Question about Fisher and Paykel (IWL12)
We have a f & p fridge freezer model E327B, that randomly beeps at us at odd times. I small light inside flashes indicating there is something wrong with the freezer but everything is still frozen. If we push the button next to the light it stops beeping.
    Brigadier General:
  • 6,277 Answers
Sorry, it would be better if you re-post this onto the fridge/freezer forum- this is for washing machines so you might not get an answer- other than this one ;-0)
Good luck,
John C
PS sounds like the temperature sensor might be misbehaving like ours did - but take no notice of me!
Posted on Apr 07, 2011
Have a GE Profile PFCS1RKZA - with many random issues...
The dimming light indicates a power loss in the system.
Jul 10, 2015 | GE Refrigerators
FRIG KEEPS BEEPING BUT DOORS R CLOSED TIGHT
Not knowing the make and model of your fridge, I would suggest reseting the fridge and freezer temperature settings, inside your fridge. With some fridges like Fisher & Paykel, when the power is cut to the fridge, it will beep until you select the temperature level inside the fridge.
Failing that, a constant beep is a warning code to alert that a fridge component has failed.
Ash
Sep 11, 2011 | Refrigerators
Hi My Fisher & Paykel Model: E522B starts beeping for no reason at random times. When I press the cooler/warmer settings it stops but will start beeping again randomly at a later time. Please...
Hi - I believe the problem is the power module located on the rear of the machine. I have not done work on F&Paykels for a long time.
Whats happenning is the controls is picking up an error with the input power supply, the modules perhaps got an intyermittent issue.
Try this turn your fridge off & back on again - the E522B will start to beep indicating the lose of power which is exactly whats happening to the unit at the moment, to eliminate the beeps you reset with the temp button on the inside.
Jun 14, 2011 | Fisher and Paykel Active Smart E522B...
The alarm beep which tells you to close refrigerator or freezer door now beeps even after either door has been closed. It beeps three times at approx twenty second intervals, then beeps continuously for...
Sounds like you have a bad door switch. Depending on the age of the fridge, it might still be under warranty. If it's not, then you might be able to access the door switch yourself and pull it out & replace it.
Good luck......
Aug 15, 2010 | Fisher and Paykel Active Smart® E522BR...
Fridge beeping
the beeping is an alarm certain lights on the display will be flashing when it is beeping record which lights are flashing this idicates a fault code then post your results and i will tell you what the fault code is and what the problem is likely to be :)
Jun 07, 2010 | Fisher and Paykel Active Smart® E522BR...
Freezer not working on ariston fridge freezer 2 orange lights on top of fridge keep beeping every two hours causing fridge not to work is there a reset button
freezer not working on ariston... Solve freezer not working on ariston fridge freezer 2 orange lights on top of fridge keep beeping every... (More) freezer not working on ariston fridge freezer 2 orange lights on top of fridge keep beeping every two hours causing fridge not to work is there a reset button
Sep 13, 2009 | Freezers
Control panel lights blink and beep, freezer fan cycles
The column between the doors being warm usually indicates that the compressor is running properly but the condenser fan at the bottom rear that cools the condenser and compressor is not running. Remove the cover from the back of the machine and verify this fan is running. It could have stuck from sitting for a period of time or something has gotten stuck in the blade during the move.
I am interested in what the fan inside the freezer is doing. You say 3-4 second pattern, is it running a few seconds then off a few seconds?
Please post back with the exact model number from the decal inside the fridge and I will look it up and see what I can come up with.
Nov 11, 2007 | KitchenAid Superba Architect KSCS25INSS...
Washing Machines Logo
119 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
marley mcelhinney
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
