Question about Dryers
My whirlpool dryer #LER5636KT0 seems to be working ok with the exception that it won't turn off when the door is opened. I have to turn the timer knob to the off position for it to stop. What would be the cause of this?
    Master:
    Sergeant:
  • 385 Answers
There is a door switch so that when you open the door the dryer turns off. Be sure to unplug dryer before trying to remove the switch, it needs a new switch put in.
Posted on Apr 07, 2011
LE6090XS Dryer timer open
Timer part # is 696434. But, as you already know, it is no longer available. You might try doing a ebay search for that timer.
Sep 01, 2017 | Dryers
My dryer won't turn on at all. Can hear timer and I had the push start tested and is ok . any suggestions?
first test the fuseable link in the back its near the fan burner area on gas units on electric by the coil heater. let me know then we go from there
Nov 03, 2012 | Kenmore Dryers
Won't stop, have to manually open door
Sounds like a bad timer. Your dryer is a Whirlpool product.so a replacement timer should be easy to locate. If the timer is advancing but the dryer won't stop, the problem could be the control unit. Run another load of clothes and take notice of the timer's position. If it doesn't run out, then it's very likely the timer. The video below shows step by step instructions for replacing the timer unit.
Mar 30, 2012 | Estate TEDS740JQ Electric Dryer
Whirlpool electric dryer not drying very well. Dryer seems like it is on lo all the time. Mod LER5636KT0
poss venting problem. call 214-341-0097 for service or further questions. maytag service....
Jan 27, 2011 | Whirlpool Dryers
Hit start button but dryer will not start can hear the timer running
Open the dryer door and press the door switch , to make sure you hear a distinct " click " . If the door switch seems ok , then remove the rear dryer panel ( UNPLUG DRYER FIRST ) . On the blower housing , you will see a white 1" long piece ( thermal fuse ) with 2 wires plugged onto it . This is the piece you need to replace . #3392519 is the Whirlpool part number .
Apr 18, 2010 | Whirlpool LER5636P Electric Dryer
I have an electric whirlpool with start switch not working
OPEN THE DOOR/PUSH THE START SWITCH ON DRYER/THEN PUSH THE DOOR SWITCH/HAVE A PERSON TURN THE DRUM/IF IT STARTS TO TURN (DRUM) OR STILL HUMS AND DRUM WILL NOT TURN YOU HAVE A BAD MOTOR/REPLACE MOTOR.
FREDDY
Feb 14, 2010 | Whirlpool LGB6300 Gas Dryer
Whirlpool LER5644A No heat and motor wont Turn
Replace the dryer wires.
Put your meter leads into the 4&5 slots.
Make sure the door switch is closed or jumpered.
Push the start button.
If you read no voltage the issue is with the wiring, the timer, or a relay.
Mar 11, 2009 | Whirlpool LER5636P Electric Dryer
Dryer stopping in middle of cycle but timer continues to run.
oK " It's your timer, it has to be replaced
it's not going threw all it cycles, will start but will not finish
not a big job, unscrew plate on back at the top you will see
timer , take it out and replace it
( can not stress enough that you have to unplug the electrical cord from the wall socket before working on a dryer or any appliance )
Jan 24, 2008 | Whirlpool LER3624JQ Electric Dryer
Dryers Logo
41 people viewed this question
Top Dryers Experts
