Question about Bosch Classixx WFL 2066 Front Load Washer
I have a Bosch classixx 1200s Expresss. When I press the start nothing happens and a get a 12 beep alarm (4 then 4 then 4) every 60 seconds. There is power and water
    New Friend:
I'm not an expert. I just had the same error (on a Bosch Maxx 6) and fixed it by chance.
My area has a lot of debris in the water supply, and it turns out that the small filter in the hose connected to the water supply was completely clogged up. You can either replace this filter, or clean it as outlined below.
Here are the steps to cleaning it:
1) Unplug washer
2) Turn of the water supply, either by a turning the handle to the washing machine water supply or by turning of the water main.
3) unscrew both ends of the water supply hose
4) Screw the washing machine end of the water hose into the water supply outlet
5) On the other end of the hose, there is a small filter. Hold this in place with the tip of your finger, and turn on the water supply for a few seconds, while keeping the free end of the hose in a bucket. This will flush water through the filter in reverse, thereby cleaning it. Do NOT reverse water flow with one end still attached to the washer machine, as this will flush all the debris into your machine!
6) Turn of the water supply, unscrew the water hose, and reconnect both ends as specified by the manufacturer.
Hope that helps!
-Dennis
Posted on Apr 12, 2013
5 Suggested Answers
  • 3 Answers
SOURCE: very annoying beep when finished programme
When the machine is on, but not running, press and hold the "pre-wash" button. After a few seconds it will begin that beep noise, keep holding it in until the beep volume goes down and finally stops completely (5-10 secs). Once the beep has stopped, release the button and voila, no more annoying beeps at the end of your cycle.
To restore the end of cycle notification (beep) do the same thing as described above, but release the button earlier while the beep is still going.
Posted on Dec 06, 2008
  • 228 Answers
SOURCE: Conditioner not emptying in Bosch Classixx 1200 Washing Machine
ITS NOT THE DRAW THATS NEEDED CLEANING ITS THE JETS ABOVE IN ROOF OF DISPENSER THESE ARE DIFFICULT TO CLEAN UNLESS YOU USE HOT SOAPY WATER AND A SYRINGE TO FORCE THE BACTERIAL GROWTH BACK DOWN THE PIPES,IF YOU DO THIS KEEP GOING TILL NO MORE BLACK STUFF COMES OUT THEN TRY IT IT SHOULD WORK LEAVE THE DRAWER AJAR WHEN NOT IN USE THIS WILL CUT DOWN THE MILDEW GROWTH.
Posted on Sep 19, 2009
Macmarkus
  • 2605 Answers
SOURCE: There is a key symbol and I cannot start my next load
Hello and welcome to Fixya.
You`re likely right on about inadvertently locking out the controls. Your washer has a "child lock" program and I suspect that has been activated.
Here`s how to deactivate it...
1) Press the "menu" button until you see "CHILD LOCK :ON" appear in the display. ( if nothing is pressed within 10 sec.following this the menu will close and it will default to program in the display )
2) Once you see what I just mentioned in the display press the "select" button until "CHILD LOCK :OFF" appears in the display.
3) Finally by pressing the start/pause button the key symbol should disappear confirming you have successfully exited the child lock program.
If this indeed was the issue preventing you from operating the washer you should now be free to select any cycle and carry on.
Let me know if this was helpful to you or not, if so please take a second and rate it accordingly.
Thank you for visiting "fixya" for your washer solution inquiry.
good luck going forward.
macmarkus :)
Posted on May 08, 2010
  • 50 Answers
SOURCE: bosch classixx 1000 express wont spin
Check the motor housing for an overload button, usually on the back and coloured black or red. Give it a push and if it clicks then the motor might have just been a bit stressed out and popped it.
Next two things are more serious unfortunately. The relay on the circuit board might have burnt contacts from switching the motor over the machines life, or, one of the motors windings has developed a fault. (these are both pretty rare though).
Posted on Jul 29, 2010
The child lock in on on my Bosch classixx 6 1200. I don't know how to disengage it
Hello, welcome to FixYa.
I'll start by saying your post indicates it is a Bosch classixx and the "child lock" selection has been activated, either intentional or accidental.
To reset it is as follows...
3) Finally by pressing the "start/pause" button the key symbol should disappear confirming you have successfully exited the child lock program.
**Many times you can also push and hold the start key for several seconds and this too will deactivate the selection...on various models**
Let me know if this was helpful to you or not, if so please take a second and rate it accordingly and a short testimony is also appreciated. Thank you for choosing FixYa.
Regards,
Macmarkus :)
Aug 23, 2011 | Bosch Classixx WFL 2066 Front Load Washer
Washing Machine will bo start
Power on, press the start button for 5 or 6 seconds, the sign will go off. Try the door gently.
Pl rate me 'very helpful' for the free help, thanks
May 26, 2010 | Bosch Classixx WFL 2066 Front Load Washer
I have a Bosch washing machine /classixx 6 12 Express and the key sign is on and cannot programme wash
May 21, 2010 | Bosch Classixx WFL 2066 Front Load Washer
macmarkus :)
May 07, 2010 | Bosch Classixx WFL 2066 Front Load Washer
Very annoying beep when finished programme
Nov 23, 2008 | Bosch Classixx WFL 2066 Front Load Washer
Stop beeping at end of wash on bosh machine
When the machine is on, but not running, press and hold the "pre-wash" button. After a few seconds it will begin that beep noise, keep holding it in until the beep volume goes down and finally stops. Once the beep has stopped, release the button and voila, no more annoying beeps at the end of your cycle.
Aug 16, 2008 | Bosch Classixx WFL 2066 Front Load Washer
Bosch washing machine flashing red lights
all lights are flashing on bosch classixx express no thinh working no water intake door is locked what is the problem and can i do it myself
May 28, 2008 | Bosch Classixx WFL 2066 Front Load Washer
Bosch Classixx WFL 2066 Front Load Washer Logo
63 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Craig Butler
Craig Butler
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
