Question about GE GSS22JEM Side by Side Refrigerator
I HAVE A DSS25JFPH WW REF,AND THE FREZZER WORKS FINE ITS THAT THE REF. SIDE IS FREZZEING EVERYTHING IN IT ......ITS SET AT THE LOWEST SETTING??????
  • 239 Answers
SOURCE: Refrigerator side is freezing everything and is
Limit the hile in tha back left bottom corner with a peice of packing tape, leave about 1/4" space instead of the whole opening.
Posted on Sep 01, 2009
sclarke7
  • 222 Answers
SOURCE: Refrigerator is on lowest setting, but everything is still freezi
you need either a temperature control #66005516 or more probably a new auto damper # 61005989 they ar both in the back at the top of the fresh food section under the plastic slide control housing they are easy to replace be care ful and take your time disassembling and reassmbly will be much smoother.
go to apdepot.com and enter in the model number etc and you will se a blow up of the unit itself under controls.
Posted on Sep 12, 2009
SOURCE: refrigerator side freezes even on lowest setting?
It may be a problem with the damper panels that are situated between the freezer and the refrigerator. Most people note a problem when the damper doors stop opening and food becomes warm. In your case the doors may be not closing properly.
This may be mechanical, the damper louvers assembly is broken, or it may be electrical, the relay switch and motor assembly that operates the damper is not operating properly.
In side by sides the damper is usually in the upper side rear of the refigerator. If you can peer into it, you may be able to see light from the freezer (freezer door open) which would confirm the louvers are open.
Quick fix? duct tape a portion of the opening. It will restrict cold air flow. Costs little, and if you are not particular will work. Other fix. Call a repair man and be prepared to pay about 200 for the parts and labor.
Aloha
Posted on Sep 18, 2009
heatman101
  • 43501 Answers
SOURCE: GE Side by Side Refrigerator model GSS22JFMC WW Is
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
rggasd
Posted on Sep 29, 2010
repairman45
  • 130 Answers
SOURCE: Frezzer will not get cold enough , barley frezzes
You are probably low on freon. It would cost around $250 to get a charge and stop the leak.
Posted on Nov 30, 2010
Veg drawer in lower part of frig frezzes the veg. setting on ref is 4
NEED TO CHANGE TEMPERTURE CONTROL IN UNIT. NOT CUTTING OFF SOON ENOUGH AND COLD AIR SINKS. ONLY A MATTER OF TIME AND OTHER THINGS WILL START FREEZING
Jan 15, 2013 | GE Refrigerators
I have a ffa90 futre fridge & bottom frezzer. the fridge is frezzing the food in the door & in the fridge. have tryed water in botles & they get ice on it .in the door the food frezzers so
Find where the supply air is coming into the fridge part. It comes from the freezer and could easily be supplying -18 air direct to the door. This would give you a 2 in the fridge but anything in the direct air path could freeze.
Sep 07, 2012 | Hotpoint FFA90 Bottom Freezer Refrigerator
Vegetables keep freezing in the bin even though I have the temp control set at 1. The freezer compartment is also set at 1 and the freezer works fine at this setting.
Please VOTE FOR ME AND GIVE ME YOUR TESTIMONIAL IF POSSIBLE, IF THIS WAS HELPFUL
ITWILL BE MUCH APPRECIATED.
The cold control needs replacing. Thats the knob with the numbers that turn the Ref OFF and ON.
What I do is call my local Appliance Parts Store with my model no. They are extremely helpful .
Get freezer and ref thermometer. Ref is probably too cold.
Freezer should be 0 to 10 degrees. Ref 33 to 35
If you need more help, Go here:
http://www.applianceaid.com/procedures.html
I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
MORE TIPS AND TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS====
http://www.fixya.com/support/r9962087-stop_paying_high_price_refrigerator
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
Thanks for using fixya
Leo Ponder
imufo2
Sep 15, 2011 | Whirlpool GB9SHKXL Bottom Freezer...
I have a GE artica md417876 ps525mgna ww side by side the frezzer is not frezzing the food it sounds like the fan is working what can I do to fix this problem
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
heatman101
Jun 25, 2011 | GE Profile Arctica 25.4 Cubic Feet...
I love my refridgerator except for the fact it doesn't make enough ice.I was wondering if there is a setting to adjust the amount of ice it makes..I had a service man to come out and there is nothing wrong...
mrs. justice u should have a setting knob that says freezer colder and by adjusting that knob a little making the frezzer colder so the ice frezzes faster. the faster it frezzes the faster it will dump making more ice. but if that dont work then that box should be equiped to have the more up to date one that has a fan in the ice maker that makes it colder and makes ice faster.. remeber the colder the faster the ice should make. ok try that. later gator.
Feb 22, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
Fridge freezing everything
THIS REF. WORKS BEST WITH THE REF. SET ON 4 OR 5 AND THE FREEZER AT 2 1/2 OR 3. HAVING A HIGH FREEZER TEMPATURE CAN HAVE FREEZING IN THE BOTTOM DRAWER OF TH REF. MAINLY BECAUSE OF THE RETURN AIR VENT TO THE FREZER IS BEHIND THAT DRAWER.
Apr 25, 2010 | Maytag 21.9 Cu. Ft. Bottom-Mount...
Freezer works fine,refrierator not cold.
Check to see if the fan is running in the frezzer side. This is called the evaperator fan and it blows the cold air from your evaperator to the ref side to cool it. If this is not running then your ref will not be cooling at all.
Jul 29, 2009 | Refrigerators
Frezzer is not frezzing
if the compressor is running your ref. should be getting cold. Their is a defrost timer but when it is in defrost the compressor shuts off. I think you do have a leak.
thanks,
Jun 28, 2009 | Refrigerators
Having temp problems
for a freezer would suggest a thermostat problem easily replaceable if you follow the removal of the old thermo.use temperature gauge to set to the required degree after instaling new thermo
May 21, 2009 | Freezers
GE ESS25XGMC WW Side by Side
its possible that your water tank has frozen up, try turning the refrig off and leave the doors open for about 10-15 mins and try it again. if that works just reset temp controls a little lower..
Dec 15, 2007 | GE GSH25JFR Side by Side Refrigerator
GE GSS22JEM Side by Side Refrigerator Logo
48 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
