Question about Taylor Ice Cream Makers
Taylor 152 counter top ice cream machine belt slipping and making noise. New belt fitted but still making noise at end of freezing cycle even when ice cream is softened. Belt seems a little slack. Is there a way to adjust it tighter.
SOURCE: Spares for Taylor 8756 ice cream machine
you must buy replacements from your local tatlor dist. 700-900$
You will find that responce from all of thier part suppliers carrier is a very well insulated company.
Posted on Aug 05, 2008
SOURCE: taylor ice cream maker
go to taylor web site and download manual
Posted on Aug 21, 2008
SOURCE: taylor soft serve ice cream machine model #y754-27
I have a gearbox,coupler,pulley etc. pulled off a y754-27
Jer 805-925-5556
Posted on Dec 01, 2008
ThaMp3Doctor
  • 8596 Answers
SOURCE: trying to find out what a taylor 168-12 ice cream
Depending on serial number, that machine is about a 2000-2001. Very nice commercial ice cream maker. I've seen used ones range in price from $1000 to $3000. $2500 seems to be a going rate for a used one.
Posted on Mar 10, 2009
SOURCE: Taylor 8756 ice cream machine clogs at face
can i see a display of internal shake machine?
Posted on May 05, 2010
I have a Taylor C707-23 that is freezing the product in the barrel and not dispensing. Then the drive motor trips. Had the sensor probe changed same thing.
If this is an ongoing problem that you have had for a while, it sounds as though your viscosity may be set too high. You can adjust the viscosity by removing the 4 screws that hold the face plate on. You will see 3 potentiometers. You want the left most potentiometer. It Should be labeled "Viscosity". You need a tiny screwdriver to turn it. Turn it counter clockwise about 1/16th of a turn. If your Ice Cream is already frozen, You will have to let it cycle a few times before the ice cream reaches consistency. If its liquid, then you will know as soon as the machine finishes the initial freeze down cycle.
If this is a new problem, then it is highly likely that your beater motor is going bad. To check this you would want to test the amperage of the motor when you initially draw product from the machine. A single phase 1.5HP motor in the taylor ice cream machines should not draw more than 7 amp on an initial draw right after freeze down. Its normal to draw around 6 amps then drop for a few second. In order to trigger the reset, the beater motor has to draw more than 6.3 amps for an extended period of time. Your reset may be set higher than 6.3 but that is average.
Jan 16, 2018 | Taylor Ice Cream Makers
Brush Cleaning did not clear the (L / R) HPR> 45F (7C) AFTER 1 HR fault on my Taylor Model C723 soft serve ice cream freezer.
Certain conditions must be met. The machine needs to be empty. The freezer door must be off the machine. The power switch must be off. Once the machine is off, a 5 minute countdown will show. It will also show 4 temperature readings. All 4 of them must be above 60 degrees F. before the countdown will start. Once the counter reaches zero, the Brush Clean Cycle will be reset along with any temperature vs. time error codes. If at any time, one of the temp readings drop below 60 degrees F. before the end of the 5 minute countdown, the countdown will reset to 5 minutes and the machine will not reset. Generally, the freezing cylinders take longer to come to temperature. Even when you run warm water through it first, there is sometimes enough residual cold to bring the temperature back below 60. A successful Brush clean Cycle will display "Power Switch Off---Unit Cleaned" and the 2 digit green display under the main display will reset to 00. if this happens and you turn the machine back on and you are hit with the same message then you may have an issue with one of your boards.
Aug 02, 2017 | Taylor Ice Cream Makers
My taylor 152 only makes about 5 ice creams then won't produce any more for about 6 minutes ... why ??
The Taylor 152 is at the low end of output when it comes to commercial soft serve equipment. It is rated for 102 3.5oz. servings per hour, but only 4 3.5oz rapid servings before it needs time to recover.
Possible remedies:
When you need to serve several cones in a row, you can pull the feed tube in the top. That will help the product fill the cylinder a little faster.
You could always consider a used Taylor machine that has the ability to keep up with your demand. Soft Serve Parts Taylor Machines
Apr 07, 2017 | Taylor Ice Cream Makers
Taylor 710-27 ice cream machine top not cooling
For Taylor ice cream machine maintenance, please see our Support page or our Youtube channel. Providing ice cream equipment maintenance to you for free!
Slices Concession
Jul 09, 2012 | Taylor 702-27 Tabletop Soft Ice Cream...
Recently bought a used Taylor Shake/Slush Freezer Model 430 to be used for shakes. It was used for aheks in the past and no problems, however, we put it together and the ice cream is too hard. Even...
The Taylor 430 thermistor model has two adjustments a fine adjustment, which is made by turning the knob, and a coarse adjustment that is made by turning the screw in the center of the knob. I suspect you are trying the fine adjustment, which will change the product + or - 2 degrees F. The coarse adjustment will let you set the product temperature between 10 and 30 degrees F.
As far as the clunking, those machines clunk a little. It would do it more if the product was too hard.
You are correct the machine will leak drops into the drip tray, but if it is more than drops, you want to address it. Should be as simple as a new tune up kit.
X39969Tune up kit for most Taylor Slush Machine non Carbonated machines...
If this doesn't help, or if you have any other questions, you can reach me at
Soft Serve Parts Supplies
Mar 15, 2017 | Taylor Ice Cream Makers
Ice cream machine was making ice cream and now the machine runs but will not freeze the mix it is like a milk shake
a.improper pressure switch setting . b. low refrigerant level. c. TQC needs adjusting. d. faulty solenoid. e.insufficient mix in freezing cylinder.
Sep 06, 2010 | Taylor 632-27 Ice Cream Maker
Taylor Y754-27 Soft Serve Ice cream machine
Gearboxes definitely go bad. The first sign is usually noise, I would describe it as a rumbling. The best way to determine if it's the gear box is:
1. empty and disconnect machine from power.
2. remove the freezer door and beater assembly
2. remove the rear panel - 4 screws
3. Remove the belts on the noisy side
4. Spin the big pulley and listen for the noise, you may want to remove the belts on the quiet side to compare the two.
I have a video that was shot to help change the hex coupler, but you would follow all of the same steps to replace the gear box.
Dec 12, 2009 | Taylor 632-27 Ice Cream Maker
i need to know where i may go to get directions to put this taylor 8756-22 ice cream machaine back togeather if you can help please e-mail me at johnjohnson1967yahoo.com thanks
Jun 01, 2009 | Taylor 632-33 Ice Cream Maker
Taylor Icecream Machine Model# y754-27
Try slowing down the rate at which you are drawing the product from the machine,and giving it a minute or two between draws. If you take to much out to fast it starves the barrel and will cause it to freeze up,and that will make the belts squeal.
Dec 11, 2008 | Taylor 632-27 Ice Cream Maker
Ice Cream Makers Logo
79 people viewed this question
Top Taylor Ice Cream Makers Experts
Dennis Boxerman
J.D. Browning
J.D. Browning
Andrew Taylor
Andrew Taylor
Are you a Taylor Ice Cream Maker Expert? Answer questions, earn points and help others
