Model : ELekta EAWM - 7003 i loaded the clothes for washing. it started to do the washing then after a few minutes it turned off. i checked the wire and pressed the power on button , but it didnt work. i do not know how to fix i t. there was no problem in the socket or electrical wirings... Unfortunately, i removed the water manually but somemore was left. please advise thanks
  • 1294 Answers
SOURCE: Washers isnt working
Most probably its your belt that has come off. Open up behind to check and refit. If belt is too loose, replace. The belt should "give" about half an inch after it is fitted. Or it would be too tight or too loose.
Dont forget to rate me please.
Posted on Dec 27, 2007
SearsTechToo
  • 261 Answers
SOURCE: Whirlpool washer overflow during wash cycle
What you can try is to get the machine empty and remove the hose that connects the pressure hose to the switch and blow air through it to make sure it is clear, then tap on the nozzle where the hose connects on the switch to make sure it is also clear.
Posted on Oct 16, 2008
  • 4 Answers
SOURCE: I have Model WF-S6607?WF-S6607TC. Washing Machine.
This might be Lid cover open protection. There is a small magnet at the edge of the lid cover, housed in some sort of a catch.
If the plastic housing cracked, the magnet might have dropped into the washing drum. To overcome this, place a magnet on the position where the plastic catch will contact the washer when the lid is close.
Posted on Sep 09, 2009
mnwarfield10
  • 452 Answers
SOURCE: When I press start the water turns on and off for
change water valve assy... this should cure it....
Posted on Dec 30, 2009
  • 713 Answers
SOURCE: Washing machine will not turn on.
Hi just read your posting.Have you checked the power point for power with a toaster or hair dryer?If there is power to the machine then there are 2 reasons why it is not powering up.1st-- the drain pump is open circuit 2nd the control module is faulty.1st empty the machine by hand so you can look underneath the machine by tipping it back far enough to see the pump.Now the pump will either have a red or black fan on it ,or you will see no fan and that means you have the new style pump.please reply with the type of pump you have and if you have or can borrow an electrical test meter and i can guide you step by step to find out if the pump is faulty or the controller or both.
Posted on Jun 04, 2010
My elekta washing machine model EAWM-S7003 doesn't startup. There is no display.
Check your fusebox and make sure that its all switched on
Feb 09, 2015 | Washing Machines
Elekta EAWM - S7003 Manual
When running the washing machine does not withdraw water
Nor in the process of drying and rinse
Sep 22, 2013 | Washing Machines
Whirlpool WFW9050XW Washer Front Load
Disconnect your mains from the wall and clean out your filter.
Pl click if helped.
Apr 28, 2013 | Whirlpool Washing Machines
I want user manual for elekta eawm-s7003
water inlet is not closing while switchon
Apr 10, 2013 | Cell Phones
Problem with my washing machine
You need to replace your wash timer or circuit board this is your problem. This is the unit behind where you turn your machine to heavy load whites and what have you. Remember to rate my solution and give testimonial this is how i earn my achievements here on Fixya Thanks in advance.
Apr 26, 2012 | Kenmore Washing Machines
Asko Dryer won't spin...need to tighten belt
Does the Motor turn... We have had many motors with bad capacitors .. check the white capacitors for cracks or metal coming out of it...the motors will run with out a load on the but put a few clothes in the drum and they will just hummm..
Jul 19, 2008 | Asko T721 Electric Dryer
Front Load Washer - Error F30
hI I HAVE REMOVE THE TOP COVER. YOU WILL SEE AT LEFT A PLASTIC ACTUATOR WHO MUST BE UNPLUG FROM ANOTHER PLASTIC PIN. JUST PUT IT BACK TOGETHER AND THE PROBLEM WAS GONE!
Jun 16, 2008 | Washing Machines
Fisher/Paykel Smart-drive 5.5 auto washing machine was on final spin cycle and starte making unbalanced load noises. I stopped it,redistributed load and tried to restart. It restarted in spasms so I took...
sound like the controller opr micro board is sick. unplug leave off for a few minutes then power up again and try empty wash cycle if its the same call the engineers.
Apr 22, 2008 | Washing Machines
Washing Machines Logo
233 people viewed this question
Top Washing Machines Experts
