Question about Ryobi Cultivator
A starting problem with 31cc idc 400 1 cultivator. what is timing procedure . New module has been installed.
    Problem Solver:
  • 19 Answers
The timing is not adjustable. When the flywheel is set on the crankshaft and the key inserted between the crankshaft and the flywheel, this aligns the magnets in the flywheel with the coil. As the flywheel spins, the magnets swing past the coil setting up an electromagnetic field, thus generating the spark. I suspect that when you say a "new module was installed" you are referring to the coil. If it was installed correctly and gapped properly your timing can't be off. Accordingly, the problem likely lays elsewhere. You may wish to inspect the fuel lines. If the machine is more than 3-4 years old they are probably cracked or broken. Also check to make sure the fuel filter hasn't come off of the pickup line inside the fuel tank. This is a very common problem and fairly easy to repair.
Posted on Oct 31, 2011
How to replace pull cord on mtd yard machine cultivator 31cc
-Remove the cord or rope assembly. then rewind the unit and then attach the new rope to. After install the new rope. Try to pulls out to see it will rewind back or not. If not rewind more.
Good luck
Mai
Jun 19, 2014 | Garden
Repair and replace power module on bolens culivator 31cc engine
How old is it? Does it show a spark when you remove plug an hold against engine while pulling cord? Did you replace plug? It is the most common problem. Remove the stop wire an try to start, if it does or you see spark the switch is bad. I would check put these things before replacing module.
Mar 16, 2014 | Bolens 31cc 2-Cycle Gas Cultivator BL410
I need parts for the IDC 400 31cc cultivator
ordertree.com has them for abt 50 dollar. part 753-04125, I believe its a mtd part. plus abt 10.00 shipping
Aug 25, 2012 | Yard Machines Cultivator
I have a Yard Machrines by MTD Yard & Garden Cultivator 31cc: Model No.21A-121R900 Ser.No.1A246DG1150 and I need to replace the primer bulb. How do I do that?
hello l, how to change primmer bulb,,remove the two fuel lines making note which line came off where,use needle nose pliers to push the two ears down and pull bulb out,make note on where the long and short stem was at,go to the mower shop and get a new bulb and install,put lines back on, done start engine,,hope this helps,,
Jan 27, 2012 | Yard Machines Cultivator
I HAVE JUST UNPACKED A NEW RYOBI TILLER BUT WON'T START. NEW GAS MAYBE FLOODING FROM LEAVNG IN START AND PULLING THE START CORD FOR SOME TIME?
yep...take the plug out...pull it 5 or 10 times to clear the gas...dry off the plug....re-install...hold the trigger wide open...and pull...
if that worked, go back and review the start procedures
Apr 18, 2010 | Ryobi Cultivator
Ryobi Cultivator Logo
769 people viewed this question
Top Ryobi Garden Experts
Jim Parker
Jim Parker
Nick Olsen
Rexter1
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
