Question about Refrigerators
Thermostat set on 46 degrees,yet freezes everything. i have filled it pulled it away from wall and still it freezes, the water filter froze and cracked. is this the thermo?
  • firesale01 Apr 07, 2011
    No, the coils are not freezing up the liquid products and water and water filter are freezing,the thermo is set on the highest setting!
    How do i check it? the freezer works fine
  • 4,323 Answers
Hi
You can use a hair dryer to melt the ice around fan. The water will drain down to pan near compressor. However, if the quantity of ice is large then you may use towels to collect the water. Ice on coils happens because of defrost heater not working or a faulty defrost timer, if the coils have frost deposit on them again then check the defrost heater and defrost timer, you can also test the thermostat before replacing any part. Hope this helps...please post back for further assistance.
Daniel
Posted on Apr 07, 2011
  • Daniel Scott
    Daniel Scott Apr 07, 2011
    Then check the defrost thermostat and if bad replace it
  • Daniel Scott
    First try to locate the defrost timer and once you
    locate the defrost timer, slowly turn the screw like
    wheel in
    the middle of the defrost timer with a straight screwdriver until the fridge
    shuts off. You are now in defrosting. If the
    defrost
    heater(s)
    comes
    on now, replace the defrost timer and defrost thermostat. If the heater(s) does
    not come on, you can
    ohm test
    the defrost heater for continuity or
    volt test
    for 120 volts to the heater(s). If you have no power to the
    defrost
    heater(s)
    you
    can also bypass the defrost thermostat to see if the defrost heater will come
    on,
    join
    the 2 wires together
    to
    bypass the defrost thermostat. If the heater now comes on, replace the defrost
    timer and defrost thermostat. If the heater itself is bad, defrost the fridge
    with a hair dryer, replace the defrost timer
    and defrost
    thermostat
    Hope
    Daniel
    First try to locate the defrost timer and once you locate the defrost timer, slowly turn the screw like wheel in the middle of the defrost timer with a straight screwdriver until the fridge shuts off. You are now in defrosting. If the defrost heater(s) comes on now, replace the defrost timer and defrost thermostat. If the heater(s) does not come on, you can ohm test the defrost heater for continuity or volt test for 120 volts to the heater(s). If you have no power to the defrost heater(s) you can also bypass the defrost thermostat to see if the defrost heater will come on, join the 2 wires together to bypass the defrost thermostat. If the heater now comes on, replace the defrost timer and defrost thermostat. If the heater itself is bad, defrost the fridge with a hair dryer, replace the defrost timer and defrost thermostat. Hope this helps...please post back for further assistance.
    Daniel
What, other than clogged filter, causes water flow blockage in Whirlpool ED25TE?
FYI - Mine actually froze the water in the line.. had to remove the water filter, turn off the ice maker, pull the fridge away from the wall..remove the line from the fridge connection..laid it outside for a few hours until I could blow through it.. re-installed ..all ok..
Jun 08, 2017 | Whirlpool Refrigerators
Frigidaire side-by-side water & ice in the door Model #GLRS234ZAW1. The refrigerator side freezes with its thermostat any where above the lowest setting. Also the freezer thermostat has to be only a...
Please VOTE FOR ME AND GIVE ME YOUR TESTIMONIAL IF POSSIBLE, IF THIS WAS HELPFUL
ITWILL BE MUCH APPRECIATED.
The cold control needs replacing. Thats the knob with the numbers that turn the Ref OFF and ON.
What I do is call my local Appliance Parts Store with my model no. They are extremely helpful .
Get freezer and ref thermometer. Ref is probably too cold.
Freezer should be 0 to 10 degrees. Ref 33 to 35
If you need more help, Go here:
http://www.applianceaid.com/procedures.html
I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
MORE TIPS AND TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS====
http://www.fixya.com/support/r9962087-stop_paying_high_price_refrigerator
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
Thanks for using fixya
Leo Ponder
imufo2
Sep 22, 2011 | Refrigerators
My HSE02WNAPG Haier was working just fine...until it froze everything inside (I found out when I returned to work to find 2 exploded sodas...whoops). I unplugged it to make sure everything was thawed and...
Leo Ponder
imufo2
Sep 19, 2011 | Haier HSE02WNAPG 1.8 Cu. Ft. Compact...
I don't know what happened to my refrigerator but it is starting to freeze everything. I couldn't change filter because it was stuck, frozen in place. So i had to turn the fridge off so it could thaw out...
1 setting on a fridge is as cold as it can get so it will be close to freezing
should be set on 4 or 5
next if it still is freezing then the thermostat is failed and you will need to replace it
May 09, 2017 | Frigidaire FRS23H5ASB Gallery 22.6 Cubic...
My aquastar 125b ng froze in cold weather and spewed water everywhere. when installes I was told it was ok to have this unit on outside wall. ... any suggestions
Generally speaking, tankless water heaters should not be installed on an outside wall, especially if they are masonary (which lose more heat to the outside) - regardless of what the installer told you. If the wall reaches & goes below the freezing point, so will the water pipes supplying the heater. However I am somewhat surprised that the heating element did not compensate, if indeed it was the heater that froze. I would recommend moving the heater to an interior wall if possible. You may also want to check the thermostat setting as well.
Dec 09, 2010 | Bosch Water Heaters AquaStar 125 series...
The freeze plug came out and water drained.Now when I fill truck back up with water .It runs out of spark plugs holes.
what exactly caused the freeze plug to come out if it froze hard enough to push out freeze plug then it most likely has caused other damage the only way water is coming out of plug holes is the water is entering the cylinders i suspect you either have a cracked cylinder head or a cracked cylinder wall i have seen this on one other engine were it froze and bursted the cylinder wall i reccomend removing cylinder head for further inspection
Sep 13, 2010 | 2001 Chevrolet S-10
ASU9RLS/AOU9RLS unit Froze outside/ won't defrost
The drain had pine needles clogging the drainb so it couldn't drain.
In 2 months.... Thanks anyhow!
Jan 05, 2010 | Fujitsu Electronics - Others
Water filter froze solid
Your refrigerator compartment temprature is below 32 degrees and freezing your water in the filter. Adjust the thermostat setting to a higher temprature setting using a thermometer in the referigerator as a refrence. 34-37 degrees is a good temprature range to keep food fresh.
Jul 31, 2009 | Refrigerators
The fill cup and the water inlet tube are filled with frozen water. There seems to be enough water pressure coming out of the wall and there aren't any leaks. What could be causing this?
Hello LaraKettler,
If the ice is in the water line going to the icemaker then you have a slow leak from the inlet valve allowing water to leak into the line and freezing in the water inlet tube. Replace valve
If you have water freezing in the freshfood side of your refrigerator most likely you have a thermostat problem or you may need to turn your thermostat down. For most models 5 is a good setting to keep your freshfood side around 36 degrees. Hope this helps, please let me know if you have any other questions. MCA0824@aol.com
Apr 30, 2008 | Refrigerators
Everything freezes in the refrigerator
Your damper that controls the air to the fridge side is stuck open. It can be caused by moisture getting on it and freezing it so it wont close or by a failure in the electrical circuit that controls it. There was a service bulletin from about 3-4 years ago about defective control assemblys. I have replaced several and as far as I know Frigidaire is still replacing some of them for free if they fall under the model and serial numbers that were affected.
You can tell if it is frozen by turning the controls off and thawing the damper at the upper left rear of the fridge section with a hair dryer.. After you have it thawed out, turn the controls back on and you should hear the damper door motor running. Keep your thermometer in it and check it after a while and see if it shuts off before it freezes.
Post back with the complete model and serial numbers and I will try to locate the service bulletin at my shop computer tomorrow.
Oct 26, 2007 | Frigidaire FRS26R4C Side by Side...
Refrigerators Logo
49 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
