Question about Toshiba e-Studio150 Copier
Hi tohisba e studio 150
I have a h4 error - could you tell me how to fix this problem
    Scholar:
  • 62 Answers
This is a fuser error.
First you must enter the simulation mode as follows:
press the keys clear, density select, clear, density select
then press the copy key
use the arrow up and down buttons to select the number 14 in the display
press the copy key
this should fix the problem
c
Posted on Oct 07, 2008
Thoshiba e studio 120. What does error code H4 mean?
The Code H-4 Mean the copier needs to be reset. Also I have added a link to help you troubleshoot the copier.
Thread Toshiba studio 120 with error code H4
Mar 17, 2016 | Office Equipment & Supplies
How to reset Toshiba e-Studio 161 Copier Copier with "error code H4"
Step 1:-
Press
"C" key AUTO/TEXT/PHOTO key
"C" key AUTO/TEXT/PHOTO Key
(Note:Perform the first two key strokes quickly )
Machine display should stop blinking
Now press 14 and press start button.
Switch off and on to check
Feb 27, 2016 | Toshiba Office Equipment & Supplies
[H4-00]SHARP system error
A H4-00 error code is a problem with the fixing unit. Odds are you will need to replace the fixing lamp or thermal fuse or the thermistor to solve your problem. You did not tell us what model of Sharp you have? There are many different ways to reset the code. Good Luck
Dec 22, 2012 | Sharp Office Equipment & Supplies
Removing the error H4-00 code
In Toshiba Printer the error codes generally occur due to instability of drivers in system and also due to system related issues either it is supporting or not .So for proper assistance on this issue just get connected at Toshiba Printer Support Number 1-800-243-0019 and get in touch with expert technicians and get your issues resolved. Visit: Toshiba Printer Support Phone Number 800 243 0019 for Help
Aug 27, 2012 | Toshiba e-studio 203sd
I have a Toshiba e-studio 150 copier. L-1 error code flashing
hi there is problem L-1 means that u have problem CCD MCU Harness Disconnect
May 12, 2010 | Toshiba E-Studio 161 Copier
Display panel h4 code any clues?
This error is displayed when the Fixing heater has not reached normal operating temperature after a specified time.
It is usually a blown heater element.
You will need a technician to repair this.
May 01, 2010 | Sharp AR-235 Copier
Toshiba e-studio error H-4
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} H4 Heat roller low temperature detection
Apr 28, 2010 | Toshiba e-STUDIO 150 All-In-One Laser...
Error h4
H4 in 161, fuser low temp.; instantly solve it by simulation (c-auto-c-auto) 14; check thermistor; check fuser lamp by 5-02. it is to blink!
Jul 07, 2009 | Toshiba e-Studio DP170F Plain Paper Laser...
Error code H4-00 and machine is "locked-up" in scan mode
H4 is a fuser error. It needs to be replaced by a tech. Sometimes they can reset this error in service program.
Apr 24, 2009 | Toshiba E-Studio 3511 Color Copier
Toshiba e-studio 150, Problem H4
This is a fuser related error - the fuser is not warming up within a specified time frame. It could be the heater lamp or a thermostat/thermistor that is not working, possibly a bad fan. You can cancel the error code (hopefully the error does not come back) by going into sim mode. press the following keys one after the other "clear" "density select key" "clear" "density select key" then enter 14 and the copy start key. then restart the copier. If error code persists you could remove the fuser unit and look for any foreign matter inside the fuser. dirty thermistor or thermostat can cause this too.
Hope this helps
Apr 05, 2009 | Toshiba E-Studio 161 Copier
127 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
