Question about Sony KDL55HX800 55 in. TV
My kdl-55hx800 will occaisonally power off and back on shortly after it is turned on, it also loses its clock setting when this happens. I have installed the latest software, 086, which was supposed to resolve this. any suggestions? thank you!
  • panfili Apr 08, 2011
    this all makes sense,but the tv is 6 monthes old.
    Top Expert:
  • Sony Master
  • 74,198 Answers
Hello
Check well whether there is any loose contacts in the wall supply outlet, or to any other extented wirings. Your TV loses supply voltage to it by anyway. If the supply votage is steady; clock settings will not reset, eventhough the internal circuits or the TV has some trouble. The loose contact may be in its power inverter board inside. It is very difficult to detect these loose contacts with naked eye, as they will be micrscopic, and can be noted with the help of a high power magnifying glass. In practice, what I do is, to this type of fault is to resolder most of the suspected solder points, by applying a little more solder, without making any solder bridge short in between the component terminals. If you have a concept of soldering, you too can do this work. But must have patience, and a steady hand. Look for any loose in outer supply wiring first. Try an other plug point too. Still fault prevails, be sure that the supply inverter board has the trouble and the loose contact is in it.
Just check these. if it does not helps you inform me by Fixya. I'm happy to assist you.
Me caucious when handling the main supply inverter board. Eventhough the power input is disconnected, ther may be some storage voltage be there in the high voltage capacitors in it. Discharge them before doing any soldering work on it. Try. Wish you Good Luck. OK.
Thanks for using Fixya.
Posted on Apr 08, 2011
  • 1,591 Answers
There's a good chance you have failing electrolytic capacitors either in the power section or the inverter section or both.
Any caps in these sections that look bulged at the top, or bulged/leaking at the bottom need to be replaced.
Each time you turn it on, eventually it'll probably stay on, but every time you turn it off, the TV will get harder and harder to start up until one day it just won't.
You may also notice a clicking when it power cycles when you first start it up.
If you aren't tech savvy, don't worry, read the rest of this post and watch the videos.
If you are handy with a soldering iron and can identify the power supply and inverter / FM section for the backlights, an inexpensive handful of capacitors will likely fix you right up.
Match the capacitance on the capacitors. Go over voltage if you can, and still have them fit.
IE - it's not a bad idea to replace a 10V cap with a 16V or 25V or even a 50V, but don't replace a 680uF cap with a 500uF or a 1000uF (unless you are positive it's only doing ripple filtering, and even then, you should go OVER, not under the uF rating).
Most of the caps that go are 10V 1000uF or 3300uF.
I found some great videos of the procedure (for many Samsungs with the same issue) on youtube.
http://www.youtube.com/watch?v=Mm51C_RDIZE
http://www.youtube.com/watch?v=BNHHrgX_6cs&feature=related
http://www.youtube.com/watch?v=8l0AUj8QUkg&NR=1&feature=fvwp
http://www.youtube.com/watch?v=Y7b_nTaZYcU&feature=related
As you can see, this issue spans plasma TVs, as well as large and small LCD TVs and monitors.
This problem is not brand or model specific, it's affecting many!
The parts are cheap, and skill required is minimal.
  • Norman Skinner
    Norman Skinner Apr 08, 2011
    These are improperly manufactured capacitors.
    They can fail at any time...most outlive the warranty (barely) others don't.
    If it's under warranty, get the manufacturer to repair it for free.
What is causing solarization?
Fault to its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Nov 30, 2015 | Sony KDL-55HX800 55" 1080p 3D Ready LCD TV...
When I turn on my kdl-55hx800 half of my screen stays darker than the other half?
Sounds like a backlight inverter board fault. Check it. Contact any service technician. If you wish to get some details, http://electronicshelponline.blogspot.com/ Pull up older posts.
Dec 16, 2013 | Televison & Video
KDL-55HX800 Tv turned off after 30 Sec
How many times do this LED blinks at one time switch ON? These are called blinking codes, and are fault indications. From the number of blinks, you can get an idea about the faulty circuit section inside it.If you wish to get more details, surf this link. http://electronicshelponline.blogspot.com/
May 22, 2013 | Sony KDL-55HX800 55" 1080p 3D Ready LCD TV...
Hi, I have a Sony KDL-55HX800 that shutdown and will not turn back on.
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
http://electro-medical.blogspot.com/
Mar 10, 2013 | Televison & Video
Kdl-55hx800 flashing 4 red lights
Visit the site named 'Electro-help' for more details. Click this link. View it in "Timeslide" or "Flipcard" option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. It will make search easy. There are more than 1100 posts to different brand TVs now. Pull up older posts there.
Nov 05, 2012 | Sony KDL-55HX800 55" 1080p 3D Ready LCD TV...
KDL55HX800 dims and then shuts off and red LED blinks 6 times
IIC bus clock and/or data lines low at power on 06
Aug 25, 2012 | Sony KDL55HX800 55 in. TV
LCD Screen replacement for KDL-55HX800 55in 1080p 240Hz 3D LED TV?
Hi there and good morning to you
I am sorry I do not know of anyone apart from trying AMAZON.
Here in Iceland Imight eventually find one but it is far away.
Good luck toyou
Kolbrun
Feb 25, 2012 | Sony KDL55HX800 55 in. TV
Sony KDL55HX800 55 in. TV Logo
199 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
