Question about Desisti 2.5 4K Rembrandt HMI Fresnel, Barndoors
I'm trying to find parts for a Desisti Piccolo 2510 HMI. I need the UV lens.
I bought a Rocketfish 55mm uv filter and tried to install in on my 18-55mm lens. I thought it would be easy but I think it's a wrong fit. I need help installing it.
The 55mm uv filter refers to the diameter - 55mm. This is unrelated to the focal length of your lens 18 - 55mm, which could be any diameter. You need to note the required filter size of your lens and purchase the appropriate size.
Jan 24, 2011 | Cameras
The outer glass lens has come apart from the body of the lens. The part has a thread but I don't know how to re-assemble it. Any ideas?
Is this a completely flat piece of glass? If so, it is only what is called a filter (probably a UV filter) and is not vital to the functioning of the lens. It's an accessory that is mostly used to protect the actual front element of the lens. Filters normally have a screw thread that simply screws into the front of a lens.
If the part that has come loose is curved on either surface, then it is part of the lens and you may need to have a comera shop help you put it back.
Nov 11, 2010 | Canon EF 28-80mm f/3.5 -5.6 USM Lens
When you're choosing sunglasses, does UV protection matter?
Yes, ultraviolet (UV) eye protection matters. UV radiation from the sun can damage not only the skin of your eyelid but also the cornea, lens and other parts of the eye. UV exposure also contributes to the development of certain types of cataracts.
When you're choosing sunglasses, look for UV-protection details on product labels. Choose sunglasses that block 99 to 100 percent of both UVA and UVB rays. Skip sunglasses that are labeled "cosmetic" and those that don't offer details on UV protection. Opt for larger lenses rather than smaller lenses - or, better yet, the wraparound variety.
Nov 07, 2010 | Clothing Accessories
Do I still need those "UV Protective" sunglasses
Yes! Most people believe that the darkness of the lens is what protects their eyes. The degree of darkness has no effect on UV rays. For adequate protection, you need to buy sunglasses that indicate they block 100 percent of the sun's UV rays.
Size of uv lens filter
Can you give me details of what kind of lens you have, Brand/Model with the F-stop size. Tony
Jun 03, 2010 | Olympus Cameras
Canon on nikon
The Canon lenses are FD mount which means that you will need to get an adaptor to convert the FD mount to fit the F mount on the Nikon. An example of the mount can be seen here:
http://www.rugift.com/photocameras/canon-fd-nikon-adapter.htm
As for the speedlights the hotshoe mount will accept them on your Nikon, put them on with fresh batteries and try them out.
Jan 13, 2010 | Nikon D40 Digital Camera with G-II 18-55mm...
My Nikon D40 18-55mm lens won't work on automatic
THERE is a problem in lens not with the UV filter
remove the lens clean the contact of lens & camera if not working repair or replace it
Jul 17, 2009 | Nikon D40 Digital Camera with G-II 18-55mm...
Lens Protection Size!!!
Get a CLA-1 lens tube. It screws into the camera body. The other end accepts 43mm accessories. Put on a 43-49mm step-up ring. Into that screw a 49mm UV filter. (The step-up ring is needed to separate the filter from the extended lens.) Leave the UV filter on at all times. Throw away the lens cap.
Sep 11, 2005 | Olympus Camedia C-3040 Zoom Digital Camera
Filter
Skylight filters don't generally block UV, they change the colour tint optically, which you can do without danger of image degredation in post-processing, so I woudn't really recommend using a skylight filter for digital cameras. I haven't tried a UV filter on my fz10, only my circular polarizer. From what I've heard however, a uv filter may act as lens protection (or use the lens hood), and might in some circumstances reduce haze (rarely), and there are unconfirmed rumours of possibly reducing purple fringing. If anyone could ever confirm this, I might consider one. Otherwise, UV filters also seem peripheral for digital photography. Probably the most important optical filter you can use is a polarizer. This can cut a lot of excess scattered/polarized light and reduce excess contrast, increase sky colour saturation, etc. It's effects are extremely difficult or impossible to get in editing.
Sep 06, 2005 | Panasonic Lumix DMC-FZ10 Digital Camera
Desisti 2.5 4K Rembrandt HMI Fresnel, Barndoors Logo
64 people viewed this question
Top Desisti Cameras Experts
Are you a Desisti Camera Expert? Answer questions, earn points and help others
