Question about Cycling
I have a 1998 toyota avalon and sometime my horn work and sometimes it don t need to know why problem:
    Guru:
  • 347 Answers
Sounds like you may have a short in the wiring. Best thing to do is take it into a auto shop and have them diagnose unless you have the tools to check for electrical issues.
Posted on Apr 07, 2011
My question on my 94 toyota pickup 2wd; how can I check to see if the horn contacts are making contact? since the horn contacts are located under the steering wheel, and the air bag is also located there,...
disconnect the negative batery terminal be fore you mess with the horn. the cover should come off easily and you will the wire for the horn on my car the wire is green
Sep 21, 2011 | Toyota Pickup Cars & Trucks
The fuse have been change in the 2006 toyota avalon and the horn still don't work hoe do fix it
Check your horn relay and the wiring going to it. If they're in good order, the horn may have shorted out (hence the blown fuse) and need replacement.
Jun 23, 2011 | 2007 Toyota Avalon
1998 toyota avalon xls. No heat, no a/c, no defrost, no fan/blower. Lights on the control display sometime work. Is this the a/c amplifier?
so for that issue you will have to replace your blower motor for sure and you might have to change you resistor it should nt be complicated good luck
Jan 05, 2011 | 1998 Toyota Avalon
My 1998 toyota avalon has a light on the dash that says BRAKE. It only comes on sometimes, like when you get above 40 or early in the morning when it is still cold. What does it mean?
Have you checked the brake fluid. It has a float switch in the master cylinder and it sounds like you need to add some brake fluid.
Nov 07, 2010 | 1998 Toyota Avalon
The correct firing order for 1998 toyota avalon with a six cylinder engine
1998 Toyota Avalon XLS 3.0 liter DOHC V-6 (1MZ-FE)
I hope help with this (remember to rate and comment this).
Oct 02, 2010 | 1998 Toyota Avalon
I have a 1996 toyota Avalon XLS my my dashboard
problem with steering wheel/column wiring harnes
Feb 21, 2010 | 1996 Toyota Avalon
1999 toyota avalon horn works intermitely
I would suggest to you to have the spiral cable (or 'clockspring') replaced. This is the electrical unit that transfers power to the air bag, the horn and the cruise control.
It is located right under the seering wheel.
Your description of the issue indicates to me that your spiral cable is loose, and making intermittant contact. If the vehicle had an air-bag deployment, this cable-device should have been changed.
Nov 11, 2009 | 2004 Toyota Avalon
I need to find the spark plugs on my 98 toyota avalon
All Spark Plugs are on the Engine,follow the wires from the disributor to the Engine Block if V engine their on both sides if straight there on one side only.Sometimes they are very low and hard to reach,Other times they are just below the valve covers,Good Luck.
Sep 19, 2009 | 1998 Toyota Avalon
HORN ON '97 TOYOTA AVALON DOES NOT WORK
There should be a fuse panel under the dashboard that is labeled. One should have "horn" on it. If not check under the hood for other fuse panels. If you still cant find it, you can start pulling fuses and checking to see if they are blown or not
Jul 31, 2008 | 1998 Toyota Avalon
Cycling Logo
Top Cycling Experts
Michial Gueffroy
Andrew Taylor
Andrew Taylor
Are you a Cycling Expert? Answer questions, earn points and help others
