Question about Bosch SHU9915UC Dishwasher
Wont drain when hose connected above 2foot drains into bowl on floor ok
  • 822 Answers
Ya pump or drain by pump. is blocked..................
cheers
Posted on Apr 07, 2011
Washer door is locked and wont open.
Take the drain hose, put a bowl on the floor and drain the remainder of water out
Sep 19, 2013 | Elna Heirloom Edition 6005
Kitchenaid dishwasher wont drain
Allow the current cycle to complete. Draining will occur at the end of the cycle.
Close and latch the door. The dishwasher will not drain if the door is not properly secured.
Press the "Cancel/Drain" button on the dishwasher to start a two-minute drain cycle.
Remove the knockout plug in the disposer outlet of the garbage disposal if the dishwasher drains into the disposal. Turn off the water supply and remove the drain hose from the disposal. Place the tip of a screwdriver on the plug and tap it lightly with a hammer to remove it. Replace the drain hose and turn the water supply on.
Clogged Drain
5
Run the garbage disposal to empty it and clear the drain if the dishwasher drains into the disposal.
6
Remove the cover on the air gap on the sink or countertop. Turn the plastic cap counterclockwise to remove it. Remove soil from the inside of the air gap. Replace the plastic cap and cover.
7
Check the sink. Dishwashers connected to a sink will not drain if the sink drain is clogged. Unclog the sink. Contact a plumber, if needed.
Issues With the Drain Hose
8
Check to see if there is a loop in the drain hose. The loop cannot be more than 20 inches above the floor. Disconnect the hose and loop it just above the floor. Reconnect the drain hose.
9
Remove kinks in the drain hose. Always use the new drain hose included with the dishwasher. Do not reuse old hoses.
10
Check the length of the drain hose. The hose should be less than 12 feet long. Replace with a shorter hose, if needed.
Sep 01, 2012 | KitchenAid KAWS850LE Top Load Washer
Bike wont start
Dead fuel in the float bowls, turn fuel tap off get a piece of thin hose connect to the drain fitting on the float bowl release drain screw on the bottom of the carbs drain each carb, top gas up with good fuel turn tap on and your off.
Jan 27, 2012 | 1996 Yamaha YZF 750 R
My dishwasher won't empty
This condition is commonly caused by:
- Drain pump jammed
When you wash your clothes, any small objects (e.g. hair pins, coins etc) are flushed down the drain pipe but often get jammed in the drain pumps impellar (this is the tiny propeller on the pump).
Firstly, place a bucket on the floor....then lower your drain hose (from your tub) into the bucket - the gravity will naturally drain the water into the bucket. Be careful to raise the hose and empty the bucket each time, until the machine is empty. Remove any wet clothes from machine (you will need the bowl to be emptied).
Once empty, you can now check the drain pump.
Turn the machin off at the power.
Locate the drain pump cover (usually near the drain hose, on the back or side). Place a large towel on the floor beneath the pump cover (as remaining water will escape onto the floor). Unscrew the drain pump cover and allow the water to drain (if your pump cover contains a filter, then clean everything from this filter).
Then, look inside the drain pump cavity for anything obstructing the little propeller (remove any objects). Insert your finger inside the cavity and rotate the little propeller - you should feel a resistance, similar to a rubber band.
Re-install the drain pump cover (or filter) and ensure it is sealed properly. Turn ON at the wall.
Fill your bucket with water (from tub) and pour into your machine.
Turn machine ON, and select the last SPIN (or drain) cycle and check if machine now drains correctly. If ok, then problem now solved and you can put the clothes back into the machine for a final rinse/spin.
If machine still not draining after inspecting the drain pump, then you may have a suspected faulty drain pump - a technician can run a diagnostic process on your machine's control pad to find the diagnostic codes.
Please do let me know, if the above process helps you solve this.
Cheers,
Oct 02, 2011 | Dishwashers
How to drain water from haier 8000bt portable ac
There is a drain plug on the rear of the unit, just above floor level. Before draining into a low sided pan of bowl, capable of holding 1 quart of water, turn the unit OFF & unplug it.
Another draining option is to disconnect the exhaust hose(s) and roll the unit to a floor drain or outside to drain it.
Hope this helped you and thanks for choosing FixYa.
Sep 22, 2011 | Haier Heating & Cooling
I have a commercial cool 7000BTU portable air conditioner and it seems to have shut itself down and displays a red flashing alarm light. What can I do to get it working again?
Karen, the flashing red light indicates that the water collection tank is full and needs to be emptied.
You can finds the drain plug on the rear of the unit just above floor level.
It can either be drained into a low sided bowl or pan capable of holding 1 quart of water. or you can disconnect the exhaust hose(s) and roll the unit to a floor drain or outside to drain it.
Sep 06, 2011 | Haier Heating & Cooling
I have a Whynter ARC14SH. Is there a water reserve that need to be emptied?
Yes, occasionally the water collection tank needs to be drained. You will find the drain plug on the left rear of the unit, just above floor level.Since it's so close to the floor, draining it into a pan or bowl is not an option. Turn the unit OFF, unplug it and disconnect the exhaust hoses from the unit. Roll it to a floor drain or outdoors to drain it.
In case you have misplaced your Owner's Manual, I have included a link to it that you can download and print for future reference. http://www.whynter.com/Files/Upload/ProductManuals/ARC-14S_UserManual.pdf
Aug 06, 2011 | Whynter ARC14S Air Conditioner
How to drain the air conditioner commerical cool portable
Janie, since you didn't mention what brand and model number portable AC you have, I can only give you general directions.
On most unit's the drain plug is on the rear of the unit just above floor level. Some have a short section of vinyl hose that can be attached to assist in draining the water in to a pan or bowl. Others don't. However, you can use a low sided pan of bowl that will hold at least 1 quart of water and drain directly into it. Be sure the unit is turned OFF and unplugged, before attempting to drain the water. The other option is to disconnect the exhaust hose(s) and roll the unit to a floor drain or outdoors to drain it.
I hope this helped you and thanks for choosing FixYa.
Aug 01, 2011 | Heating & Cooling
It wont drain the water away after a wash we
sounds like your pump may be gone, or could be pipe blocked. to check pipe fill machine take outlet pipe at rear of machine and lay this into a bowl. If water flows ok then all pipes are clear. As water is coming through just put machine onto spin cycle and raise hose to see if water will then pump out.
Feb 17, 2010 | Zanussi FS1255S Front Load Washer
Washer won't drain.
hi, to empty water manualy, lift the hose from the stand pipe, keep it above the water level, place a bowl on the floor and lower the hose into it, the water should drain out, to stop the water flow lift the hose above the drum and empty bowl, continue until empty, hope this help, thanks for using fixya
Feb 14, 2009 | GE WBSR3140DW Top Load Washer
Bosch SHU9915UC Dishwasher Logo
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
