Question about Sharp Televison & Video
Tv will not turn on. It is plugged in, all connections secured.
  • Sharp Master
  • 6,993 Answers
The issue you describe is consistent with a power supply board issue. This is the board where the AC goes to. This problem may have occurred as a result of irregular power supply, or excess power supply or power surge.
The TV is receiving current but cannot circulate or transfer the current to other necessary part of the TV because of the defective power supply board.
I do not think it needs replacement, rather some defective capacitors are causing this issue.
Open unit up and take a look at the power supply board.You will probably see one or more electrolytic filter capacitors that are bulged up in the top-not perfectly flat like the others.
The value of these capacitors will be different, most likely they will be somewhere around-820 to 2200uF/25 V( or /10V sometimes)
You can replace them with same values but I would recommend the voltage rating to be higher(like 35V for an original 25V) for reliability purposes.
What happens is,these bulged top capacitors will cause a low and unfiltered DC voltage=main board will malfunction(the relay will keep clicking until the caps are holding enough charge to bring the voltage up over a threshold point).
You can buy these capacitors at any Fry's or Radioshack store or you can order them online at vendors like "mcmelectronics.com"(look for electrolytic capacitors).
After replacing these capacitor(capacitors) most likely the normal operation will be restored.
Note: There may be also some other causes for this symptom ,like a defective T con board ,or main board,but the bulged top capacitors are the most common cause for this issue.
If you don't know about TV repairers, take the TV to the nearest repairman to fix the fault for you. Also, note that TV stores a lot of current, so wait a while before opening the TV back cover.
I hope this helps.
Good luck.
Posted on Apr 07, 2011
Testimonial: "Thanks so much for the quick reply. I will check on what you said to do, I feel this will take care of it. Again, many thanks."
Why wont my sharp lcd LC-32D44U turn on?
Well, there could a be few issues. First thing is to verify the breaker that gives power to that wall has not tripped off in the home's break power panel. If it is not tripped then verify the wall outlet that the TV is plugged into has a reset button, like a GFI (ground fault interrupt) If it does then verify that it has not tripped. If the GFI on the wall plug is tripped simply push the reset button back in and then try plugging in your TV power plug again. Then if that checks out or does not have a GFI outlet, verify that the power plug going into the back of the TV is not loose. Unplug and replug power plug that plugs into the back of the TV in and verify it is securely connected. Lastly, the power supply in the TV might have gone out.
Aug 22, 2014 | Sharp AQUOS LC-32D44U 32 in. LCD TV
How to hook up security camera
Basically, all you need is:
1- Power-up the camera.
2- Select video input 1 or 2 on your TV.
3- Run a cable from the camera to the TV
4- Connect the cable coming from the camera to video input 1 or 2 on your TV.
Please note:
The cable you run from the camera to the TV has 2 Ends.
One End connects to the camera (BNC plug) the other End connects to the TV (RCA yellow plug)
I hope this helps. If not, provide the model# for the TV and camera, and if I come across your post I will be Happy to contribute.
Best of luck
www.aaatvservice.com
Aug 09, 2014 | Mitsubishi WD Televison & Video
I have a 65" Mitsubishi dlp tv. Now when I connect anything (cable box, blue ray, ps3) to my 3 Hdmi ports the screen will flash like it is trying to receive signal. The picture will show then go away over...
make this test and fix it. God bless you
  1. Verify TV is plugged-in and getting power.
  2. Verify your home's power breaker has not tripped.
  3. Verify the batteries in the remote control are good.
  4. Verify you have selected the right input for Cable/Satellite, antenna, DVD, VCR or Game Console.
  5. Verify the cable/satellite box is plugged in and getting power
  6. Verify you are getting cable/satellite in other parts of the house
  7. Verify the VCR is plugged-in,getting power, and turned on.
  8. Verify that all wires are connected to proper place
  9. Scroll through input screen to verify you are watching the correct inputs
  10. Look at the FAQ on the manufacture's website or user manual
The Basics
Before we explore more complex tv troubleshooting techniques, we need to examine the basics. First, we need to verify the TV is securely plugged into a power outlet. Don't laugh, but failure to plug-in the TV is the number one reason reported why electronics do not work. Second, you need to verify the remote has fresh batteries. This can easily be overlooked. The remote can be working one minute and not working the next, so replace the batteries Finally, verify that all cables and connections are correctly and securely attached.
Nov 04, 2013 | Televison & Video
How can I adjust the picture colors?
There are several performance issues you may encounter with your Protron PLTV-37C LCD television.
Some problems include the television not turning on, issues with the TV's picture and issues with the TV's sound.
Depending on the type of problem you encounter, there are several options available to you to solve it.
Power Issues
Check the TV's main power cord. If it is not plugged in or is loose, securely plug it in to an electrical socket.
Unplug the television and plug it in to another electrical socket.
If the one it is plugged in to currently is bad, the television does not receive power.
Try turning the television on with the remote.
If that does not work, try turning the television on with the power button on the TV's front panel.
If that works, then remove the battery cover from the remote.
Remove the current batteries and replace them with fresh batteries.
Picture Issues
Check the video cables.
If they are loose or disconnected, securely connect them.
Adjust the television's brightness.
If the brightness is set too dark, images on the screen are extremely difficult to see.
Check the power indicator on the front panel of the television.
If it is red, the television is in power-saving mode.
Simply press any button on the remote to bring the television out of power-saving mode.
Audio Issues
Check the audio cables. If they are loose or disconnected, securely reconnect them.
Turn to different channels and adjust the volume.
It is possible that some channels are coming in quieter than others.
Access the audio options from the main menu. Check what audio setting the TV is at.
If it is set to "Mono," change it to "Stereo."
http://www.retrevo.com/search/v2/jsp/downloadPage.jsp?doc=dde1880d298054849d8c8adc90514f40&modelid=22971545&q=Proton+CS-37
Specifications for Proton CS-37 / PS-47
Aug 09, 2013 | Protron PLTV-37 37 in. LCD Television
Have a proscan ps50700 that wont show the picture, will turn on but turns itself right back off. what could it be
TV Doesn't Turn On
  • Your RCA rear projection TV may not turn on from time to time for several reasons. First, check that the power cord is plugged into a working power outlet. Check that the outlet is receiving electricity by plugging a different device into the outlet. If the other device doesn't work, you may need to replace a fuse or reset a circuit breaker in your home.
    If you tried using the remote control to turn on the TV, press the "Power" button on the front of the TV. You may have a problem with the remote control if the TV turns on.
    If you tried using the front control panels and haven't tried the remote, press the "Power" button on the remote control. The television controls are blocked if the TV turns on with the remote. To unlock the controls, open the "Parental Control" menu and remove the check mark next to "Front Panel Block."
    Finally, your TV may be performing a diagnostic check. These checks are used to find any errors in your TV. Wait a few minutes before trying to turn on the TV again.
TV Turns Off By Itself
  • You may find that your RCA TV turns off by itself on occasion. This is often because the "Sleep Timer" feature was enabled. This feature allows you to place a timer on the television that will turn it off after a specific amount of time has passed. The feature allows you to save on your energy bill and extend the life of your television.
    If the "Sleep Timer" wasn't set, the television may have detected a power surge in your home and shut off automatically to protect the components of the television. Wait at least 30 seconds before turning the TV on again.
    Finally, if you suspect the television is turning off for a reason other than a power surge, unplug the television and let it sit for at least 10 minutes. This will clear any errors in the television. After 10 minutes, plug the television back into the outlet and resume normal use.
  • Blank Screen
  • A blank screen on an RCA rear projection television is usually caused by a loose connection or an incorrect setting. Check that the coaxial connection on the back of the television is secure or, if you're using an external device such as a DVD player, the video cables are secure. Press the "Ant/Cable" button to switch between tuners if you are watching television, or the "Input" button to switch between input channels if you're watching something from an external device.
Apr 21, 2012 | Proscan PS60690 60" Rear Projection...
When i turn tv off and then back on it doesnt have volume if i turn tv off unplug HDMI cable then plug back in then turn on TV i have volume its annoying and NO ONE can figure out why it does that ...
While HDMI has been a very convenient choice for the consumer, it has also provided better security for the owners of the content that we watch on our TVs. HDMI does what is called a "Security Handshake" between the connected devices. A lot of people have to ensure that their TV is turned on prior to turning on the connected device or the security handshake fails.
Most people overcome the security handshake by using a programmable remote that turns their TV on prior to the connected devices.
I hope this information help explains the odd behaviors of HDMI.
Please let me know if I can assist you further.
Regards,
KYTechnology
Mar 02, 2011 | Philips 42PFL3704D LCD TV
Snow on tv cant get bk to pic
Hi nelle_king my name is MikeHouston of DISH Network. There are a couple things we can do to get thatpicture back. What you will need to do is make sure the TV is on channel 3 orthe right input, and if the picture is still snowy and we are on the correctchannel/input you will need to reset the receiver by unplugging it for 10seconds and plugging it back in. After you plug it back in it will power up byitself and you should see the DISH Network screen. I will send the steps tohelp with the setup. b> # Sequentially follow the below steps until problem is resolved or until instructed to skip to another step 1 Verify HDMI Connections Verify HDMI cables are connected from the DISH receiver HDMI Out to the HDMI In of the Revue, and the HDMI Out of the Revue to the HDMI In of the TV. 2 Reset Revue and DISH Receiver Unplug both the Revue and DISH receiver for 10 seconds and plug back in. It may take up to 5 minutes for the reset process to be completed. 3 Check Receiver-to-TV Configuration Check that the wiring between your DISH receiver and your TV is configured properly using http://www.dish.com/wiring. 4 Secure Receiver-to-TV Connections Check that the connections between your DISH receiver, your TV, and any component(s) (VCR, DVD Player, etc.) in between are secure. 5 Bypass Revue Bypass the Revue and directly connect the DISH receiver to the TV using an HDMI cable.
Feb 02, 2011 | Toshiba Televison & Video
Dosnt turn connect to different outlets and nothing Can I send it to get repaired or what can I do
Most video displays will let you know that there is no video input with a display. If your unit is not turning on, make sure the outlet is powered. Take a lamp and plug it is the same outlet you were going to plug your TV into. This will determine if you have source voltage. If you do, then we can concentrate on the TV.
Assuming the plug works, check to see if ALL connections are secure and fully inserted in their sockets.
Finally, please make sure that the voltage selector (120/240) is selected to 120.
If the unit still will not power up, take it back.
Sep 26, 2010 | Akai CFTD2011 20 in. EDTV-Ready LCD...
When I turn to Sirius radio the sound sounds like waterfalls or slow to it. The second tv is fine
Guest,
I would check the connections from the receiver to your TV to make sure you have a secure connection. I you have already done so, you can unplug the receiver from the electrical outlet and leave unplugged for 10 seconds. Plug the receiver back in after 10 seconds. After it reboots and re-acquires the signal, try the Sirius channels. If you still have the same problem, we may need to replace the receiver.
Ray Calo
DISH Network
May 14, 2010 | DISH Network DVR-625 DTV Receiver /...
HAVE A SAMSUNG LE46 HI DEF TV. THE TV WON'T SWITCH ON PRESSING THE ON BUTTON BUT IT JUST KEEPS CLICKING AND WON'T SWITCH ON
first of all, is the tv plugged in?
make sure its plugged in and make sure the cord is connected to the tv securely.
that could be the reason why it wont turn on.
if that is not the case, your tv is probably ruined.
cheers.
Aug 15, 2009 | Televison & Video
Televison & Video Logo
549 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
