Question about OKI Electric Industry C8800DN Printer
131 fatal error - OKI Electric Industry C8800DN Printer
OKI C830 Error code 131
This is an error for the yellow LED head. Check the connection. If you feel confident enough try moving the LED heads around. If the error moves with the LED head then it needs to be replaced. If the same error occurs the the CU pcb need to be replaced.
Apr 07, 2014 | Oki Electric Industry C830DN Led Printer
How do i fix error 131 on oki printer
Please confirm the model and error code. I have checked the technical manual for the B410d and there is no reference to error 131.
Apr 07, 2014 | Oki Electric Industry B410D Laser 30PPM...
Iterra elite II printer showing fatal error 131 code error
Error Code: -131, ErrorMessage: Connection to license server failed; if license server address is invalid, correct it; if TAO NT naming service stopped, activate it and restart License Manager
I was sure that all SAP B1, and MS SQL services are up, and running on the server side so I knew this is an issue related to the client side.
The solution was checking the file "b1-local-machine" which is located it under "C:\program files\SAP\SAP Business One DI API\Conf"
The value of the server ip was "localhost", and it should be the ip of my production server instead.
Hope that was helpful.
for more hrlp visit CBR Tech Solutions
Feb 04, 2014 | Elite Office Equipment & Supplies
131 fatal error
131 code
LED Head Error
131= Yellow Head
Jan 30, 2014 | Xante Ilumina Digital Color Press Printer
Hardware Error +0137 +131 ---
This is a jam error. This error may come if the rod is jam or carrage motor is not working properly.
Oct 02, 2013 | TallyGenicom 2265+ Matrix Printer
Xante ilumina I have an error code 134:fatal error , please help!!!!
LED Head Error
131 = Y Head 132 = M Head 133 = C Head 134 = K Head
Sep 21, 2012 | Xante Ilumina Digital Color Press Printer
How do i fix a 131 fatal error?
FATAL ERROR 131, 132, 133 OR 134 ON THE DISPLAY ON POWER-UP
CAUSE - ONE OF THE LED PRINT HEADS IS DISCONNECTED
SOLUTION - RECONNECT THE RIBBON CABLE TO THE PRINT HEAD
Just for information, the led print heads are the four assemblies that hang down from the lid of the machine when you open it.
Sometimes they become unclipped, and the ribbon cables can get pulled loose.
131 probably means the front one.
Mar 04, 2011 | Office Equipment & Supplies
Iterra elite starts with fetal error 177 after initialization. What is meant by Fetal arror #177
i have a isys iterra elite II printer showing a fatal errror:131 pls wat does it mean
Dec 09, 2010 | Office Equipment & Supplies
OKI C5600 printer is printing Blank pages
you looking at 3 posibles one is the scanner may need to be replace or the low voltage power supply or you looking at a posible drum problem
Nov 22, 2008 | Ricoh Aficio 250 Copier
Error code 131
Call the guy who replaced the motor/ module. Error 131 is serious. Not for home repair.
Sep 06, 2006 | Fisher and Paykel Fisher Paykel Intuitive...
OKI Electric Industry C8800DN Printer Logo
952 people viewed this question
Top OKI Office Equipment & Supplies Experts
Jimbras
Level 1 Expert
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
