Question about Dyson Vacuums
Very little suction only when I press the floor bar hard will it start picking up
SOURCE: No Problems with suction on hoses, however brush area it seems to lose powe, and has little suction r
We had a similar problem with ours and had to finally take it to the repair shop. They informed us that we needed to replace our clutch and that you needed to do that every 2-3 years. It cost less than $100 and has been well worth it.
Posted on Jun 24, 2009
  • 430 Answers
SOURCE: vacuum not picking up dirt
The neck in your power head is likely clogged. Disconnect from the wand and look inside. Also check the wand.Since you have suction on the bare floor the hose is likely not blocked.
Posted on Sep 11, 2009
Shorty1_wt
  • 324 Answers
SOURCE: not picking up dirt. hardly no suction
if your model has a hose for a wand or brush attachment then remove the hose and check it for clogs.
Posted on Jan 23, 2010
VacuumRepair
  • 438 Answers
SOURCE: Loss of bare floor pick up
There are several things that this could be. Probably the most common problem that we see when customers come in with this problem is actually a fairly simple problem to fix. Here are just a few things that this could be.
The fist possible problem sounds like the most probable to me, just because of the fact that you said you had just replaced the clutch, and therefore you had to remove the bottom sole plate. This is a VERY common problem actually.
Possible Problem #1. The first problem is extremely common. In fact, we probably see between 2-3 of these problems every week. It mostly happens after people take the bottom plate off the vacuum in order to clean the roller brush. What happens is when they reinstall the bottom plate, they put it on on incorrectly. It's actually very easy to do. When the bottom plate (soleplate) is installed wrong, there will be a gap between the bottom plate, and the agitator housing, or the purple tray the roller brush sits in. This will cause the soleplate to be a few inches higher off the ground then it should be, preventing the brushes from even hitting the carpet. This makes it seem to the user that vacuum has lost suction power because without the brushes hitting the carpet, the machine will not pick up very well on floors, but when they use the attachment hose there's plenty of suction power.
Here's a picture of the WRONG way to install the bottom plate. Notice the gap in between the two housings:
Here's another picture, that is the RIGHT way to install the soleplate:
I would say probably 6 times out of 10 this is the problem with the customers machine. If you checked the soleplate and it is installed correctly, move on to the second possible problem.
Possible Problem # 2. Turn the vacuum cleaner upside down so the brush roller is facing upwards. I found the easiest way to work on it is to put it on a counter top or work bench. On the left hand side behind the roller brush you should see a flexible transparent hose that goes from the motor to the agitator housing. This hose actually has a lot of strain on it when the vacuum cleaner is in the reclined position. When the first few series of Dyson DC07 models came out, they didn't make this hose long enough, so when the vacuum was in the reclined position, it would put too much stress on the hose, and cause the hose to actually crack, usually right where the end of the hose that goes into the agitator housing. Examine your hose and see if you have any visible cracks in this hose. If you need to you may just remove the entire hose assembly by pulling on it. It will easily come right out of the machine so you can inspect it better. Here's a picture of where the hose usually cracks:
This would also explain why the vacuum works fine when using the attachments, but not on the floors. The attachment hose uses a different suction channel, and when the machine is in the upright position, no suction goes through this hose. If you do find a crack in this hose, the this hose needs to be replaced. Here's a direct link to that hose on our GoVacuum website.
Dyson DC-07 & DC-14 Upright Replacement Internal Hose Part # 904219
Possible Problem #3. I would suspect that this may not be the problem, but if neither of the solutions above worked, then try this one. Dyson's in general are prone to clogging. There are a few clog ports throughout the vacuum cleaner that were added there due to Dyson prototypes becoming clogged at these points. Here are pictures of how and where to check for these clogs. Simply remove the suction port covers at both of these locations:
If you are getting suction power from the hose, but the vacuum still doesn't pick up on the floors, I think that these solutions should fix your problem. If you just replaced the clutch mechanism, the roller brush should be fine, but turn the vacuum over on it's side and make sure that the roller brush is actually spinning while it's on carpet mode. If none of these problems fixed your Dyson, please use the Clarification Request, or leave another comment here on the Fixya repair page, and I'll be happy to further diagnosis the vacuum cleaner with you.
I hope this was helpful to you. If so, please be sure to rate the repair as helpful by clicking the thumbs up icon in the top of the repair page. This is what keeps Fixya repair professionals like myself continue posting these detailed repair solutions for free. We really do appreciate when someone recognizes the work you've done. Thank you very much,
Chris J.
GoVacuum
Posted on Apr 05, 2010
SOURCE: hi my dyson dc18 has great suction from wand but
My Dyson dc18 had the same symptoms. The wand worked well and the floor bar had no suction. After removing pieces & shoving my fingers into the machine (no blockage) I found the suction pipe rotates between two positions (floor and wand). It looks like a piece of plastic broke on the outside housing, so it no longer rotates positions when the wheels are raised or lowered. My son found we can move the suction by sliding a finger into the mechanism behind the wheel cover, and rotating the plastic piece clock-wise or counter clock-wise until it locks into position. It's a big pain but it works for now. I wish I could find a replacement piece online. Patty
Posted on May 23, 2010
My dryson dc40 beater bar will not spin and there is no suction
The brush bar motor or one of the switches may be defective. If the brush is not spinning it will not pick up anything from carpet leading many to think it has no suction. Feel for suction down by the brush bar. If you have no suction it may have a clog or need new filters. Make sure the changeover valve that switches suction from floor to tools is working properly.
Mar 25, 2018 | Dyson Vacuums
Very low suction. hardly picking up dirt . cleaned rollers and all openings.
There could be an obstruction somewhere. Start from the brush bar and work your way back trying to determine where it is.
Mar 14, 2015 | Dyson Dc18 "slim" Upright Model...
VACUUM BEATER BAR WONT TURN AND NO SUCTION ON FLOOR. LOTS OF SUCTION FROM HOSE.
If the belt is stretched it will not pick up properly. Try replacing the belt first. Belts should be replaced at least twice per year.
Feb 24, 2015 | Bissell PowerGlide Deluxe Pet...
Our DC41 is impossible to push on carpet. Is there an adjustment to do? Almost like there is too much suction.
See if the following information can help.
CARPETS OR HARD FLOORS
• The brush bar will always default to 'ON' (spinning) each time you switch the
appliance 'ON' and recline it for cleaning.
• The brush bar will not rotate when the appliance is upright.
• To switch the brush bar 'OFF' (e.g. for delicate rugs and hard floors):
- switch the appliance 'ON'
- recline the appliance
- press the brush bar 'ON/OFF' button - the brush bar will stop spinning.
• The brush bar will automatically stop if it becomes obstructed. See 'Brush bar -
clearing obstructions'.
• Before vacuuming your flooring, rugs and carpets, check the manufacturer's
recommended cleaning instructions.
• Some carpets may fuzz if a rotating brush bar is used when vacuuming. If this
happens, we recommend vacuuming in 'hard floor' mode and consulting with
the flooring manufacturer.
• The brush bar on the appliance may damage some carpet types. If you are
unsure, turn 'OFF' the brush bar.
Dec 31, 2014 | Dyson Bagless Upright Vacuum DC41 Animal
The suction seems so strong on the floor that it is suddenly hard to push. Don't notice anything thing that would actually lift it off the ground making the suction not so air tight. I have check the...
I'm sorry to hear you're having difficulty using your DC24 on this particular flooring. The cleaner head is designed to adjust automatically to suit the surface being cleaned, and the cleaner's powerful suction causes the soleplate to seal closely with the flooring for high pick-up of dirt and debris. You may find on certain floor types that this makes the cleaner feel a little heavy to push.
Reassuringly, it sounds as if your cleaner is working correctly - however, if you wish to discuss your issue further with one of our experts, please get in touch with us directly. You can call us free on 08002980298 (UK), or 1866MYDYSON (US).
Kind regards,
Jack
Dyson Online Customer Support
Jul 17, 2011 | Dyson Ball DC24 Bagless Upright Vacuum
My Dyson absolute vaccume has no suction. I have cleaned the filters, visually checked all of the hoses. there is no suction from the floor brush or the wand.
Check the ducting that goes from the floor pick-up into the machine, fluff etc often clogs the elbow. Check the pipe that plugs into the floor pick-up as well, it could be clogged further up.
Jan 28, 2011 | Dyson DCO3 Absolute Bagless Upright...
Brush does not turn. suction with the handheld unit it fine but when used as a floor sweeper it hardly picks up anything
these stick mmachines do not have a tremendous amout of suction at the best of times but if it has a full bag, or full dirt container, or dirty exhaust fiters it will take away from the air flow as well. take a flashlight and look up in to the tube of the floor attachment to see if you can see something blocking the tube.If there is no obstructions it may have a roller bar that spins on the bottom , so turn it over and turn it on and if it has a roller bar and it is not spinning it probably needs abelt . If there is no roller bar and no blo0ckage chances are it is just weak at the floor tool as the air a further to travel all the way up from the floor so it takes away from the air flow again. good luck.
Oct 07, 2010 | Electrolux Pronto 2-In-1 Stick/Hand Vacuum...
The suction is good, but it can't pick up most of the stuff on the floor. The hand held hose works very well, but it doesn't even pick up little fuzzies reliably when I push it along. And, the suction is...
Check entire length of hose, including the piece in the power head, for clogs. Simply drop a marble in one end and allow it to roll out the other. If it doesn't, then the hose is clogged somewhere.
Aug 22, 2010 | Dyson DCO7 Animal Bagless Upright Cyclonic...
My dyson slim dc18 has suction in hose attachment but no suction in floor attachment. Tried to clear any obstruction by running clothes hanger in rectangular opening that empties into cannister and also...
Hi its Darran at Dyson.
It would be worth checking that the brush bar is turning when the machine is in the vacuuming position. If it is not turning, please press the re-set switch located on the cleanerhead.
If this starts the brush bar turning but does not solve the problem, please check the cleanerhead for blockages and remobve any threads or hair trapped around the brush bar.
Shoudl you need any further help or advice, please contact our Helpline on 1866MYDYSON.
Kind regards
Darran
Dyson Customer Service
Apr 19, 2010 | Sharper Image Dyson Slim DC18 All Floors...
Vacuum not picking up dirt
Sep 11, 2009 | Kenmore 22512 Bagged Canister Vacuum
Vacuums Logo
274 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
