Question about Maytag Dryers
Belt installation is too loose on Maytag dryer model # pye2300ayw? Trying to fix it need a diagram??
  • Maytag Master
  • 3,740 Answers
Hi and welcome to FixYa, I am Kelly.
If the belt is loose it is most likely stretched / worn and should be replaced:
The idler (item5) of this drawing:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=46651&diagram_id=630165#d630165
See routing here: http://www.repair-help.com/kb/index.php?article=105
The drive belt is item 5 this link:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=46651&diagram_id=695560#d695560
The top must be opened and the front panel removed to install the belt.
Here is a link to step by step "how to" instructions.
http://www.ehow.co.uk/how_7277908_do-belt-maytag-pye2300ayw-dryer_.html
Make sure to inspect the rear drum rollers while you have the dryer open. Item 7 this link:
Flat drum rollers or hard to turn rollers will cause the new belt to fail prematurely.
Additionally if the front or rear drum seals are worn it can cause the belt to be loose. These are glued on with high temp adhesive.
The front seal is item 10 this link:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=46651&diagram_id=28505910#d28505910
The rear seal is item 2 this link:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=46651&diagram_id=28505913#d28505913
High temp adhesive: http://www.appliancepartspros.com/part_details.aspx?part_id=4284239
By replacing the items above your dryer will operate like new again and extend the life of your dryer by many years.
Thanks for choosing FixYa,
Kelly
Posted on Apr 07, 2011
Does a kenmoore 80 series have glides
http://www.searspartsdirect.com/partsdirect/part-model/Maytag-Parts/Dryer-Parts/Model-PYE2300AYW/3048/0151200?pathTaken=&prst=0&shdMod=PYE2300AYW
go here and you can see the parts in your dryer,if the model isn't a maytag pye2300ay then just put your model number in there and it will show you,kenmore doesn't make anything,you go by the model number if it starts with 110. it's a whirlpool,if say 417. it's frigidaire made but the maytag model you sent has rollers and i would say if you have a kenmore 80 series it has rollers,you can buy a kit that comes with the rollers,belt and belt pulley
Nov 14, 2013 | Maytag PYE2300AY Electric Dryer
Trying to replace the dryer belt forgot how the old one came off b/c it broke. not sure how to get it back on to the pullys. maytag dryer model de7600.
This link is a listing of diagrams of belt configuration on various brand dryers the diagram for how the belt goes on the motor/idler pulley on the Maytag brand is going to be diagram E
http://www.repairclinic.com/Dryer-Belt-Diagrams#DiagramE
GENE
Aug 31, 2011 | Maytag Dryers
Maytag electric dryer (PYE2300AYW) does not stop on auto cycle.
Either the control board or the humidity sensor is bad.
Jan 11, 2010 | Dryers
Need color code wire diagram for control wires on timer switch. model#pye2300ayw maytag dryer
This info should be located behind the control panel of your dryer. If not, someone must have removed, try asking again if it's gone.
Oct 19, 2009 | Frigidaire GLER341A Electric Dryer
How do I change a drive belt on maytag model pye2300ayw
remove the back inspection panel, take the old belt off and put the new one over the series of pulleys and tensioners as you took it off, about 15 minutes work
Aug 15, 2009 | Maytag PYE4558A Electric Dryer
Maytag electric dryer:attached belt as per directions,but is still loose,the pulley seems to not give enough tension
You can verify your belt installation by going to repairclinic.com. Click on the "Repair Help" link at the top of the page, then locate the "Dryer Belt Diagrams" link under Special Features. Refer to Diagram E under the Maytag heading. If you say you have the belt installed correctly, make sure the tension spring is still installed. I hope this helps you.
Jun 27, 2009 | Dryers
Need routing diagram of dryer belt on maytag dryer D7600
Go to repairclinic.com and click on the "Repair Help" link at the top of the page. On the following page, locate the "Dryer Belt Diagrams" link under the "Special Features" section. Scroll down to Maytag. The dryer belt diagram for Maytag should be listed as diagram E. I hope this helps you.
Jan 28, 2009 | Maytag PYE2300AY Electric Dryer
Maytag dryer belt replacement
maytag.gif Diagram E
Style: Flat with ribs
Installation Tips: Flat side of belt against drum
Jan 03, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Dryers Logo
278 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
