Question about Pioneer PL-990 Turntable
It needs a new belt - Pioneer PL-990 Turntable
Http://www.turntableneedles.com/Flat-Belt-Medium-236-Inch_p_255.html
Pioneer PL-990 is listed as a compatible player for this belt.
Posted on Apr 07, 2011
The belt stop while running by itself and if I step off it starts again
That belt needs to be adjusted so it does not slip under load.
Sep 02, 2015 | Reebok 8050 ES Treadmill
Why do i need to change cam belt and tensioner at the same time? is it a must
yes a new belt should have a new tension other wise they cant guarantee the belt will last another 90k miles because in the old tensioner loosing tension and possibly damaging the new belt
Aug 08, 2014 | 2002 Audi A4
Replace fan belts
When replacing fan belts, route the new belt through the pulleys so that it uses the exact same path as the old belt. You may need to loosen the belt tensioner a little bit more in order to slip the new belt onto the final pulley.-------------------------------------------------------------------------
New UPA USB Programmer
Apr 20, 2013 | Cars & Trucks
There are two belts. How do i put the new ac belt on. The new serpentine is on. But there is no tensioner for the ac belt.
the a/c belt is not held taut with a tensioner, you need to loosen the compressor and pry it one way or the other until you get enough slack to remove the old belt and and slide the new one on, to retighten the belt you may need a pry bar of some type ( tire tool, long screwdriver )
Jan 10, 2011 | 1996 Dodge Caravan
New Serpentine Belt Causes Squeeling. Added gobs of belt dressing, still squeels. Old belt was only half a belt--totally worn out. New belt is therefore tighter and putting more force on pulleys. Do I...
Take off the new belt ... toss it ... get a new belt ... before you put it on ... clean all the pulleys twice ... final cleaning should be alcohol.
Oct 27, 2010 | 2003 Mini Cooper
Fit new drive belt to tumble dryer
I need to know more. like how to instal belt or how to find what belt fits your dryer . need more info like mod # there 5 different belts for hotpoint . and several different ways to install them so model # ______________ needed . **** . pls .
Jan 02, 2010 | Dryers
I need to put a new belt so the water pump can work. do i have to take everything apart? how you pull out the pulley so you can put a new one? cadillac el dorado 1995
Sounds like you have the Northstar engine yes?...if so...you won't need to dismantle anything other than the water pump belt cover. You can then put the new belt on by levering the small belt tensioner.
Pulley's do not need to be removed, simply position the belt around the three pulley's.
Jan 01, 2010 | 1995 Cadillac Eldorado
Fitting a new fan belt
Remove the fan shroud cover and draw the fan belts route, loosen the aircon tensioner bolts x 3 on the left side of the cover and remove the aircon belt.With a 15 mm socket on a power wrench pull the auto tensioner to the rightand remove the belt , with a little skill and patience you can get the old belt off and the new one on over the fan blades without removing the fan.Make sure the belt is on properly to prevent it coming off when starting.
Nov 08, 2008 | 1996 Land Rover Discovery
Setting the timing belt A new timing belt was put on but the timing was not set correctly. Do I need a new belt entirely or just need to get the timing reset???
you do not need a new belt seeing it was replaced, setting the timing should solve the problem,however this is something that should be done by a good mechanic.
Aug 27, 2008 | 1999 Dodge Intrepid
Pioneer PL-990 Turntable Logo
135 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
T-Comtech Repairs
T-Comtech Repairs
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
