Question about Dell 1815dn All-In-One Laser Printer
The copier reads fuser door open. We have tried all of the suggestions. Thanks
    Director Badge:
    Uploaded 100 video answers.
  • 160 Answers
If the back door is shut and the fuser seems in place you need to replace the High Voltage Power Supply. The fuser door switch is part of the High voltage power supply. Replacing the HVPS should fix this right up. Hope it helps!
Posted on Jun 16, 2011
Fuser door open?
Try fuser door should be in the back. If it is close, it could be a door sensor issue. Also make sure that the fuser is in correctly.
Jul 07, 2015 | Samsung ML-3051ND Laser Printer
C41 Error on Toshiba E-Studio 550
Get a decent piece of equipment. WHY would you throw money away on a bad copier?
Apr 15, 2014 | Toshiba E-studio 550 Copier - Fast,...
I get an error message of Fuser door open
turn off printer pull out fuser unit turn on printer and turn off printer again replace fuser unit back and turn on the printer
Dec 14, 2009 | Dell 1815dn All-In-One Laser Printer
Fuser door open on dell 1815n
If you have tried closing the fuser door (rear door) several times and the error continues. You most likely need to replace the High Voltage Power Supply (Part# WH773). Iteminc.com has this part and can ship same day. The sensor which reads if the door is open can go bad and it is part of the HVPS. Good luck!
Oct 02, 2009 | Dell 1815dn All-In-One Laser Printer
Reads open heat error
This sounds like a problem with the fuser or possibly the fuser lamp. You can try turning the printer off for about ten minutes to cool the machine off and then turn back on. If that doesn't work you would need a new fuser unit. The fuser is located behind the door on right side of the machine. There are four screws used to hold the fuser in place. Good Luck, I hope this helps.
Aug 21, 2009 | Xerox WorkCentre M20i All-In-One Laser...
Problem wit hfuser
If you cant find a video for it, try this. From the front of the printer go your left. You will see a dor who pulls down and give you acess to the fuser door. Remove the duplexer if present (recto-verso unit) Then you will be able to remove the fuser (2 screws on the top of the fuser to remove) It's not that hard but take your time if this is the first time you do it.
Jun 09, 2009 | HP LaserJet 8500 Color Printer
HP LJ P3005 13.31.00 ERROR
As i can understand whenever you try to print with rear door closed printed page should come on top from top output roller however paper gets jammed.
Solution:
Try to print a page using rear door open and it should come out from the rear drop down tray it printed page comes out successfully with rear flap open than paper gets jammed at top due to faulty top output roller.
However if the paper gets jammed at fuser with rear door closed than it is issue with fuser in that case you need to get fuser replaced at the same time replace 20 tooth gear next to fuser.
Thanks and Regards
Neeraj Sharma
Apr 11, 2009 | HP LaserJet P3005n Printer
Minolta Di550 error code C-0500
Dear sir; the error code you post out,I check the manual it said "low fuser temp" my suggestion go to check the fuser lamp inside the fuser roller of the heating unit, you may try to reset before you go for it; the easy way just open and close the lower front door,just try it and let me know the resolve. HAVE A HAPPY HOLIDAY !!!
Dec 17, 2008 | Minolta EP1030/1030F CS/PRO Copier
Broken fuser gear
To access wires/connectors
remove back cover 4 screws
open and remove right door 2 screws on back frame one with small spring attached
remove fuser unit with 2 screws unplug 3 connectors
on back of copier.
remove one screw on wire end of fuser/cut ty wrap with wire cutters be careful not to cut wires!!
pull off cover
remove heat lamp by pulling on copper end piece
slide lamp up and out
remve small c shaped retainer ring from end of roll with 2 small flatblade screwdrivers
take off old gear and install new one-lubricate bushings with a few drops of fuser oil on both ends
re-assemble in reverse order.
any questions just ask!!
Jul 25, 2008 | Xerox WorkCentre XD100 All-In-One Laser...
Paper Jam
The fuser unit has a pape sensor. If, for some reason, the sensor is stuck, the printer will read a paper jam. Open the rear door and inspect the paper sensor located in the fuser assembly. See if it came out of it's original position or if there is something blocking it from moving freely. Good luck.
Aug 23, 2007 | Lexmark Optra T610 Laser Printer
Dell 1815dn All-In-One Laser Printer Logo
96 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
