Picture freezes briefly then continues, especially ITV and Channel 4, and when using handset. picture excellent on Bush modelIDLCD32TV05HD, 3 years old
    Sergeant:
    Champion:
  • 286 Answers
This is most likely atmospherics . And there is nothing you can do about it.Sorry.
But, I would take it to a repair shop to check it out. But, most likely Atmospherics.
Hope this helps.
Posted on Apr 07, 2011
Bush IDLCD26TV07HD , I get picture freeze when i change to channel 5 have you got any tips as to why it do`s this
I just repaired one of these that was freezing on all channels - the only solution was to turn the set off then on again - the picture also had a tendency to flicker.
I replaced all of the larger capacitors on the power board and it's fine now - I suspect the three 680uf 35v ones as the culprits.
Careful though - Bush used different power boards on these models - however all were Beko and all seem to have faulty capacity issues! A cheap fix.
Apr 22, 2011 | Televison & Video
Ihave Bushldc 26" T.V. and
The most common cause of that is signal break up causing firstly "blocking" of the picture and audio drop out. Heavy clouds can also cause signal deteriation as does heavy rain.
Hope that helps.
Jan 18, 2011 | Televison & Video
Loss of some channels on 32LD30U B
Weak digital signal. Either antenna or tuner.
May 03, 2010 | Televison & Video
Cannot get ITV or Channel 4 on newly aquired DTV, why is that?
The only thing I can think is happening is for some reason it's ignoring these stations. I suggest you try going to the factory settings for it. Then retune, it might clear the tunner's memory.
Feb 26, 2010 | Televison & Video
Unable to get BBC 1 and 2 on Digital. Both Channels are ok on Analogue but switch to Digital and programmes start at ITV( channel3) Have re tuned since last digital update but still the same. Have used the...
There is not a problem with the TV despite it's age this is can be due to your reception of the digital package for BBC. Have you checked through he full listings? sometimes the BBC channel will be at a different number setting because of the transmitter you are receiving. I assume you are using a digital box, you can enter a menu which will give you an indication of the strength & quality of the incoming signal. Do you pick up some of the other BBC channels such as BBC3 or CBBC? It's possible your aerial strength is a bit weak for the digital BBC package & you may need to have that looked at.
Oct 07, 2009 | Panasonic Televison & Video
My Bush tv NR Itv 2101 on channels 1 & 4 picture is fine but channels 2,3, & 5 has a black band 1 inch deep top and botton. All channels say 4.3 so can't be that, any idea's. regards JM
it is because the channel is being brodcast in hd and not just digital. it is an unfortutane side effect of the dtv convertion, all brodcast are now digital but not all are high def, if you had a high def tv and were watching and standard definition channel it would have thick black line on the left and right because the image does not fill the dislay
Aug 14, 2009 | Televison & Video
I have the samsung LE40A656 and when i watch itv channel (footbal
well, you can call up the network and get the picture clear or another sd card maybe
Jun 04, 2009 | Samsung Televison & Video
Lost ITV channels and C4
I've got exaclty the same problem :-/
HELP!
Oct 06, 2008 | Samsung LE26R74BDX 26 in. HD-Ready LCD...
Continuous Channel Searching & Power Button Issues
What source are you using? If cable, you should only be able to pickup channel 3 or 4 if you're using the box. If there is no antenna, that would be the only other answer if the set checks out...accordianman
Mar 20, 2008 | Audiovox FPE1078 7.8 in. TV/DVD Combo
LE32R74BDX
this is because most new lcd tv's have a poor tuner built in and require a stronger ariel, to pull in the analogue or digital signal. Check that your ariel is freeview capable whether using freview or not, as these ariels are better at pulling in the signal, or do what i have had to do and buy a mains plug in signal booster from Asda for about £6.00, this did the trick, especially if you don't want to replace an ariel costing about £30.00
Jun 13, 2007 | Samsung LN-R409D 40 in. LCD Television
Televison & Video Logo
79 people viewed this question
Top Televison & Video Experts
Electro Med Services...
