Subtract 5% of 3243.91 - Office Equipment & Supplies
    Sergeant:
    Champion:
  • 286 Answers
162.1955 Is this correct.
Posted on Apr 07, 2011
How do i subtract two cells and progress down a row by a day so the next day the formula subtracts the current day and previous day?
You have to start the sequence with a slightly different formula because there is no preceding value for Monday.
25525374-qztzwsd5tae24twsq5kxbvm0-3-0.jpg The rest of the formulas are running totals so they are the same just dynamically duplicated down the column add infinitum.
25525374-qztzwsd5tae24twsq5kxbvm0-3-2.jpg Just duplicate the the formula Picking up the value form the result column and subtracting the next running subtraction value.
Mar 06, 2015 | Microsoft Excel 2010
Luke wants to find the difference 175 - 134. He has subtracted the hundreds and tens so far. What is the sum of the two numbers he has subtracted? How much does he still need to subtract?
SUM means adding not subtracting. so if you were wanting to add the total (the sum) of the amounts of the hundreds and the tens would be 170 plus 130 which would be 300 but the remainder from subtracting 130 from 170 would be 40. That would leave the single units 5 minus 4 of which the remainder is 1. So, the remainder from subtracting 134 from 175 is the reminder of subtracting the one hundred from the one hundred which is zero added to the remainder of subtracting the tens (70 minus 30) which is the remainder of 40 plus the remainder of subtracting the units of 5 minus 4 which is 1. So you need to add the 0 and the 40 and 1 which is the remaining sum of 41.
Sep 19, 2014 | Office Equipment & Supplies
Subtracting monomials
Remember that the SHARP calculator does not solve algebra.
But some tips for adding and subtracting monomials include:
Group all the terms that are like terms (they have the same variables and exponents. Make sure that you move them with the sign in front of them (dont lose your minuses).
Add or subtract just the numbers in front of the terms and leave the variables exactly as they are when you write down the answer.
Feb 20, 2014 | Sharp el-531x scientific calculator
2.45.35 hours - 0.23. 12 hours = ?. a short quick method please
Seconds: Subtract 12 from 35 to get 23.
Minutes: Subtract 23 from 45 to get 22
Hours: Subtract 0 from 2 to get 2.
Put the three together to get 2.22.23
This one was easy because there was no need for carry. If you do have to carry, just make sure you carry 60. Otherwise, it's exactly the same as when you learned subtraction in second grade.
Some calculators have conversions between decimal degrees/hours and degrees/hours:minutes:seconds. If you have such a calculator, you can convert both numbers to decimal, subtract, and convert back. Since you didn't specify what calculator you have, I can't tell whether this is an option for you.
Jun 18, 2011 | Office Equipment & Supplies
How do you subtract low numbers from high numbers
  • Hi, to "Subtract a >Higher (#,$) numbers from a <Lower (#, $) numbers; you take the "bigger number 167, place that number (over the smaller number 78 and from (right to left) take away numbers. Example: 167 - 86 = Think of 167 as $167.00 and 86 as $86.00, so to make $86.00 into $167.00 you'll need a $81.00 more. So if you think about how much more money you will need to "Add" to make a certain amount, it is just the same as how much you "Don't have! You have $167.00 when you go shopping for clothes, and you spend $86.00 when you count how must money you have left, it add up to $81.00 "That's "Subtracting." "Subtract (167 from 86 you get 81). " Always remember the Higher, or Larger number goes on top! " If you want to check to see if the answer is "right," add the two number together,(86 + 81 = 167). "I hope this helped you, rating the solution is appreciated, thanks"
May 02, 2010 | School Zone Addition Subtraction Full...
I can't seem to do simple subtraction with my Victor 1208-2. When I subtract say 5-4, I get a negative 9. Is there a setting or do I need to press something different to get simple subtraction to work?
When you want to complete a problem on an adding machine, such as "7 - 3," you would not key in "7," then the subtraction sign, then "3" and then an equal sign. If you do, then you will get an answer of "-4," and you know that is not the correct answer. Again, you have to think like an accountant when you are working with your adding machine. To figure this subtraction problem on an adding machine, you would need to key in "7," the addition sign, "3" and then the subtraction sign; you would get the answer of 4. You are actually working the problem as "7 + (-3)." This would be true on most modern day machines. In order to subtract, you have to add the negative number.
Sep 25, 2009 | Victor 1208-2 Calculator
Subtract anything to get 2/7
Subtract anything? From what?
Subtract 5/7 from 1 (which is 7/7) gives 2/7.
There are an infinity of ways to get 2/7
Hope it helps.
Sep 22, 2009 | Core Learning Fractions - Step By Step...
Ms-office
Subtraction can be done in two ways in Office using the following formulas in the formula (fx) bar:
  1. =A1-A2
  2. =SUM(A1,-A2)
The above formulas refer to cell reference A2 subtracted from A1. As usual, you can use number values instead of cell references.
The SUM formula subtracts by changing the sign of the reference. Remember the sign rules, and thus - -x is in effect +x.
Jul 08, 2009 | Microsoft Office Excel 2003 for PC
Problem coming in subtraction
You just have to use the subtraction formula. The formula is as follows:
=A1 - A2
Where A1 and A2 are cells that contain the data that you would like subtracted. If you want just two numbers subtracted you can type them directly:
=20 - 10
for more information look at the subtraction section of the following link.
http://www.homeandlearn.co.uk/ME/mes5p1.html
Feb 11, 2009 | Microsoft EXCEL 2004 for Mac
Excell
Sorry, I don't clearly understand what you want to do, but if you can explain a little more, I can help. If you want to subtract one cell from a column total, sum the column and subtract the one cell. If there is a need to subtract adjacent column entries, or similar type needs, there are formulas that can do this easily as well. Just a little more info - we'll have a FixYa!
Apr 27, 2008 | Computers & Internet
12 people viewed this question
jasbo
jasbo
