Well i have a Sherwood S-2680cp receiver it used to work at one point but it just stopped playing one day and it turns on and lights up but it doesn't play. i have switched the speakers from switch "A" from switch "B" but still nothing. i checked if it could be the fuses but none of them look burnt out...idk i where i could go and get it serviced nor do i know if i could possible do it myself... so thats my problem Thanx Jorge
  • 822 Answers
Suggest connecting a spare amplifier to the monitor output from the tape 2 record connection. This will confirm the operation of the pre-amps. You can cycle through all the input selections AM FM phono etc and confirm that the front end is working.
If the before speaker amp is OK than check for broken solder connections at the PC board caused from thermal cycling. Check for failed power resistors. If resistor has failed replace with identical wattage and type. Resistors in the power circuits of these vintage receivers are used as fuse/saftey and will fail from thermal cycling/ Last check for failed capacitors.
Hope this helps?
Posted on Jun 20, 2017
4 Suggested Answers
SOURCE: no power
my be the off/on bottom is not good.no working.
Posted on Aug 05, 2007
SOURCE: Primare A30.2 power amp has
Check for the fuses inside the machine, replace only with same ratings! Make sure there's no shortcircuit at the speaker output terminals. Have it checked out by your local dealer if you are in doubt.
Pat.
Posted on Nov 30, 2008
  • 47 Answers
SOURCE: Sherwood Rx4050r and right speaker has crackling noises.
Ahh, that channel is blown. Its not 100% blown. This has happened to my freind before, and from my long knowlage in audio, the channel is blown, and is not fixable. If you REALLY are attached to it, you could probably bring it to a shop that fixes receivers, but best bet is to let it go
Posted on Oct 12, 2009
My sherwood rx 4109 has no sound what do i do
Pull the sherwood power cord from the wall for 20 minutes. On the back of sherwood, check all cables and make sure they are in the correct places. Check speaker wires and make sure they are connected. 1)After 20 minutes, turn power on to sherwood. 2) select an input (radio, cd, etc.) 3) Push play. 4) Turn volume to desired level.
Feb 07, 2015 | Sherwood Audio Players & Recorders
Is it worth repairing a sherwood model 6030R Receiver and can you even get new parts for it???
Given that the Sherwood is a basic stereo/Dolby Pro Logic receiver, and that we have had sources where digital audio (coax and optical) are the standard for Dolby Digital and DTS for well over 15 years, and that HDMI is established now as the de facto standard for AV connections on many home AV products.... perhaps it's time to retire the Sherwood and look for something new.
Entry level price points for new, fully spec'd, AV receivers capable of dealing with HD audio, DD, DTS, Dolby ProLogiic- and ProLogic II have never been cheaper.
Sherwood is still a good brand. It has been joined by Yamaha ( RX-V377BL); Sony (STRDH750); Denon (AVR-S500BT) and Pioneer (VSX-524-K) at the entry-level price point of $249. In real terms these are probably a fraction of what you paid for the Sherwood all those years ago.
Another option is used equipment. There are some really good pre-HDMI AV receivers from Denon, Yahama and Pioneer available in the used market.
Sep 10, 2014 | Sherwood Audio Players & Recorders
When power is turned on, standby light comes on normally, but in any playing mode, the receiver switches off and the standby light flashes.
It looks like this is a common problem with a lot of the Sherwood Receivers. I've had the same problem with my R-125RDS for a while now. Finally hit on solution today by replacing a power transistor. The transistor in question is not on the power amp board but instead screwed to the chassis and wired to the mainboard. I believe it is part of the output short protection circuit. In my case the component was a 2SD2059 (silicon NPN 100V,5A) replaced by equivalent 2SD1407. The transistor seems to run pretty warm so I guess this is why they ultimately fail after a few years.
Sep 17, 2011 | Sherwood RX-5502 Receiver
Technics turntable plays but no sound with Sherwood receiver
The problem is the fact that the new receiver has no phono input. The phono input has an extra stage of amplification built in. Your receiver is working fine. You need to purchase a phono pre-amp. These run around $20. Connect the turntable to the preamp and the presmp output to any line level input on your new receiver and everything will work as expected.
Dan
Apr 12, 2009 | Sherwood RX-4103 Receiver
Does a Sherwood rx-4103 have a circuit breaker?
i have the same problem with mine and i cant seem to figure it out... it clicks off around 4 seconds
Apr 07, 2009 | Sherwood RX-4103 Receiver
Sherwood rd7103 rec.
no listing for Sherwood receiver. must do the remote "search" function. here is how:
  1. Turn on your TV.
  2. On the remote control, press TV once.
  3. Then press and hold SETUP until the TV key blinks twice, then release the SETUP key.
  4. Using the number pad, enter 9-9-1. The TV key will blink twice.
  5. Aim the remote control at the TV and slowly alternate between pressing Power and TV. Stop when the TV turns off after pressing the POWER key. This means that a working code has been found.
  6. Press the SETUP key once to lock in the code. The TV key will blink twice.
Hope that helps!
Feb 28, 2009 | Sherwood RX-4103 Receiver
Sherwood rv 6030r does not turn on.
Try these simple trick to find out yor remote control working or not....
Point the remote control towards the Camera of a Mobile Camera phone,with the camera on. While pressing remote, we can see a light (Infra Red) coming from its IR LED through the Mobile Camera if the Remote is working.
If the remote is OK, then the problem with the Remote Sensor or related components of the receiver.
Dec 25, 2008 | Sherwood R-945 Receiver
FM Tuner in Sherwood RX-4105 stopped working
Check your antenna connections. Make sure your FM antenna is hooked up to the FM antenna terminal or jack on your Sherwood receiver. If you have the antenna hooked through the coaxial cable, check your coaxial cable with an ohmmeter for continuity. You can buy a volt-ohm meter as little as $12. Usually bad connection occur between coaxial cable and the the coax cable connectors. If that doesn't solve the problem, then there may be something wrong with your tuner card inside of your Sherwood receiver.
If you receivers display does not change channels or frequencies or AM or FM mode, when you try to change the channel or frequencies, or AM or FM mode, there may be something wrong with the front board of your receiver.
If there is something internally wrong your Sherwood receiver, you need to take it to a qualified technician that can fix it. Do not try to repair it yourself. If you don't know what you're doing, you can do far more damage to that Sherwood receiver to the point that would be very costly to repair.
Before you take your Sherwood receiver to a technician, try to unplug the receiver, and leave it unplugged for several minutes, and then plug it back in. If that doesn't solve the problem, then you need to take your Sherwood to a qualified technician.
Dec 02, 2008 | Sherwood RX-4105 Receiver
No High Voltage
I did solve the problem with the Sherwood receiver R6036-R
The problem was a broken solder Trace towards the power cord on the powersupply board.
Thanks for your concern
May 30, 2008 | Sherwood RVD-6095R Receiver
Sherwood 460 equalizer hook up
Connect the EQ to the Sherwood as if it were a tape deck: EQ's outs connect to receiver's tape ins (play) and EQ's ins connect to receiver's tape outs (record).
Then you hook the tape deck up to the tape ins and outs on the EQ: Tape deck outs connect to EQ's tape ins (play) and tape deck ins connect to EQ's tape outs (record).
This will put the EQ in your receiver's tape loop.
The CD player should be connected to the receiver though the CD in's and out's (or if your Sherwood doesn't have a CD in/out, then use AUX or TAPE2).
To hear the EQed signal with all receiver sources (like the CD player) you'll need to engage the 'Tape Monitor' button or switch which will route the tape loop to the speakers.
Jan 09, 2008 | Audio Players & Recorders
47 people viewed this question
 Grubhead
Grubhead
