Question about ASUS N61Jq A1 Notebook
It keeps freezing a colred patern apears on the screen then does not respond I have to turn power off and re-boot in safe mode
  • pip_margrave Apr 07, 2011
    its brand new yes it works ok then can go at anytime ,windows 7
    Sergeant:
    Champion:
  • 286 Answers
Questions.. 1. Has it ever worked. 2. Is it new 3.what O/s do you use.
Posted on Apr 07, 2011
  • Stephen Edwards
    Stephen Edwards Apr 07, 2011
    Ok, I would suggest you take it back to the dealer you bought it from. And ask for a replacement.
    It seems to me that you have A VGA problem and can only be fixed by them..
    Hope this helps.
Hp pavilion dv4 2045dx keeps freezing and shutting down
It seems that you have a virus and it is running at boot.
first try to boot in safe mode and see if the computer stay up.
"Restart... hold the f8 key down until you see the boot option menu and select: "Safe Mode with Networking"If your pc still shut off and freezes then is not a virus and it is a hardware issue, possibly power issue or heating issue with the CPU.If it is ok in safe mode, then you need to remove the virus in safe mode. Download antivirus program that support safe mode operation.after successful removal of the viruses, reboot in normal mode and edit your msconfig, to remove any running programs that might be viruses.
If you continue to have a problem, I can log gin to your PC and fix it myself, just download teamviewer and contact meTony
Feb 10, 2013 | Computers & Internet
Screen freezes on start up power off,power on freezes again .whats the problem ?
Hi ,
This happens when a startup program is is corrupt or is not responding.It can also be that a hardware is gone corrupt that is making the computer freeze.To correct the problem please follow the trobleshooting steps listed below.
Disconnet any external devices that you have added after you bought the notebook like usb devices ,printer etc.Then turn the computer on and see if the computer freezes or not .If it does not freeze then it means that there is an external device that is causing the problem and to find it out you need to connect one device at a time and check .
U can also do this .Turn the computer off completely and then when you turn the computer on keep on tapping the F8 key till it loads the advance boot menu page then select safe mode just plain safe mode and hit the enter key .Wait till it loads the the log on screen then select administrator.It will take you to the desktop and check if the computer freezes or not .If it doesn't then it means that there is a program that is causing the computer to freeze.Go to start?run ?type in msconfig?enter?click on the startup tab ?click on disable all?apply ?select the services tab?click on disable all ?apply ?click on ok or close to exit from the page and then select restart when it prompts you to .When it is booting up to the normal mode check if the computer freezes.Then you will have to find the program that is causing the computer to freeze.To do this first enable all the startup program and then check if it doesnt then its a program under services that is corrupt .S o select one or more program restart and check so this way you will have to isolate the program and then just leave that program unchecked.
Hope this post helps you ...all the best
you can revert if this does not work....
May 08, 2010 | Medion MD-40954 Notebook
I have a gateway w/ vista home premium. After i hit the power button to turn it on, the machine goes thru the regular process of booting and before it gets to the login screen a black screen apears. At...
You can try to press F8 after you first turn on the machine, you want to keep tapping it but not super fast or you can make a keyboard error. Just until a screen appears that will give you the option to boot in Safe Mode.
If you can boot in safe mode you may be able to also choose "Last Known Configuration that Worked" as an option.
This is about the 5th option down on the screen (NOT in VISTA SAFE MODE)
If none of these options work you will just need a Vista Disc. If you use this it will not detroy your data unless you delete the partition.
But you will lose your programs, or at least have to reinstall them.
**IMPORTANT**
You must have a regular VISTA DISC not the ones that come bundled with computers. Those will 9 out 10 times erase everything. and are meant for specific machines. Plus the usually install quite a bit of bloatware on your PC.
Feb 01, 2010 | Computers & Internet
When I turn my notebook on, it freezes at the Windows XP start up screen. How do I fix this?
If it freezes on start up screen means some kinda driver usually is locking it. To check and see is it driver or Master Boot Record being corrupted try to boot in safe mode. To boot in safe mode shut down the laptop and press power to turn it on and right away start tapping key F8 untill advanced start up screen comes up and then choose safe mode. Once in safe mode if it works check your drivers in device manager and also check for viruses and spyware. If it does not allow you to boot in safe mode you might have to run recovery from a CD but this is little complicated if you dont want to loose all the data but it is still possibility. I would try safe mode and if still issues i would get it to repair shop. Hope this helps.
Jan 19, 2010 | Acer Aspire One PC Notebook
Black screen, curser still appears.
Turn off the laptop and keep pressing the F8 key to get to the boot menu. At that point, choose safe mode. If you can get into safe mode then go into system restore and choose the last date that the laptop was working properly. The system will reboot at that point and hopefully it will go into windows normally.
If you can't get into safe mode then that means windows is corrupted and you'll need to wipe out the hard drive and reinstall windows and the device drivers for your hardware.
Dec 13, 2009 | Toshiba Satellite A100-S8111TD Notebook
My dell inspiron 1525 continuously keeps locking up. The screen just freezes up. I am unable to bring up task manager or hit escape. The only thing I can do is shut the power down / bring back up. This is...
Try this steps:
Turn off your laptop.
Power own your laptop then press release the F8 key until this option will popup.
Select Safe Mode.
Wait until Windows succesfully boots up using safe mode.
If you can succesfully log-on on your Safe Mode.
Press Windows Key + R
The run window pops up type MSCONFIG
Click Start Up as show below
Uncheck all check Items and click OK
Reboot your laptop and boot windows in normal mode...
Hope this helps...
Oct 21, 2009 | Dell Inspiron 1525 Laptop
POWERS UP BUT THEN FREEZES AFTER ABOUT 4 MINUTES
Need to test and isolate where it exactly freezes? After dell logo, after windows logo or while inside windows? Now, if it only freezes inside windows try to turn off your windows updates and antivirus first and check if still freezes, if yes then try booting in safe mode, reboot system then keep tapping on f8 once dell logo appears. Check if laptop keeps freezing in safe mode. Please let me know.
Oct 01, 2009 | Dell LATITUDE C600 PIII 750MHZ 128MB 15GB...
Frozen screen
try to log in safe mode when the laptop is booting by pressing F8 key, you will see many option select boot in safe mode, if you can boot in safe mode then reboot normally. if the problem remains then you have to repair or reinstall your operating system.
Dec 15, 2008 | HP Pavilion dv6000z Notebook
GATEWAY 310
I wonder if that is a computer virus.
Try putting the computer into safe mode by shutting the computer down, wait 30 seconds, turn if back on.
At the beginning of the boot press and hold down the f8 button. Use the up and down arrow keys to select safe mode and press enter.
After windows finishes starting up in safe mode, restart your computer the normal way.
If the login screen still appears that way and you can get into safe mode, I can tell you how to go into the control panel and change the login screen to the other mode. That should work then.
Jun 21, 2008 | Gateway 310S (2900621) PC Desktop
ASUS N61Jq A1 Notebook Logo
203 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
