Question about Roper RAX7244KQ Top Load Washer
Roper washer, agitater stripped?
The washer fills up fine, drains fine, spins fine, but during the wash cycle it seems like the bottom of the agitator is working, but the top half of it just sits there. You can turn it by hand all the way around in both directions, seems like it is stripped, is that possible? Can I fix it somehow?
  • 5,911 Answers
It sounds like you need to replace your agitator dogs (yes, there is such a thing). They are small plastic pieces that are used by the upper portion of the agitator to grip as it turns. This is a common problem when they wear out. If you go to searspartsdirect.com, there's an illustration of what I'm talking about under the "Agitator, Basket and Tub Parts" heading. Item number 10 (part number 80040) is what you need to replace. Just type in your complete model number in the "Search by Model Number" block. The following link provides you with step-by-step instructions on how to do this:
http://www.fixya.com/support/r823955-replacing_agitator_dogs
You can find these same parts at repairclinic.com and a cheaper price. Use the part number provided. I hope this helps you.
PS The item is priced for a package of 4.
Posted on Aug 06, 2008
Please describe a typical washing cycle to me on the RTW4440XQ Roper 3.1 Cu. Ft. Top-Load Washer, please.
The typical cycle is;
fills to selected water level
agitates wash cycle
drains wash water
spins wash cycle
fills to selected water level on rinse cycle
agitates on rinse cycle
drains rinse water
spins final time
end of cycle
Aug 08, 2011 | Roper Washing Machines
Washer doesnt agitate but spins and drains
Replace the agitator drive coupling dome under the agitator. It is stripped out from overloads.
Jul 05, 2009 | GE WBSR3140DW Top Load Washer
Agitater problems will not agitate
To Reset computer. Unplug for 2 minutes, plug back in, open and close lid 7 times slowly to reset computer. This should solve your problem.
May 09, 2009 | GE WBSR3140DW Top Load Washer
Agitater will not agitate during the wash cycle or rinse cycle. it will fill and . drain and spin.
2 things to look for , first check a SWITCH where the lid closes , this will send a signal that is OK to WASH & RINSE cycles , it could be that the SWITCH is either loose or defective , check it out with a multimeter. second , you have to open the washer and check at the bottom a small motor where the discharge hose is connected , remove motor and check for debris , usually it gets clogged , not letting to do the wash & rinse cycles, hope this helpful , AJ
My ge washer wpre6100g clicks during agitation part of cycle...
sounds like the agitater drive is stripped its a plastic piece under tha agitater you just grab the agitater work your fingers under the edges and **** up on it and it snaps off then remove the 5/16 screw put a new block on and snap the agitater back on
Jan 29, 2009 | GE Profile WPRE6100G Top Load Washer
Agitater does not spin
the transmission needs to be replaced
Jan 02, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Roper RAL6245AW0 Washer Won't Drain or Spin
We have a Kelvinator Washing Machine that just won't drain , but fills , agitates , & spins just fine. What shall we do?
Oct 13, 2008 | Washing Machines
Kenmore stack washer and dryer
gabehart....sounds like belt is slipping. Replace it. The water pump is on a separate smaller motor so is not affected by the agitator/spin motor.
Jun 04, 2008 | Kenmore 98702 Stacked Washer/Dryer
Roper Washer
The gears in top are stripped out need replacing, take cap off agitator and take out bolt pull agitator out ..pull top part agitator off and replace gears
Here is what the gears look like for the top part of the agitator
top part of agitator
bottom
Oct 17, 2007 | Tecnik TKL9260 Front Load Washer
Roper RAX7244KQ Top Load Washer Logo
155 people viewed this question
Top Roper Washing Machines Experts
Dan Webster
Dan Webster
Mike
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
