Question about Cell Phones
Given yellow black red and green wires on the phone wall jack, which wires should I connect to the two wire input from the phone company?
Cerfer39
  • 709 Answers
SOURCE: wiring ceiling fans to wall switch
Hi Bigelow,
You need two switches.  It sounds like the Electrician set up the junction box for two circuits(Lights and Fans).  i say this because your supply has 4 wires, Red , Black, White and Bare. We may be able to oversome this with one Lutron Switch. Allow me to investigate, and I will be back.
Posted on Oct 29, 2007
docjohn174
  • 943 Answers
SOURCE: Maytag dryer MDE4000AYW change 3 prong to a 4 prong
HI thanks for your question. the red to red black to black white to white green goes to the fram of the dryer. thanks hope i was helpful. please rate my answer.
Posted on Oct 12, 2008
  • 30 Answers
SOURCE: Wiring on a RCA RJ-45 wall jack
the RJ45 wallplate is not meant for ethernet. It's an 8P8C connector for a phone. Will it work as a network jack? Maybe. I wouldn't use it, but if you really want to try, wire it thusly:
1 Blue --- Orange/White
2 Orange --- Orange
3 Black --- Green/White
4 Red --- Blue
5 Green --- Blue/White
6 Yellow --- Green
7 Brown --- Brown/White
8 White --- Brown
I'd still recommend a CAT5 wallplate with a CAT5 jack.
Posted on Apr 12, 2009
al_kupchella
  • 843 Answers
SOURCE: The 3-way dimmer switch has 4 wires; 1-red,
Incoming white - outgoing white This is the neutral, which just passes through without connecting to the switch
incoming black - switch black the hot wire provides power to the switch
switch red - outgoing red a traveler, will have power when toggle is one position
switch yellow - outgoing black
the other traveler, will have power when toggle is in the other position
incoming bare - switch green - outgoing bare the switch is grounded and it passes through
If this was helpful, please vote.
Posted on Mar 23, 2010
  • 351 Answers
SOURCE: I bought a Utilitech 7 day digital in wall timer,
HI .. if the switch has only a black and white wire attached, and there are no other wires in the wall box, then you cannot use this timer switch. You need to return it and get a timer that does not use a neutral connection. The wires you have are a switch leg from the light and there is a white wire but it is not a neutral.
If there are other wires in that wall box , tell me and we can chat more about how to remedy this .
Please Vote !!
Posted on May 25, 2010
Phone Jack Wiring Problem
Your apartment is wired for two lines but you are using only one of the two. Your phone jack has red and green terminals for one line and yellow and black terminals for the other (old color codes). The four wires coming in to your apartment are actually two lines: orange/white and white/orange plus blue/white and white/blue (new color codes). One of those lines is active. Connect the orange/white wire to the red terminal and the white/orange wire to the green terminal. Plug in your phone and listen for a dial tone. If no tone, disconnect the first line and connect the second pair of wires. Listen again. DO NOT CONNECT ANY WIRES TOGETHER. Just follow the steps above. If you still don't get results, the phone company may not have activated your connection
Dec 30, 2012 | Lands Phones
Need manual for wiring phones
The 612 system required 3 pairs per phone. Every 3 pairs on the 25 pair cable would be one station. A modern 6 conductor jack would be wired according to the label. If you have jacks with Green,Red,Black,Yellow,White, and Blue wires, then it's wired as follows.
W/Bl - Green
Bl/W - Red
W/Or - Black
Or/W - Yellow
W/Gr - White
Gr/W - Blue
Oct 12, 2012 | Inter-Tel (660.7600) Corded Phone
I have a cat5e wall plate(tph552) a cat5e wire4 colors don't match and 4 colors do ( brown,orange,blue,green,) are ok then wire has 4 that are white with (brown,orange,green,blue,)stripe. and wall plate...
The wires/colors in a category 5e cable run in pairs. They should be tightly twisted together, mostly white with a blue tracer. mostly blue with a white tracer- mostly white with an orange tracer- mostly orange with a white tracer, mostly white with a green tracer- mostly green with a whte tracer, and mostly white with a brown tracer- mostly brown with a white tracer.The jack you have sounds like a standard telephone or cat. 3 jack. If the jack is being used for a standard telephone line, you'll need to connect one of the wire pairs(usually the white/blue pair) to the green and red terminals on the jack.Make sure that the same pair is also terminated at the main telephone junction.
Aug 08, 2010 | RCA Computers & Internet
LIGHT ON THE SPEAKER BUTTEN STAYS ON
If your speaker button doubles as an in-use-indicator , You most likely have a reverse polarity, This is not usually a problem because the phone will work either way, This only happens with some systems, Check your wall jack for Red and Green wires. The Jack Red Wire should be (Depending on your house wiring) attached to a Red, Blue, or Bluewhite wire and the Green should be attached to a Green, White/Blue stripe, or White/blue striped. Yellow and Black was intended for line 2 but may have been used instead. I hope this helps you
Dec 05, 2009 | General Electric 25982EE3 Twin Phone
I'm trying to install a rotary phone, but it doesn't have a jack like modern phones do. It has three wires with little crescent shaped metal things on the ends. Please help!
if they are red-green-yellow then just isolate your yellow wire and spade and open up phone junction box and connect the red/green wires to the red/green wires on phone jack terminals you can hook either way this type of phone isn't polarity sensitive,then make sure all other phones on this line work properly after install
Sep 15, 2009 | Cortelco 1950's Classic American Standard...
How do I remove the wires from an existing wall phone jack and then rewire to a new jack
pop the front cover off write down witch color wire goes to witch letter on the plastic change to same, most phones line need two wires green and red, but 4 are hooked up black and yellow, for a second line, hook them all up just in case the other wires had a problem and the phone company switced to the other two
Sep 09, 2009 | Lands Phones
2 Orange --- Orange
4 Red --- Blue
6 Yellow --- Green
8 White --- Brown
Apr 11, 2009 | Computers & Internet
No service
What color wires were there ???
What kind of jack, a new one that had...
white blue/blue
white orange/orange
white green/ green
white brown/brown
If so, the white/white blue would go to the same wires.
If you had red/green and black/yellow, the red/green should go to the white blue/blue.
Jan 13, 2009 | Lands Phones
Phone line/phone jack problem
The wiring on the jacks is set up for a 2 line phone.
If you take the jacks apart, you will see either:
A) red, green, and black, yellow
B)white blue/blue white and white orange/orange white
You need to swap the pairs.
If there are red/green/black/yellow wires. remove the yellow/black and move them to where the red/greens are. Then put the red/green wires, where the yellow/black used to be.
OR, you need to swap the orange and the blue wires.
Dec 22, 2007 | Lands Phones
Cell Phones Logo
1,177 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
