I removed from my computer my USB 2.0 1GB Medion Stick, without rejecting it. Now I cannot open the Locked Protected file. What should I do?
  • 27,725 Answers
Click start control panel administrive tools computer management device manager scroll down universal serial bus controllers you should see a yellow question mark?
right click to reinstall drivers
if you can see your usb drive but its not working
ports(com&lpt)right click update driver
another thing you could try is to control panel administrive tools computer management disk management right click on your drive select properties tools computer management disc management if you can see your usb drive right click select properties tools check now tick in both boxes to scan for and repair/recover any bad sectors and automaticall fix any corrupt files
or you might tick in one box wait until it has finished then return at tick the other box
USB drives can be write-protected by modifying the StoreageDevicePolicies Registry key and WriteProtect Registry value.
click Start>run>regedit to open Registry Editor. and press control+F to open the find dialogue box and type "usb device" or "driverdesc" to open usb mass storage device or type "usb mass storage device" in the search windows. And right click on it and delete. This will set the policy value to 0. then insert your usb device. It will work fine.
# Remember: do not delete any unknow files in the registry as this will make some programes not work as usual.
also
If you are running a Windows XP OS then you might be able to:
- click start right click on my computer select open
- Right click the icon of your Flash Drive (It should be F:/ or something)
- Click Properties in the menu that comes up
- Click the Sharing tab
- Click permissions
- And finally, click Allow next to Full Control.
hope this helps
Posted on Apr 07, 2011
How to remove write protection from sony memory stick pro duo
There should be a small plastic catch on the side of the card which allows you to write protect the memory stick pro duo. It should have an image of a lock or say locked next to it, if it is locked you won't be able to write to it. Slide it to the unlocked position using a fingernail or a paperclip.
Apr 29, 2015 | Sony Electronics - Others
I have a small red Vernatin USB memory stick and forgot my pass word ! what can I do to get back the content ?
Always backup your files from the USB flash drive to a computer, since these removable drives will always either break, get lost, or get stolen. Sometimes a flash drive will prompt you for a password and there will be an option for giving a HINT. Click on this option and see if you left a hint on the drive. Passwords are there to prevent theives from stealing your personal information and data. There are supposedly applications that can read protected files without the password, do a search on the Internet for one of these.
Feb 28, 2013 | Verbatim CORPORATION 94933 USB 2.1GB...
Sir My system D drive and E drive folders are locked with usb lock ap, unfortunately I format C:drive and installed windows xp. So D drive and E drive usb lock ap folders are not opened. present i...
You need to ask for experts on this - if the drive is copy protected or locked.
Then bring the drive to expert servicemen to open it up to recover you files
Mar 07, 2011 | Advanced Systems USB Lock RP
Hii sir pls help me mine kingstone data traveler 2gb is write protected so how shall i remove write protected?
Copy all the files onto your 'C:' drive.
Spend $9 to buy a new 2GB USB memory-stick.
Copy the files to the new memory-stick.
Take a sledge-hammer to the old memory-stick -- to prevent anybody else from reading your files.
Oct 26, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
When ever i try to copy a file on to my pendrive ,a file pops up saying that it is a write protected drive .how am i to remove this write protection?
try this one, hope it will work on your memory stick coz i tried this and i was able to format my write protected memory stick smile.gif
use a computer with XP OS.
right click 'my computer'
select 'manage'
then select 'disk management' to format ur memory stick. but sad to say, all data will be lost, am pretty sure you know it
Jun 10, 2010 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
My memory stick is write protected...i cant add/delete files.
CHECK if it is not physically protected, a small button/switch might be on the stick!
THEN, try any other flash drive or memmory stick to locate the target problem (memorry stick, or usb port mulfunction or even security/driver issue).
PLUS, there are some programes that might protect flash drives, check if u have any, and uninstall them, and make sure u have deleted ther HIDDEN system files located on the stick!
gd luck.
Jan 01, 2010 | Electronics - Others
Write Protected USB
hi Not only your pendirve your computer system is also affected by virus . please check your pendrive with any other computer .before you connected open your pendrive format your pendrive with any other computer. if it will not work you have go for any new pendirve. bye
Jun 16, 2009 | Disney High School Musical Mix Stick 2.0...
How to remove write protect on my usb flash drive
On USB stick, there is a "Lock/Unlock" slide bar on the opposite end of USB port. It uses the symbols of a "lock" and an "open hasp lock" to show that the device is "locked" (write-protected) or "unlocked" or not write-protected. remove the lock
Oct 08, 2008 | Computers & Internet
USB Write Protection Hi, I am trying to copy/delet files from/to a USB stick. window says: " The disk cannot be written to because it is write protected. Please remove the write protection from volume USB...
As you said that there is no switch to lock and unlock usb stick so if this is the case than download the file below
Use the Registry Hack to Disable Writing to USB Drives
Here is the link .just download the zip folder and after opening the folder you will find a file just double click on it..
This will solve the write protect error definitely
Low feed backs hurt my ratings and I tried my level best to resolve the issue. so show your appreciation by rating it.
Thanks for using fixya support..You have a wonderful day
Mar 21, 2008 | iLO (2 GB) MP3 Player
HOW TO FORMAT A WRITE PROTECT USB DRIVE
MY KINGSTON DATA TRAVELER SAY WRITE PROTECTED HOW CAN I FORMAT IT CAUSE WHEN I FORMAT IT DIRECTLY IT SAY DEVICE IS WRITE PROTECTED BUT MY USB DEVICE DOES NOT HAVE THAT KIND OF SPECIFICATION TO HAVE A WRITE PROTECT DISK.
I had same problem. I fix it with suggestion of 1st guest. I download program from site http://www.apacer.com/en/support/downloads/Repair_v2.9.1.1.zip, and program formated USB and he work fine now. TY for advice.
Jan 10, 2008 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Computers & Internet Logo
42 people viewed this question
David Payne
David Payne
