Question about Tools & Hardware - Others
I took apart our boston 131 stapler. Staples were stuck, now I can't get it back together.
brainyass
  • 242 Answers
SOURCE: LOAD IT
On this model, there should be a spring on the arm. Compress the spring and put the staples in. When you close it, the metal part on the end of the spring holds the staples tight.
_____
I
I
I arm and spring below
I___
___I staples here I_____))))))))))))))))))))))))))))))))))))))))))))))____[___]
Posted on Nov 10, 2008
  • 132 Answers
SOURCE: surebonder 4.8 v cordless stapler
with mine there is a fine spring on the plunger which holds the staples in which i restretch every now and then you could also try checking for jammed staples and putting one or two drops of oil on the shaft that pushes the staples down after the oil operate afew times empty of staples see if this helps bestaluck glenn
Posted on Nov 15, 2008
rowdy45176
  • 2176 Answers
SOURCE: Disassembled the stapler now need diagram to reassemble
Found user manual online but no parts breakdown, I have a phone number at 1-800-343-9329 and they might be to email you the breakdown. Wish I had better info but this is all they furnish online.
Posted on Mar 15, 2009
SOURCE: Can't get the staples to go in. It's a sears
Pull out the part that loads the staples, turn the gun upside down, put the staples in the bottom of the gun and push the loader back in. It took me awhile to realize that you don't load them on the piece that pulls out of the gun.
Cheers.
Posted on Jul 18, 2009
SOURCE: Can't get my Black and Decker 5700 powershot back together.
Need instruction manual on how to put it back together
Posted on Nov 17, 2009
How to put back together
Stanley Model TR45 Light Duty Staple Gun Review - YouTube
? 3:35
https://www.youtube.com/watch?v=hWmvXhkqnYI
Jul 25, 2012 - Uploaded by Vansvideoreviews
Stanley Model TR45 Light Duty Staple Gun Review ... How toPut Staples in a Craftsman Stapler (Model 968447) ... Stanley SharpShooter Manual Staple and Brad Gun review - Duration: 9:35. by Unpack Guy 35,948 views.
How to load staples into a Stanley Stapler - YouTube
? 2:11
https://www.youtube.com/watch?v=j4Q5W0uKS-s
Mar 26, 2013 - Uploaded by David DeStefano
This video shows you how to load staples into a Stanley StaplerModel # TR110. ... Stanley SharpShooter Manual Staple and Brad Gun review ...
put stanley sharpshooter staple gun back together ... - Fixya
www.fixya.com > Forum > Tags
Find solutions to your put stanley sharpshooter staple gun back together question. ... staples for the TRE500 Stanley Sharpshooter Electric Heavy Duty Stapler.
Dec 10, 2015 | Stanley SHARPSHOOTER HEAVY-DUTY STAPLE GUN
How do I reload staplers?
There are two basic designs of staplers. The most common type is the Swingline or Stanley Bowstitch types. At the business end of the stapler there is a small catch that you need to pull rearward and the front staple head will drop down. Inside, you will see a metal bar and a spring. Pull the spring back towards the rear of the stapler and insert a full clip of staples appropriate for your stapler. Release the spring slowly so the metal tab pushes against the staples... should be pointed tips down. Put the stapler on a firm surface and press it as you would when stapling something. The two parts of the stapler head will join back together again.
Apr 02, 2015 | Office Equipment & Supplies
My rexel stapler does not work, any help[
When you lift up the top of the stapler (as though you are going to put staples in), does the pusher slide freely back and forth? It might be getting stuck at some point and not pushing the staples (either due to a worn pusher spring, or friction). First (after removing the staples) try spraying some light oil on the mechanism and lifting the top part of the stapler up and down a few times and observe how easily it moves back and forth. Also, with the top open try GENTLY sliding back and forth a little - if it slides fine with no sticking, try loading staples and using stapler. If it slides ok, but doesn't quickly return to it's "normal position" when pulled so as to put tension on the spring, rhen the spring may be worn and need replacing.
Sep 11, 2012 | Office Equipment & Supplies
WHERE do I open it to refill it??
Located on the end opposite of where the staples come out, there is a spring loaded cap. Push it in toward the base of the stapler and slightly down to release the retaining hook. then let the spring release the pressure rod and pull it out. Connedted to the end of the rod you will see a plunger that is shaped like a short run of staples. Make a mental note of how and where this plunger slides into the base of the stapler. Place a run of staples into the stapler in the same manner that the plunger fits then replace the plunger into the same place following the run of staples. Compress the spring into the stapler and attach the hook as it was. Now you are ready to work.
NOTE: If you cannot compress the spring enough into the stapler you have inserted too many staples, just remove some of the run of staples and try again.
Nov 12, 2010 | Arrow T50P ARROW STAPLE GUN
See above
317b762.jpg4a538aa.jpg067f3f0.jpg5077a62.jpgca392ef.jpge76904e.jpg77309d5.jpgThis is an older b&d stapler but the designs are similar in most cases. The position of the springs, and the order you put them in, are an obvious factor.
The parts that overlap go in after the parts underneath.
When you have one half assembeled you should not have to force the cover to go on, it should just sit in place while you put the screws back in.
If the handle coil spring and the flat spring are not seated properly the top cover will not go on easily.
These types of staplers are designed to clear from jamming without being taken apart, the staples, under normal circumstances, do not have access to the body of the unit past the flat spring.
As with any tool forcing the tool after a fault will only make matters worse, I would try some light oil or spray lubricant first before taking anything apart, these springs can be a pain to get back in, which is why I have not taken this one any further apart. Hope this helps you. If it does please let fixya know.
Regards
Les
Feb 02, 2009 | Black & Decker 5700 Powershot Forward...
AS 300 electric stapler--pulled out jammed staples but even though it staples, it won't grab the staples (staples as though empty)
What has most likely happened is part of a staple is stuck in the front portion of the stapler where it forms the staple and presses it into the stapler.
You would most likely have to remove the stapler, and remove the binding staple from the stapler head.
Sep 28, 2008 | Panasonic Office Equipment & Supplies
Tools & Hardware - Others Logo
894 people viewed this question
Top Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
