Question about Mitsubishi WS-65511 65" Rear Projection Television
Where do I find a new DM Board for Mitsubishi WS65511
  • 1,476 Answers
Xazna,
There are no DM boards available but there are repair kits for the board. I have a tip at http://www.fixya.com/support/r7065906-mitsubishi_turn_flashing_power_timer which explains where you can get the parts.
Thanks for using FixYa and for the great rating.
hardrocko
Posted on Apr 07, 2011
Blinking green light
Replace the 7 capacitors on the DM board. That should solve the Issue. You can get the Mitsubishi WS48511 - WS65511 DM repair kit from www.tvrepairworld.com which has the upgraded replacement capacitors and the CD with repair instructions.
Jun 19, 2012 | Mitsubishi WS-55511 55" Rear Projection...
My tv is a mitsubishi model ws65511 our power went out when it come on tv wont work just flashes green reset wont help
thats caused by failed DM caps which discharge during power outage and then cannot be recharged when power is restored. the mitsubishi repair kit called the WS48511 - WS65511 DM repair kit available from www.tvrepairworld.com should solve the issue it has the replacement capacitors and the CD with repair instructions.
Jun 02, 2012 | Mitsubishi Televison & Video
I have a mitsubishi rear projection tv model ws65511. When i turned it on this morning all the timer light started to blink green. I tried to reset and it still blinks. unplugged and plugged back in and...
that's a very common problem for that model which is almost always caused by bad DM capacitors. Replacing them should solve the issue. You can get the Mitsubishi repair kit called the WS45511- WS65511 DM repair kit from www.tvrepairworld.com which has the caps and the CD with detailed repair instructions.
Oct 04, 2011 | Mitsubishi WS-55805 55" Rear Projection...
Ws55511 wont turn on just get the flashing green light of death!tv is 9 yrs.old no other problems.what can I do about this problem?
Install the DM repair kit called the WS48511 - WS65511 DM repair kit which is available from www.tvrepairworld.com the kit has the capacitors and the CD with repair instructions.
Jul 30, 2011 | Mitsubishi WS-55511 55" Rear Projection...
The power wet off and now the timer green light is flashing and it wont turn on model # ws 55511
Thats caused by the 7 capacitors on the DM power board. They discharge when the power is lost and then cannot recharge when power is restored and the indicator light will blink non stop indicating the DM has not completed the boot sequence. Replace the DM caps. The WS48511 - WS65511 DM repair kit is the correct repair kit for your model. You can get the repair kit from www.tvrepairworld.com
Jul 08, 2011 | Mitsubishi WD-52525 52" Rear Projection...
I have a mitsubishi model WS-55511.we lost power in the house and when it came on the TV didn't work. There is a little light that blinks just over the power button but nothing else works....any ideas??
thats the failure of the capacitors on the DM board. Very common problem fopr your model you can get the WS48511 - WS65511 DM repair kit at the following link. The kit contains the capacitors and the CD with illustrated instructions to do the repair.
http://www.tvrepairworld.com/
Jul 15, 2009 | Televison & Video
Got a Mitsubishi ws-55511 as a freebie a few weeks ago. Once plugged in it does nothing but flash the power light. Prior owner removed access panel but went no further. I am an audio engineer with lots of...
Thats an easy fix. The capacitors on the DM are known to fail . You can get the WS48511 - WS65511 DM repair kit at the following link which contains the replacement capacitors and the instructions on how to do the repair on CD which also contains the Service Manual
www.tvrepairkits.net
Jun 25, 2009 | Mitsubishi WS-55511 55" Rear Projection...
Ws65511 green blinking light had power failure last nite power came o briefely then off when power was fully restored the green blinking lite appeared have tried numerous things HELP
Replace the dm power board . Its inside the metal box on the left (looking at the back with the back removed). p/n 935C986002
Or if you can solder then replace the 7 electrolytic capacitors on the DM power board. value 1000uf16v.
Jun 24, 2009 | Mitsubishi WS-65513 65" Rear Projection...
Blink green light of death - mits ws55613
Just click below for the solution desame as your problem;
http://www.fixya.com/support/t1012464-fixed_blinking_light_but_still_no
Hope it may help you;
Regards;
VOTIT
Jan 28, 2009 | Mitsubishi WS-65513 65" Rear Projection...
Green light will not stop blinking
often the capacitors will show no visible sign of swelling. 90% of the time the blinking light symptom is caused by those capacitors
May 12, 2008 | Mitsubishi WS-65511 65" Rear Projection...
Open Questions:
See all Mitsubishi WS-65511 65" Rear Projection Television Questions
Mitsubishi WS-65511 65" Rear Projection Television Logo
103 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
