Need Manuel
Go to managemylife.com and enter your model number under the "MANUALS" link. You owner's manual is available in .pdf format and can be downloaded or printed for FREE. If you need further assistance, please post back with your complete MODEL NUMBER and let me know. I hope you find this information helpful.
Oct 08, 2010 | Kenmore 88752 Top Load Stacked Washer /...
Need to replace the heat element for my Dryer Kemore
sorry couldnt find your modle number, but kenmore dryers are enerally whirlpools in which case are easy to replace. the harder issue is determining if this is your problem.I would assume your guessing on a bad heater, only for the face that if you truly did check hte heater, you would find how to remove it( a few screws will release it from its mounting. A simple check with a Meter will determine if indeed it has gone bad. A more likely source or just as common cause of no heat would be a blown thermal fuse, or a bad high limit thermostat, all can be checked for continuity with a meter
Jan 20, 2009 | Kenmore Dryers
Kenmore dryer doesnt heat
Nothing you did wrong! Probably needs a new heating element. Prices vary by model. Call Sears/Kenmore parts center nearest you. Tell 'em you need a heat element for your dryer. Be sure to provide your dryer's model number.
Unplug your appliance first before attempting repairs! Safety first and always!
Dec 19, 2008 | Kenmore Dryers
Model 11060052991 kenmore elite dryer
For heat issue I had replaced the heat relay switch a year ago and that worked. For the start button holding issue I replaced the motor relay switch and the dryer is fine again.
Nov 25, 2007 | Kenmore 63942 Dryer
Kenmore 63942 Dryer Logo
48 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
