I have a sterling overhead heater QVF-75.Pilot fires up and main burners also.Fan does not start.I took fan off and found will run with direct power.I took thermal couple off and tested and it opens and closes.There is a limit switch(terminology may not be correct).L8947.Is this where my problem lies?
    Brigadier General:
  • 4,736 Answers
It's called the blower activation switch. It turns the blower on, when the heater reaches the proper temperature. The Thermocouple has nothing what-so-ever to do with the blower. It's simply a safety device for when the pilot goes out for some reason, it stops the gas from reaching the pilot. In other words, it locks up the gas control valve.
Most of the time, a "Limit Switch" stops the heater form overheating by shutting it down. However , these Sterling Heaters can be a little strange at times and what I would consider a limit switch, could be something different for Sterling. Check you Owners Manual to see what Sterling means by Limit Switch.
Hope this helps you to further troubleshoot the problem.
Posted on Apr 07, 2011
How do I light pilot light?
There should not be a pilot on a direct vent furnace. When you turn up the thermostat for heat the 1st thing to happen is a venter motor should start, it should vent for approximately 45 seconds, the air switch will verify a vacuum in the burner box, then a spark igniter should start clicking to start the pilot, then the flame rod will verify the pilot, the igniter will stop clicking, and the main burner will ignite and remain on until the thermostat has satisfied the set point. These guideline steps must be satisfied before the controller advances to the next step. The 1st step is the venter motor running, sometimes the motor will stick over the summer months, spin it manually to unstick it. PS, nothing runs if the fan door cover is open, as that shuts down the power to the whole furnace.
Oct 02, 2015 | Coleman Gas Fired Mobile Home Furnace,...
Glo warm heater
the regulator IS not only the issue, but it's a major safety benefit,..the pilot flame is non adunstable..get a cheap regulator(like the ones for the outdoor bbq's)
Mar 16, 2008 | Heating & Cooling
Heater fan runs for a few min then shuts down
Check the afc Automatic fan control is shut off too soon .
Apr 29, 2017 | Vulcan Heating & Cooling
Brivis buffalo 85 main burner not coming on pilot light is on fan comes on ???
If the pilot is on the thermo couple is ok. Could possibly be a faulty temperature limiting switch, it may be stuck and just needs a spray of WD40 or similar product. Then again I could be completely wrong.
Apr 04, 2014 | Jandy Lite2 LJ125 Ceramic Gas Heater
Bought a sterling 75 c garage heater burner lights but then 24 v transformer burns out
I didn't find that model but did see a pretty standard wiring schematic for Sterling garage heaters in one installation manual. I'm sure they didn't change much. I did notice they use a 50va transformer, not 40 which is likely what is getting used now. Don't think that would fix it, just an idea. Put a 5 amp fuse inline on the red side of the secondary side of the transformer. This will protect it. I'm willing to bet the ignitor section on the low voltage common is wired wrong. Remove the tstat wires, buy a resettable fuse and install it first. Then get the fan running first. If there is a g terminal jump red to green. This is fan only, start simple, hope this helps
Jun 18, 2017 | Sterling RF75 Natural Gas Heater (75,000...
Sterling RF-45 Pilot light comes on and the burner won't fire. The pilot goes out and fan keeps running.
clean pilot check flame sencor is clean , jump high leval limit first see if it lights , if not try low limit , check thermocouple is tight if fitted ,
Sep 24, 2011 | Sterling RF45 Propane Gas Heater (45,000...
I have a Sterling heater in my garage - Model QVF 30. The thermocouple has apparently gone out because the pilot will not stay lit. Do you have a replacement thermocouple, or can you tell me who deals...
ACE hardware, Tractor Supply, H Depot or Lowez should have what you need. Bring the old one with you. You may have to purchase one a bit longer, just keep the extra coiled up out of the way.
Mar 02, 2011 | Sterling Heating & Cooling
The pilot is lit, the fan blows ,but the main burner will not light
This may sound silly but is the main gas valve on. Switch on top of the valve generally, turn it from pilot to ON.
Dec 07, 2010 | Sterling RF75 Natural Gas Heater (75,000...
Intalled an overhead 130K BTU Mr. Heater last
On a call for heat, the 24 volt thermostat sends a signal to the control module. The control module will indicate a call for heat with a light on the control either blinking or remain solid depending upon model. The inducer (exhaust) blower will purge all gasses from the furnace and pressurize a pressure switch. Once the pressure switch tells the module to continue, the electronic ignition will energize and send 120 volts to the igniter. The igniter will glow and you will be able to see it if viewed thru the small inspection port. Once the igniter gets hot enough, it sends a signal to the module opening up the gas valve (24 volts). Either a pilot will come on or the burner tube will ignite then spread the flame to all burners. Lastly a safety sensor will be looking for a certain temperature within a few seconds and the furnace will continue to operate and the room air blower will turn on in a minute or two.
What could go wrong? The unit will not run if there is no signal from the thermostat (bad thermostat or broken wire), the control module does not sense a signal from the thermostat (bad control), the inducer does not energize (bad motor), the pressure switch does not close (blocked vent piping, bad switch, plugged condensate hose), the igniter does not energize (bad control, bad igniter), the gas valve does not open or there is no gas (bad gas valve, broken wire, no gas), the pilot does not light (dirty pilot), the burner does not light (bad burner, plugged orifice, not enough combustion air), the flame does not spread to each burner (bad flame spreader, dirty flame spreader, more bad burners), the flame safety sensor does not detect flame (dirty or bad flame spreader, bad flame sensor, broken wire, bad control), or the room air blower does not energize (bad fan motor, bad control).
Dec 01, 2009 | Mr. Heater Heating & Cooling
Heating & Cooling Logo
371 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
