Ricoh Aficio 3025 All-In-One Laser Printer Logo
A
Anonymous Posted on Apr 07, 2011
Is error code sc562 on ricoh 3260c a fuser issue???
3 Related Answers
Anonymous
  • 813 Answers
  • Posted on Jul 16, 2008
SOURCE: Lost admin password for ricoh
if u have bios password u shoud do that remove your bios battry from the motherboard for few mints & your password will be reset
Anonymous
  • 9 Answers
  • Posted on Dec 16, 2008
SOURCE: Ricoh Aficio 2238c: Fuser Oil Unit
you really can not refill the bottle but I would recommend two things. One find a fuser oil unit on ebay and order it quickly. Next hit the yellow clear modes button, then hit the numbers 1 0 7 , then hold the red clear stop button till the display panel changes. hit copy sp, select 7 data log. now use the page down arrows located in the middle of the disply till you see 7804 push it then go to #10 oil supply and hit execute. this will reset the oil counter and allow you to use the machine till you get the new unit.
Anonymous
  • 58 Answers
  • Posted on Jan 13, 2009
SOURCE: code error sc543 ricoh aficio
SC-543
Heating roller fusing lamp overheat
The detected fusing temperature stays at 200 °C or more for five seconds.
Replacetment the PSU. Got it here: http://www.websitetoolbox.com/mb/copierquestions
5helpful
2answers
Model sp200s. What does c8 error indicate?
Fusing Reload Temperature Error (Fatal Error)
After servicing the machine to solve the problem, the service technician must execute a "Fuser SC Reset". Otherwise, the machine will continue to issue this SC code and cannot be operated.
There is a problem with the fuser section p/n M1014002 -Carl
2answers
How to reset fuser temperature SC542 RICOH Aficio SP C232SF
Fuser Temperature errors usually mean that one of the heating elements has failed inside the fuser. Time for a new fuser or, a good rebuilt one.
3helpful
Ricoh Aficio SP 4210N- Code SC 543
This is a common error code for Ricoh copiers, Savin and Gestetner copiers that need service. Recently Ricoh has purchased Lanier and now is naming all their new machines Lanier instead of Gestetner, Savin and Ricoh. However, the copier service error codes have remained he same.
When you get this copier printer service code it means the fuser or fixing assembly (same part) has thermistor problem. The copier fuser's thermistors help regulate the temperature of the fuser assembly. The fuser assembly on all copiers including Canon, Kyocera, Ricoh, Sharp and other brands is the part that melts the toner onto the page.
Getting back to the repairing the copier on Ricoh, Savin, Lanier and Gestetner models that have the fuser or fixing code error. The majority of the time the fusers' thermistors (Middle and read) need to be replaced. Just cleaning them will not solve the copier repair service code.
It is usually, depending upon the machine, its a 1 to 2 hour copier repair job because the copier repair service technician will need to dissemble the fuser, insert the two new thermistors, re-assemble, reset the error code and test the copier machine repair. Also, ask the copier technicians to to do a copier cleaning maintenance while on site.
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Error SC534 on Ricoh 3260C Color Copier
This code will come up if the fan isn't turning fast enough. Doesn't have to be stopped. Clean the blades or replace the fan. (May also be paper in the fuser connector.
1helpful
3answers
I cant get my ricoh 3260c to register even after the auto register is complete
Hi
Thanks for using FixYa. To register Ricoh 3260C please download the Operating Instructions from the link---
Ricoh 3260C Operating Instructions
All the procedures are given in the Operating Instructions.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
4helpful
Code error sc543 ricoh aficio 3260C
SC-543
Top Ricoh Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
