Ok so i have a wd500 gb hard drive and when i go into the bios it detects my hard drive in native ide mode( thats the only mode it finds it in) and it seems like its fine. But when i go 2 install windows 7 it works fine till the point it needs some where to put it and it can t find the hard drive during installation. Its my first build and im new at this but i figure it would just work. Its a SATA cable and everything is plugged it just cant seem 2 get it 2 work ive tried everything please help!
  • Andrew Freyne
    Andrew Freyne Apr 07, 2011
    Hello Faze, just a couple of questions. Firstly, does your hard drive have an IDE port on it or a SATA port or perhaps it has both? Also, you mention that your hard drive is recognised as an IDE mode. In your bios you should notice an area that mentions SATA. If you have a SATA cable then do you have this cable plugged into one of your sata ports on the motherboard? If so it should be your first sata port, that's if you have four of them. Also, I want to ask, do you have an IDE connector on your motherboard?
    Scholar:
  • 50 Answers
Hello and welcome to fixya.
If I was in your position, I would try disabling the AHCI mode of the Hard Disk Drive from the BIOS. That option is can be found according to the type of BIOS you have.
Of course the other-way around stands as well. This means that if you notice that the AHCI option of the Hard Disk Drive is disabled or not on, please try and enable it and try the Windows7 installation again.
This problem is mostly noticed in Windows 7 (64-bit) here but as I mentioned before, it might not be exactly the same. Try disabling/enabling that specific option I've told you and see what happens.
Also: You didn't mention intially if you have more than one Hard Disks or if you are running RAID. That might also cause some issues or needs specific configuration.
Let me know how that went.
**Don't Forget to vote this answer**
Thanks.
Regards from FixYa.
Posted on Apr 07, 2011
  • Chris D Apr 07, 2011
    I would also like to clarify (in case you have missed it), whether you have plugged in the power strip cable of the SATA 2 Hard Disk. More informative setup of SATA can be found here--->http://www.easeus.com/resource/install-s...
    Sergeant:
    Champion:
  • 286 Answers
At this point i would ask what model is the hard drive and is it internal or external..?
The former Operating system is vista, i tried to down grade my operating system to XPsp2. the problem is the installation cannot continue the apperance is blue screen that informing me the hard drive...
you need to find the floppy driver for your chipset and install it to detect the hard drive. newer chipsets use a hard drive mode called AHCI, or like you mentioned RAID.
alternatively you need to go to the BIOS and disable these or change the setting to IDE/Legacy to detect the hard drive. the only advantage to the AHCI or RAID is hot-swapping the hard drive and Native Command Queuing (supported by newer hard drives) but the performance gain in XP would be negligible.
May 05, 2011 | Computers & Internet
I have a Soltek SL-K8AV2-R1L with one 160 gb sata harddisk (with XP on it), a 40 gb IDE harddisk on IDE channel 0, and two DVD/CD-drives on IDE channel 1. Tried to reinstall XP but XP setup did not...
Welcome to Fixya. The first thing you need to check is if the SATA Hard Disk is detected in Bios. In the system information you will see there the list of the drives including the DVD and the IDE hard drive. You can also check the Boot Sequence or Priority if it is there. Please let me know if you find the SATA hard disk on the list.
Thanks
Apr 15, 2011 | Soltek SL-K8AV2-R1L Motherboard
Hello, Where could I find a driver for WD5000KS SATA? I am trying to upgrade my desktop PC to Win 7 but when installing it, the setup could not detect the SATA HDD and asked me to load the HDD driver. ...
Check in your BIOS,first make sure the SATA controller is set to native mode and not RAID, and secondly that the BIOS can detect the drive, if the drive can't be detected by the BIOS then it's because the drive surpasses the boards drive size limitation.; If this is the case there is a chance a BIOS update may fix it but it's not guaranteed it will.
Jan 05, 2011 | Western Digital Caviar SE16 (WD5000KS)...
The Bios is not recognising the HDD at all nor is windows. I am using a GA-MA78GM-US2H and I have tried it in all Sata Slots on the board 0 throught to 4. I have an IDE plugged into the board as this...
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your motherboard to your hard drive make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ?
hope this helps
Dec 18, 2010 | Seagate ST3750640AS-RK 750 GB SATA II Hard...
P4m80-m4 mobo not detecting SATA hard drive
go to bios setup,thn go to advncd settings thn u have to change the settings for hdd from ide to sata mode
Jul 23, 2009 | Seagate Barracuda 7200.10 320 GB SATA Hard...
Sata hdd not detected in bios
Tried a differant SATA power inout into it? Is it making a clicking sound?
Feb 18, 2009 | Samsung SpinPoint T HD501LJ 500 GB SATA...
Ide install problem
there may be some conflict in the jumper settings so just check the jumpers and try to connect it should detect the device ...
if you still persist the problem then just check the ide bus cable there may be some problem in that ...
replace the ide cable and try it ... make sure that the ide slot is working properly ...
regards
-Dileep
Dec 26, 2008 | Asrock AM2NF3-VSTA (4711140874470)...
My computer will not boot up if my WD500 is connected.
You will have to go your BIOS settings. What its doing is the BIOS is looking for a removable storage to booot to before it looks for your actual hard drive. You will have to change the order of boot checking to where your hard drive is first.
Reboot your computer without the drive connected.
While still on the black screen that looks like DOS, it should come up and say press F2 (or some other key) to get to SETUP.
Press the key rapidly until the screen comes up.
If it dosnt come up then you were to late and then reboot your system and start pressing it repetadly agian right when it turns on.
Navigate in your BIOS menu to find BOOT OPTIONS.
Once there rearange the list to where IDE or HARD DRIVE 1 is first on the list.
Press the exit button and make sure to save chages not discard them.
Then try connecting it and turning on.
Dec 24, 2008 | Western Digital My Book Essential Edition...
Compaq presario v3000 laptop..doesnt recongize the hard drive
I beleive that you are trying to install retail versions of XP which will not be able to detect the Hard Drive in the Notebook as it is a SATA drive and Windows XP will not be having the drivers for SATA Hard Drives by default.
In this situation, I recommend you to check and disable the SATA Native support  option available in the BIOS.
Start the Notebook and start tapping the F10 key which will take you to to the BIOS Setup window.
In this, go to the System Configuration tab using the Arrow keys and select the option as Disabled next to SATA Native Support.
Press the F10 key again to save the settings done and exit BIOS.
Now, you should be able to use the Windows XP disk and install Windows XP Operating System in your Notebook without any issues.
By disabling the SATA Native Feature, the Hard Drive of the Notebook will be detected as a IDE Drive because of which we will be able to install XP without any issues.
Donot Re-Enable this feature in the BIOS again as the Operating System may not boot. Let the option next to SATA Native Support be Disabled.
Hope this helps...
Aug 12, 2008 | HP Compaq Presario v3000z Notebook
Computers & Internet Logo
81 people viewed this question
David Payne
David Payne
