Question about Jaguar Heating & Cooling
I have Jaguar S-Type 2000, and I am facing a problem in the Air Conditioning System. When I switch On the A/c, the compressor sometimes works and sometimes no. Also sometimes it works for a while, for a short period of time and then it goes Off. I replaced the (Relay), but the problem remains. I hope you can help me defining this problem. Thanking you.
    Scholar:
  • 133 Answers
If it is low on Refrigerant, it will cycle the clutch off. When the pressure rises from the lines equalizing, it will come back on. When it does stay running, does the larger line get cold? If not, it is probably low on refrigerant. Roger
Posted on Apr 07, 2011
Solenoid that affect the heater
The heater is controlled by a 'variable solenoid water valve' that is controlled via the Air-conditioning module. These valves are prone to failure after a few years service. Another cause is if you have refilled the cooling system, the heater matrix sometimes airlocks, this can be overcome by bleeding the hose at high level by the heater hose in the engine bay.
Good luck -hope this helps
Feb 18, 2015 | 2000 Jaguar S-Type
Where do you putgas for air conditioner for s-type 2000 3.0 jaguar
it usually put in on the low pressure side of any air conditioning system, it will be on the largest size alumunin line that comes from the compressor, some have a blue cap covering the service port.
May 05, 2014 | 2002 Jaguar S-Type
Air conditioning problems
First check that all electrical connections to/from your air conditioning components are tight and secure with no broken or chaffed wires and connectors, or oil swollen connection points. Then check that all fuses and relays involved in the operation of your air conditioning system are operational. If all is good, then remove the belt around the air conditioner compressor pulley. Get a wrench and try to turn the front of the compressor pulley. It should turn with little to no resistance. If it wont move or is very hard to turn, it is probably locked up and needs repair or replacement. If it moves, then the compressor part is OK, but your clutch would likely need replacement. Some model cars its cheaper to just replace the whole compressor than to rebuild the clutch. Jaguar sounds expensive - I would seek out a junk yard. Good luck.
Apr 20, 2014 | 2001 Jaguar S-Type
How to remove a radiator form a 2000 jaguar
Removal
  1. Drain the cooling system.
  2. Reclaim the air conditioning refrigerant.
  3. Remove the motor and shroud.
  4. NOTE: Seal the line and the evaporator with plugs.
Detach the air conditioning line. Raise the vehicle.
  • Remove the lower radiator splash shield.
  • NOTE: The splash shield is equipped with hinges which should be treated with care on removal. Remove the radiator splash shield.
    Detach the securing clips.
    NOTE: Seal the line and the evaporator with plugs and Detach the air conditioning line.
    1. Detach the lower coolant hose.
    2. Remove the air conditioning condenser. Remove the securing screws.
    3. NOTE: Vehicles with manual transmission, cable tie the cooling radiator
    4. tach the automatic transmission/power steering cooler.
      Detach the automatic transmission/power steering cooler.
      1. Lower the vehicle. Remove the radiator foam trim.
      Remove the radiator.
    Sep 25, 2012 | 2000 Jaguar S-Type
    Noisy air conditioning pump
    Hi guys,
    I have a 2.0 diesel X type and when the AC is switched on and the centre of the pulley on the compressor goes around it sounds like there is a very noisy rattle from the engine. It is OK when AC is not on. any ideas, and can this be fixed without replacing the compressor.
    Oct 17, 2011 | 2004 Jaguar X-Type
    My air conditioning was blowing only hot air. The dealership replaced the AC compressor. It worked for one day then started again blowing only really hot air. It has not had the problem diagonosed yet...
    It should have been diagonosed already if you had a compressor installed, They are to check for leaks, and should have replaced any bad o-rings,
    When the system is vacuumed (a mechine applies a vac. to remove any moister in the system) it is to sit for min. 15 minutes with pump off, any if the gauge shows that vac. has changed (should be a neg pressure) then there is a leak.
    I would take it back, but I would only pay for parts.
    Check out this site and maybe it will enlighten you how A/C systems work. Good luck
    http://www.denlorstools.com/autoblog/2009/04/adding-freon-to-car-ac-gauge-readings-explained/
    Aug 12, 2011 | 2000 Jaguar S-Type
    Air conditioning system takes a charge, but the
    high pressure switch is kicking out on overload, replace it or you might have too much freon
    Jun 27, 2010 | 2000 GMC Jimmy
    Like a fridge Air con needs recharging ask if your local garage has the equipment
    May 04, 2010 | 2000 Jaguar S-Type
    FAN OF A JAGUAR S-TYPE 2000 HAS ONLY ONE SLOW
    check the blowermotor resistor, this is what controls the blower speed and is a very common problem.try replacing the resistor, that should solve your problem. good luck.
    Mar 02, 2010 | 2000 Jaguar S-Type
    Heating & Cooling Logo
    118 people viewed this question
    Top Jaguar Heating & Cooling Experts
    Lawrence Oravetz
    michael vanier
    NOEL
    NOEL
    Are you a Jaguar Heating and Cooling Expert? Answer questions, earn points and help others
