Question about Home Security
Zone alarm code
I have a ge security system or at least the key pad is ge nx-1448e. One of the zone alarm lites is on and I have checked the windows in that zone and all are closed and locked. Any suggestions? Joe
  • 74 Answers
Check all the wire to that zone, magnets or movement sensor`s led is lit with every movement, it might be a damage wire or a mice bite hehehe, check the panel and make a bridge between the zone number and the common if the led zone turns off, u definitely have the check the wiring and magnets... becareful !! some magnets can give false contact... use a tester to measure continuity, other wise contact a troubleshooting for that brand....
Posted on Mar 09, 2009
I do not know that make, but, it could be the contact and magnet not in line or water ingress or maybe just a faulty contact. Check your manual for a reset procedure.
I hope this helps ?
Posted on Aug 07, 2008
SOURCE:
I forgot my password for my Caddx NX-8 Alarm. It was installed in 1999
My caddx nx-8 system, have started going into a instant alarm mode for no reason, what can I check for this?
Mar 30, 2011 | GE / Caddx Networx NX 8 Control Panel...
Keypad message reading 12volt low battery on three wireless zones. changed out all batteriies and still getting message.
This could be referring to your battery backup for the control panel. Make sure your battery connections are secure and check the batteries' voltage with a multimeter. If it is showing less than 12 volts and has been connected to the control panel for more than 24 hours, the battery is bad and needs replacement. Contact your local alarm company and ask them verify the battery is bad, and they can install a new one for you right then.
Feb 23, 2011 | GE / Caddx Networx NX 8 Control Panel...
I have the Caddx NX-6 alarm system. Problem: Alarm system will not arm when entering the 4 digit code. Symptom: I have all doors/windows/zones closed. LED displays READY. I press the code and get 3...
If the power was out for 5 hours and the control panel still shows 'low battery', it's probably time to replace the battery for the control panel. However, this shouldn't keep the alarm panel from arming up. I would first try to re-start the control panel by removing the power and battery connection for a few seconds and plugging it back in. After that, it would be a good idea to re-enroll all of your attached sensors, etc. by entering into programming mode and exiting. Press * 8 + {go code} then just press exit. The default 'go' code is 9713. After about 15 seconds, the panel will have auto-enrolled each attached device. Try arming and disarming the panel. Be careful of setting off the alarm, as your monitoring station may dispatch police, etc. in the event of alarm. This is why having a certified alarm installer do this work is a good idea, as they can put your account with the monitoring station on 'test' so alarm signals are recorded for testing purposes but are not acted upon.
Feb 11, 2011 | GE / Caddx NX 6 Fastpack with NX 1308E LED...
I have an old Westinghouse Security Systems that keeps alarming every 15 minutes Model XL4600SM Key pad and its driving us crazy.. don't know how to shut it off can someone pls. help us (numeros days...
Check all ur windows and doors sensoring connections,might need to be changes.Weather is too hot or too cold,will trigger the alarm.When u arming tries by passed and any error codes for doors or windows connections codes.This should stop the fault alarm by the expanding and contracting sensors by the weathers.
Dec 15, 2010 | GE Security Simon 3 Wireless Home Security...
Hi i have a ge Caddx NX-148E-RF - beeps only on the hour anoying
Press * 2 and it should tell you what the problem is.
AlarmProfessor.net
Jul 04, 2010 | GE Security Simon 3 Wireless Home Security...
Hi Liam here I just installed a networx nx4 and when powered up key pad has 1,2,3,4 flashing rapidly with service light on I was able to get rid of service light but zones still flashing And there is only...
This could be a supervision problem. If zone expanders, gsms, keypads, etc. are added to this alarm panel, you must enroll the device with the control panel. This is done by entering into programming mode ( * + 8 + {go code} ) and then simply exiting programming mode by hitting the exit button. The GE NetworX control panel and it's affiliated compatible devices will auto-enroll after about 15 seconds. The default 'go' code is 9713, but this is usually changed by the alarm company installer.
Apr 21, 2010 | General Electric GE NX-591E-GSM NetworX...
Have ADT 3000 series alarm system - would like to set it to max
adt sw3000 panel does not support max button on key pad. best solution would be to have ADT tech reprogram Zones so windows are perimeter zones(instant when armed away or stay) and motions interior follower (instant when no perimeter zone was triggered first). doors stay exit/entry.
Feb 25, 2010 | GE Security Simon 3 Wireless Home Security...
ADEMCO alarm system indicates A/C not ready. What does it mean, how to fix it?
Turn the alarm off two times. If it still indicates A/C not ready, press the * key and it will tell you what zone is open or what zone has a low battery.
Nov 22, 2009 | Honeywell 5804 Ademco Wireless Security...
Contant Beeping on alarm
The Fail To Comm message is not related to your low battery problem. A Fail to Communicate occurs when the alarm system tries to send a signal (alarm, trouble or restore) to a monitoring service but can't. Most often the causes are telephone related. Has your system been disconnected from it's phone line? Have you recently changed phone services from your main carrier to an internet provider that provides VOIP service? Sometimes alarm systems have a hard time communicating over these services. Whatever the reason for the
Mar 28, 2009 | GE Interlogix Dvmre Pro 10 Channel Triplex...
Help with wireless window security alarm
"Zone not ready" indicates the windows sensors are not seeing the magnet piece to indicate the window is closed. Are your sensors built into the window jams or are they external wires you can see?
If you have external wires, look for broken wires or broken/missing magnetic bars.
Did the painters paint the window jams? If so, they may have painted over a sensor, though paint usually does not affect the functionality of a magnetic sensor.
Look for the broken wires or broken/missing magnets.
Also - you should be able to bypass the window zones and set the alarm. Instructions for bypassing a zone should be on the alarm head or available online.
Dec 23, 2008 | Intermatic SP130B Wireless Door/Window...
Open Questions:
Why Sliding Doors different from Hinge Door Wardrobes? If you are thinking about wardrobes there are two types of wardrobes hinge doors & sliding doors. Over the centuries of use, hinge doors have done well when it comes to giving a simple system for storing and protecting your valuables from the elements. These days doors are available across a large variety, based on material, color, style, finish etc. In this article, understanding their difference between hinged wardrobe doors vs. sliding wardrobe doors. If you would like to speak to a leading Noida based wardrobe company call Vara Designs and Decors to ask questions or book a in-home design and quote. For Hinged Doors - Improved visibility When you open the doors you get the entire view of the wardrobe. Hinged doors do not dissemble one side of the wardrobe as alike sliding door. More Hanging Space You can hang your accessories like sling bags, scarves or belts on the back of the doors with hinged doors. Color & Finish Options Actually swing doors have been in the market for a long time, these wardrobes come in different styles and colors. According your requirement and budget, you can get any wardrobe door design or color. You can choose metal-framed shutters with glass panels. If you have a small bedroom, you will need to plan the position of your wardrobe such that the doors do not prevent movement. For Sliding Doors - If you want to choose a sliding door, sliding doors work and look best when you have at least three or more doors. Extensive Length of Sliding Doors Sliding door wardrobes support large spaces that can house a lengthy wardrobe. The intrigue of these wardrobes lies in having room for a lot of things like garments, beauty care products, and accessories, etc. Besides, they save space as sliding doors don't impede the traffic stream in the room. Sleek Design of Sliding Wardrobe You have the luxury of designing your wardrobe as you wish depending on the texture or color. Mirror sliding doors can give you both style and functionality in one simple package. Space-saving Sliding Wardrobes Sliding wardrobes are perfect for minimized rooms since they are basically space-saving. While this restricts the perspective on the clothes in the wardrobe, it likewise streamliness space for small rooms. Vara Designs and Decors provides best sliding wardrobe designer in Noida, Delhi NCR. We provides interior design, modular kitchen, woods design & wardrobe etc. at best price. Call: +91 ********** & Email: [email protected] for more information here.
Oct 03, 2019 | The Home Security
Home Security Logo
174 people viewed this question
Top Home Security Experts
Marvin
Marvin
Lawrence Oravetz
Are you a Home Security Expert? Answer questions, earn points and help others
