My haiser washing machine keeps filling up with water when it should stop when enough water is in the drum
    Scholar:
  • 125 Answers
It sounds like you have a bad pressure switch. There should be a tube that goes from the drum to a switch that tells the machine to quit filling. If that switch works then the board might be bad. Hope this helps.
Posted on Apr 07, 2011
  • james300290 Apr 27, 2011
    sorted the problem now. it was powder blocked in the tube before the pressure switch. thanks anyway aviandragon.
Water keeps filling even when not in use
hi Jeremy.
Why does my washing machine keep filling up with water when not in use? Ensure that the waste pipe of the washing machine is higher at one point than the drum of the machine, this will prevent water running back into the machine. Normally this would fill the machine with dirty water. Or it could be a faulty water inlet valve, which will fill the machine with clean water.22 Sep 2007
why is my washing machine filling up with water when off ...
forums.moneysavingexpert.com/showthread.php?t=558300 Search for: Why does my washing machine keep filling up with water when not in use?
if you want to read up more then go to this link.
Washing Machines keeps filling even when not in use Google Search
Nov 18, 2017 | Washing Machines
IT KEEPS FILLING UP WITH WATER AND OVERFLOWS
There is a tube next to the drum that senses the water level, take the screws out of the back of the machine near the top and then you can lift the top off over the drum, look for the tube and see if it is plugged with lint dirt or softener. Clean it out. If that is not the problem then check the sensor that it plugs into to be sure it is not bad
Jul 03, 2016 | Washing Machines
My bush washer keep s filling up with water in the drum when the washer isn't in use
Seems that your inlet valves are leaking when the unit is off. Replace inlet valve and that should stop the issue.
Nov 10, 2013 | Washing Machines
Hot water stops filling too soon.
Fill setting has to be adjusted and the belt is slipping on the spin cycle and not generating enough centrifugal force to get the water out.
Aug 25, 2017 | Kenmore 22422 Top Load Washer
I bought a top load washing machine model number WF T7239 UL on 05Nov2010. Water sensor does not seem to work. Water just keeps filling up the drum and starts overflowing once filled.
Your pressure switch stops the water and allows it to start the next cycle. It's a switch either in the control panel or at the top of the tub with a small tube connected to it which goes down between the inner and outer tub. As the water level increases the air in the tube is compressed until there is enough pressure to make the switch stopping the water from filling. This tube can get clogged and the switch won't work. Remove the tube and clean it out. Blowing on the tube when it's still connected to the switch will make the switch if it's working and clear.
If it fills with water and starts the cycle and the water keeps running in then your water inlet valve on the back where the water supply comes in is sticking. It needs replacing.
Nov 06, 2010 | LG Washing Machines
The washing machine only keeps filling with water never stops
there is a water sensing device in your unit that is not working, it is located at the top end of a small plastic tube cumming from the washing drum the unit will have a number of wires going to the top or side of it and the plastic tube attached to the bottom, replace this unit
Apr 28, 2010 | Kenmore 24032\24036 Top Load Washer
Hotpoint aquarius drum fills to top with water
will it stop when you stop the cycle? if so your pressure switch could be the problem however if that does not stop the water you intake water valve is most likley the problem
Feb 06, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
Water will not stop filling
Not a lot to go on from your description, but most times this is because the small pipe connecting the drum chamber to the pressure switch has become blocked due to either dirt / fluff / soap scrum, or a combination of these. The pressure switch measures how much water has entered the machine by way of water pressure - the more water in = greater pressure.
To find this pipe you will need to dismantle the machine enough to see the pressure switch, the connecting pipe, and where it connects to the drum chamber. Pull off the pipe and check for blockage in the pipe, the connection to the drum chamber, or in really sever cases, the switch.
A manual would be a great help, most popular models are covered by the Haynes washing machine manual, but even if the exact model isn't, it can still give enough info to get a machine apart.
Sep 06, 2009 | Whirlpool Washing Machines
Samsung Silver Care washing machine
Sounds like your inlet valve is stuck Open ( meaning it wont shut off incoming water ) That may be defective or the control to it may be at fault.. Try unplugging the washer ..and see if the water still continues to fill up the drum? If that happens, then your valve is probably in need of replacement.. Typically, when de-energized..they close and stop water from entering the system.. Hope that helps
Aug 18, 2008 | Washing Machines
My drum of my washing machine fills with water when it is not in use. i have moved the outlet pipe many times but it keeps on doing it. should there be a cut off valve to stop the water returning?
You probably have a bad water valve that the fill hoses attach too at the back of the washer, if the solenoid is stuck open the water won't stop unless you shut it off at the wall.
Jul 30, 2008 | Washing Machines
Washing Machines Logo
29 people viewed this question
Top Washing Machines Experts
