Question about Canon Office Equipment & Supplies
I need to empty the waste toner bottle for my canon c7055. i have a replacement bottle coming in tomorrow, but i need to use it now
3 Suggested Answers
SOURCE: I have a canon c7055
The waste toner bottle is behind a panel on the lower, rear right hand corner of the unit. You have to remove the panel cover with a screwdriver. Empty or replace the bottle. If you empty rather than replace, make sure to clean the sensor window from the inside (stick a ruler with paper towel rubber banded to it in through the top and rub off toner dust). Often the bottle isn't even full, but this sensor window is dirty making the machine think the bottle is full. After replacing/returning the bottle and securing the panel cover back on, login to your unit from the control panel, press the Settings/Registration button (looks like a head with an asterisk inside), then press the 2 & 8 buttons simultaneously, then press the Settings/Registration button again. From here press Mode > Copier > Function > Clear > arrow over to W-TN-CLR > ok. Press yellow button to exit back to main screen. You should be able to print now.
Posted on Nov 16, 2011
  • 3 Answers
SOURCE: Help with emptying waste on a 2300Dl laser printer
You just open the front door, pull the bottle off, and empty it. Be aware, though, that this is one of the messiest procedures that you will ever do. The toner is so fine and dusty that it spreads everywhere when you dump it and it is vey hard to clean up. I put on plastic gloves, took it outside, put a large ziplock bag inside a tall garbage bag, and sealed this around my wrist as well as I could before dumping the toner. I still had a real mess. If I had not had a couple of the "magnetic" toner clean-up cloths sent with recharge kits, I would have been hard-put to clean up the bottle well enough to use it. And, it still took me a couple of days to clean my hands. A new bottle simplifies this. You just take off the old one, put in a plug, and discard it. Costs $30-40 but may be worth it.
Posted on Jan 12, 2009
Waste toner near full,replacement not yet needed,how can i remove this message on canon ir6055?
Hi . You need to find the waste toner box located on the left lower side of your machine. There is a rectangular cover. Remove the screw and pull out that plastic bottle. Empty the bottle and reinstall it
Jun 15, 2015 | Canon Office Equipment & Supplies
Waste toner bottle full so replaced but will not reset and says still full
then the clear section of the waste toner bottle is not clear some toner is left blocking the sensor that monitors the waste toner level
Apr 02, 2014 | Konica Minolta New Bizhub C25 Color Laser...
I have canon ir 6570 continueing errod code e0013 solution
This is the standard Canon code for waste toner feed screw is locked. Most likely someone reset the waste toner counter and the waste toner has backed up in the auger screw. You should first empy the waste toner bottle located on the right side lower right. Remove the two screws and empty the bottle you find. You may even have to remove all the associated covers motors and circuit boards to get to the waste toner system. You will have to either clear out the auger tube, or replace the whole assembly. Check for broken parts, bound up screw, fused toner, etc. I've done this a couple of times and it's not fun. I try to make sure that I empty the bottle at every 1 million copy mark just so this doesn't happen again. Good Luck.
Sep 07, 2012 | Canon IMAGERUNNER 6570 Copier
I have a canon c7055 and get the waste toner bottle is full message. I replaced the bottle but cant get into the maintenace panel to reset the count
Feb 16, 2011 | Office Equipment & Supplies
Error is E000019-0000
Let the front of the canon copier/image runner iR 3300 as a referrence, waste toner bottle is located under neath the small cover of size 15 cmsX 30 cms and this small cover is located at the extremely lower left corner of the copier/image runner iR3300.This small cover will fixed with one and only one screw at the upper/top right corner of the small cover. Un screw this small cover and remove the small cover along with the attached screw and kept aside. Under neath this small cover there will be a big plastic bottle which is called as the waste toner collection bottle. The capacity of this bottle may be 11/2 kgs to 2 kgs. When this waste toner bottle was filled up , a message will be appeared on the screen that ' replace the waste toner collection bottle'. Even after the this message the copier/image runner may work properly. If the message of error code E000019-0000 appeared on the screen this waste toner bottle may be filled completly. Then the coper will stops to work. Then gently remove this waste toner collection bottle slowly and empty the waste toner bottle which was filled up with waste toner within the plastic bag. Wash this waste toner bottle with soft water 2 or 3 times and there after with soft detergent washing powder , so that no stains of waste toner or any type of stains may be completly removed. Please don't try to remove the water particles with cloth or any thing Or don't try to remove the water particles with Hot hair dryer. After washing the waste toner bottle , dry this with the air coming from cealing fan or with cold hair dryer. After the waste toner bottle was completly dried withj the cold air replace the this bottle in the original place. Before replacing the waste toner bottle in its original position clean the place of waste toner base / holder -up , down, left & right with the clean and soft cloth which is under neath the small cover. Hurray ! your problem will be solved completly without any expenditure but you may expected to take time with patience.
Sep 22, 2010 | Canon (6981A002AA) for imagerunner 2200,...
Where is the waste toner bottle located?
Remove the small cover on the lower left hand side( one screw only) and remove the waste toner bottle and emptied it ensure that bottle neck is not clouded with toner otherwise even the bottle is empty still it will detect waste toner is full .hope this will help
Jul 09, 2009 | Canon imageRUNNER 2000 Copier
Error code E000019-0000
This error indicates that the waste toner bottle is full
Jun 29, 2009 | Canon imageRUNNER 2200
I have Canon ir5075 and it asks me to change waste bottle. I empty the bottle. But do not know how to tell the printer that it is empty.
I am not familiar with this model but usually Canon waste bottle has:
1. Check if the waste toner botlle has some clear portion near the neck, (as in IRC3200) or other part of the bottle ,even the waste toner was removed but if this portion is still clouded by toner the sensor will still detect the waste is full
2. If the situation is not like this some Canon Ir machine needs to reset waste toner counter in the service program mode even the waste toner bottle was emptied
Jun 09, 2009 | Canon imageRUNNER 5000 Copier
A message is poping out saying replace the waste toner container.
I'm taking it that you have a IR-2270, not a IR-5570 correct??? The waste toner bottle is behind the front cover... It is in front of the drum unit. It is measured by the weight of the bottle, you just need to empty the bottle and you should be all set.... There is one screw in next to the toner bottle.... The other one is on the top left front corner of where the paper comes out. You have to push the front pannel to the left to remove the cover... Good Luck
Apr 14, 2009 | Canon imageRUNNER 5570 Copier
Having trouble replacing waste toner receptacle on Canon imageRunner 3750
If the copier indicated to empty the waste toner you will have to reset in the counter in service mode. Press the additional functions key, the 2 & 8 keys at the same time, then the additional function key again. This should get you into service mode. If not depress the reset key and try again. Once there at the top right you will see counter. Depress it then you should see a menu and depress MISC. Depress WST-TNR, then depress "C" on keypad. Counter should go to all 0's. I think that the waste toner message displays at 250,000 copies made.
Jan 07, 2008 | Canon imageRUNNER 5000 Copier
1,293 people viewed this question
old marine
old marine
